Question about Brother IntelliFax-2820 Laser Fax
Fax machine is not pulling paper for printing.
  • 63 Answers
Atypically this indicates one of three problems.
  1. the nip rollers have become oily and traction for the paper to feed does not exist
  2. the nip rollers on the paper feed spindles are worn and are not grabbing the paper.
  3. the gear teeth in the sprocket of the feed spindle are damaged (broken)
In case one some manufactures provide utility kits with paper that has a rough surface to which you can condition the rollers (kinda like a sand paper)
In case two and three (above) these items will need to be replaced. This is not a job for a novice and given the return on investment ... you may be better off buying a new machine.
Posted on Oct 06, 2009
Panasonic kxfc225 fax
Open the machine up to see if you have drop something in it like a pencil, piece of paper or other debris. Hold it upside down and see if something falls out.
Oct 15, 2013 | Office Equipment & Supplies
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
Our fax machine is sending faxes fine, but will not print in coming faxes. It keeps asking for paper (which is in the fax machine), then it sounds like it's working, then stops. We turned it off to see...
The paper isn't properly loaded. remove the paper then there should be a lever near the paper loading section that you push or pull to let the paper enter the feeding area. put in paper and return the lever to the proper position. check your owners manual. to get a manual try www.sharpusa.com .
Dec 16, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
How and were do you load the paper in the machine
there should be two flaps; the first one is the larger flap at the back,put the blank paper to print there. where the smaller flap is (the doucments go) in the front, When you get ready to fax the doucment. It all should come out into the tray at the bottom of the fax machine. Look under the front of the fax machine and you should see a round indentation, put your finger into that and pull the tray out..
Mar 02, 2010 | Lexmark F4270 Plain Paper Inkjet Fax
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
When receiving a fax, it seems that several pages of paper always
you mean you're getting 1 or 2 extra sheets when machine is printing faxes? Feed roller and separation pad that pull paper from the tray are worn.....cleaning will help in the short term.
Feb 22, 2009 | Canon FAXPHONE L80 Laser
Paper is not "picked up" to print.
TRY CLEANING THE PAPER ROLLER WITH DENATUYRED ALCAHOL OR MAY BE THERE IS SOME THING STUCK IN THE MACHINE GO AHEAD AND LOOK GOOD LUCK BROTHER TECH
Jan 28, 2009 | Brother IntelliFAX 2800 Laser Fax
DOES NOT PRINT INCOMING FAX- PAPER COMES OUT BLANK
Have you tried a new toner cartridge?
Did you pull the plastic tape on the cartridge?
Mar 21, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
How Can I Reprint a Fax?
Here's a trick that I used on the Canon thermal transfer years ago. First take out the thermal transfer unit and roll up the black transfer sheet to the begining of the lost fax. Then reload the paper. Next get a solid black original equal and make a copy. The result you should get a negative copy of the lost fax. Repeat this step until all the faxes are recovered..
May 31, 2007 | Panasonic KX-FC195E Plain Paper Thermal...
Brother IntelliFax-2820 Laser Fax Logo
223 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
