Question about Sharp Office Equipment & Supplies
Sharp Z-835 Paper Jams
This little copier has been a faithful companion in my home business for over 10 years. But for the past 8 months, the paper jams just as it is coming through the rollers. About 1/4'' to 1/2'' of the paper will peek through (usually at an angle, toward the user) and jams. After nearly a dozen tries, I can get a single copy or a single job with multiple copies (without jamming -- go figure). After some experimenting, I learned that the weight of the paper seems to make a difference on how successful I am in getting a copy made within the first couple of tries. Heavy resume paper and even a single sheet of the light tri-carbon paper works better than the standard 20lb. paper. Can this problem be fixed? Does it require a replacement part, and if so, where can I find it? Except for this frustration, the quality of the output is fine. Thanks in advance!
  • 63 Answers
A few things come to mind;
1) Feed rollers in tray are either worn or dirty
2) Transport tires are dirty
3) Fuser worn
If you've had this for 10 years and have not done much to it besides a toner or drum then I would recommend taking it to a qualified technician.
Posted on Oct 12, 2009
Testimonial: "Finally found someone to service my copier. Turns out rollers were badly worn, just like you said. Good to have that 2nd opinion going in. Thanks!"
How do I fix paper jams for HP CP1215
It depends on the printer, but I found that when one of my HP printers was over 4 years old I had to upgrade to a higher quality paper to avoid paper jams. **Hammerill and Navigator are two brands. They may cost a little more to use, but it extended the life of the printer and restored the printer to normal. Those papers are noted for a more slippery paper surface in their processing, that essentially eliminates all paper jams.
Jan 21, 2015 | HP Office Equipment & Supplies
Brother Fuser Unit not feeding paper
It is possible the gloss stock is gumming up the printer.
Jan 08, 2014 | Brother HL4570CDW Printer
Paper jams at the fusing unit on my Sharp AR 275
Very common problem in that copier. The fuser unit has little pawls which seperate the paper from the rollers, they can become dislodged when customers remove jams. Another very common problem is the gear that turns those rollers wears down internallly, to check this make a mark on the orange fuser roller with a sharpie. See if the mark moves from it's previous spot after trying to make a copy. These rollers turn every time the machine is used or is turned on.
Sep 10, 2010 | Sharp AR-275 Copier
Flashing p and paper will not feed it jams
Clean the paper feed roller under paper tray use izopropilic alcool.
Sep 27, 2009 | Sharp AL 1631 Copier
Sharp 2300n gets paper jam. It fold paper like an
When you clear the paper from the machine at the fusing unit, you can see 8 pawls, it looks like a hook but in a flat design. They should be touching the heat roller ( each has a spring to make it flexible ). If one not touching the heat roll it will caused the paper stuck to it so you will have the accordion paper jam.
Jun 04, 2009 | Sharp Office Equipment & Supplies
MY SHARP AL-1010 IS MAKING A CLICKING SOUND AND THE PAPER JAMS
clean up paper delivery roller, if paper come out little bit out and stop, then you have a paper exit sensor damage
Dec 14, 2008 | Sharp AL 1215 Black and White Copier
Paper Jam
If you are getting a lot of jams in the fuser then there is a problem in the fuser unit !
Is it jamming like an accordion? if Yes, then the problem is w/ the little fingers in the fuser, they are worn and need to be replaced. The rollers in the fuser should be shiny and smooth if not they ca also cause jams.
What black thingy are we talking about and where? if it's the fuser rollers ( where the paper exits and gets hot then try cleaning w/reg soap & water rag then wipe off.
Nov 17, 2008 | Sharp AR-153E Copier
Paper jam with card stock paper
Try Getting a PM kit to replace all the rollers.
Nov 13, 2008 | HP LaserJet 2550Ln Printer
Sharp SF-2014 Copier Jams
1-check and make sure the paper sizes coreresponds : If using Letter it must indicate 8 1/2x 11 or (Letter) not Legal or 8 1/2 x 14.
2- the tires are slipping and trowing the timing off. change tires (cheap)
Aug 20, 2008 | Sharp Office Equipment & Supplies
PAPER JAMS CONSTANTLY
Well, it might be theres something stuck in there. Pick it up and give it a few shakes. I work on printers, and not too long ago I found a wedding ring, paperclip, banana sticker and other things in printers. If that doesn't work, try going to staples and getting a laser cleaner kit. They're basically sheets coated to pick up any paper dust, or bits of paper that might be clogging the path
Mar 11, 2008 | Brother HL-2070N Laser Printer
88 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
