Question about Samsung HT-X810T Theater System
Samsung HT-X810T won't eject - Samsung HT-X810T Theater System
The disk is stuck and won't come out
A couple of things you could try...
1. Remove the power socket from the wall and leave out for thirty seconds. You need to actually remove the plug from it's socket, not just switch the unit or plug socket off.
2. Near the DVD tray there is usually a small hole (a little bit bigger than the size of a pin). This is usually a manual eject mechanism. You can use a pin or a straightened out paper clip to push inside the hole which would normally activate the eject mechanism.
Jan 20, 2011 | Samsung HT-X810T Theater System
Flashing code s/w chk
It is just that main unit is looking for the "Wireless sub-woofer" and shows this message when it can't find the sub.
wireless connection between main unit and sub should be reset.
Mar 11, 2010 | Samsung HT-X810T Theater System
After applied the firmware from Samsung site the USB door just says NO FILE when before worked fine with the same external disk or pens.
I had the same problem. but if you dont put your files in folders it will work. after firmware upgrade it couldn't read folders and it is a stupid thing.
Dec 23, 2009 | Samsung HT-X810T Theater System
Remote code for samsung ht-x810
go to samsungusa.com and look for a listing for codes, or you can go to the store and look at a universal remote package for the code
Oct 18, 2009 | Samsung HT-X810T Theater System
Samsung HT-X810T Theater System Logo
519 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
