Question about Kenmore 33464 / 33465 / 33469 Gas Single Oven
The glow bar is on, and there is a little heat coming from it, but it doesnt want to eat to the full temperature. Does it normally take 15+ mintues to heat to full temperature?
  • Kenmore Master
  • 3,361 Answers
One minute on the average. Replace the glowbar ignitor. It is bad.
Posted on Oct 06, 2009
Fan oven over heating
I would contact the manufacturer .there could be a recall on it if you make them aware of the problem .
Dec 12, 2015 | Ovens
No gas flow to oven, glow bar ignites no flame no smell of gas. safety gas safety valve was replaced
With the glow bar going and no gas smell that means you have a good circuit from control to valve and glow bar. For that glow bar to work it must change in resistance. If it is weak it won't change enough resistance to make the gas valve bi-metal open. Also the gas safety valve does not come preset and usually is bottomed out all the way for propane. You must adjust the orifice to aprox the same height as the old one to get the propah gas output for natural gas.
if your old valve did not leak and has continuity between the terminals it is fine. The ignitor/glowbar is weak. If it is dim orange that is usually a way to tell. Bumping the stove makes the bi-metal come on also is a sign of a weak glowbar
Jul 14, 2011 | Magic Chef Ovens
HOW DO I LIGHT OVEN PILOT?
Hi and welcome to FixYa, I am Kelly
Your model number was missing digits so I used this manual:
GRP17WEWWW
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=981380002.PDF
and if your unit is older this one:
http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=ShowPDF&FileName=49-8514.PDF
Automatic Ignition
The oven burner is lighted by electric ignition. To light the burner, press the pad for the desired electrical function and press the INCREASE or DECREASE pad until the desired temperature is displayed. The burner should ignite within 60 seconds. After the oven reaches the selected temperature, the oven burner cycles off completely, then on with a full flame to keep the oven temperature controlled.
GE contact data:
If you don't understand something or need more help, call:
GE Answer Center®
800.626.2000
24 hours a day, 7 days a week
Both the new and OLD units use a glow bar for lighting the burner. Most likely your Glow Bar has failed: GE PN: WB2X9154
The Glow Bar is item 316 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214914&diagram_id=20725728#d20725728
If you net search the WB ge part number you can save lots of money!!!!
http://www.amazon.com/WB2X9154-Gas-Range-Oven-Igniter/dp/B004H3XQPM
If the glow bar is glowing and you still do not get ignition respond here and we can go through troubleshooting.
Thanks for choosing FixYa,
Kelly
Apr 23, 2011 | GE JGRP17 Gas Single Oven
Oven takes too long to heat up sometimes wont even go to the temperature ignitor is working well can see the glow magic chef model 3488vvv serial 13368882kz
Hello there:
When you turn the oven on, open the oven door and look down at the bottom and see if its glowing red, it should glow red for about 45-60 seconds then you should hear the gas ignite. If the gas doesn't ignite, then your igniter glow bar is bad.
Here's the oven glow bar igniter for your model:
Manufacturer's Number: 74007498
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=
partimage.aspx?imgid=z3bqljbfbxnfodk0nzawndcvq0fnl3nvdg9ochryyxav
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=74007498
Sep 28, 2010 | Ovens
RATIONAL COMBI OVEN ELEMENT GLOWING RED -IS THIS NORMAL?
your oven is electric yeah? the hot air element shouldnt be glowing like that, it glows with the door open? the oven has a over temp stat so if the oven got too hot then it would trip out, if it does then the solid state relays will have to be changed, but if it carries on as normal then shouldnt worry
Feb 05, 2010 | Ovens
GE gas oven--Spectra--the oven does not heat--the broiler works, however
Most common problem is the glow bar ignitor. Lift off the bottom panel of the oven and remove. (Some have two screws holding the panel at the back of the panel.) Turn the oven on and see if the glow bar glows.
Even if the glow bar glows doesn't mean that it is working 100%. An amp probe is need to see if the glow bar is drawing the proper amperage to allow the gas valve to open allowing gas to come to the burner. The glow bar should draw about 3.5 to3.8 amps. If drawing more or less than this, replace the glow bar ignitor.
I hope this helps.
Jan 25, 2010 | GE Ovens
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Electric starter gas oven model jgrp17 won't heat
more than likely your glow bar ignitor has stopped working or at least pulling enough amps to open the safety valve. The floor of the ovens come out may have a couple screws toward the back. take the floor out if a diffuser is on top of the burner remove it. the glow bar ignitor is mounted on the burner turn the oven on and watch it should glow bright red and in about 30 secs open the gas safety valve. If it does not glow you may want to verify power to the ignitor, more than likely the ignitor is the problem. If it glows but does not open the safety valev still replace the ignitor not pulling the required amps to open the safety valve. just put a little dish soap on the screws to the ignitor to help from srtripping them out
Nov 13, 2007 | GE JGRP17 Gas Single Oven
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Kenmore 33464 / 33465 / 33469 Gas Single Oven Logo
94 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
