Question about Maytag Dishwashers
The dishwasher is probably 12-15 years old. It
The dishwasher is probably 12-15 years old. It now will stop running repeatedly and we must push harder on the door which is closed, with no play, yet it stops itself until we push on the door and it starts again for a while.
  • Maytag Master
  • 3,361 Answers
Adjust the door lock. Check the door switch wires. Replace the door switch mechanism. In this order.
Posted on Oct 06, 2009
13 yr old dishwasher suddenly stopped working mid pre wash. Water left in bottom of machine. Power point is fine. Will not start at all now though. No lights turn on either. Is it fixable ?
If it is 13 years old, it has most likely reached its end of life--whatever the cause, something has malfunctioned. However, a service technician would probably be able to advise.
Mar 16, 2016 | Dishwashers
Dishwasher motor starts and stops
Hey Bill,
Not professing to be any kind of a dishwasher repairman but I have had a similar issue with the start and stop thing and it turned out to be the timer motor had started to go, and in going it 'burned' a couple of sets of the contacts as well. Check with a local appliance repair centre and see first if they agree with me, and if they have anyone who can rebuild the timer - Typically not too hard to get access to and remove - In my case in Canada, it had to go to Toronto pre-paid but $70 was cheaper then a new dishwasher and it's worked great for years
Feb 09, 2014 | KitchenAid Dishwashers
Dishwasher will not start.
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Washer fills, runs 5 seconds and stops for 5
Major problems here. Sounds like a circuit board thing. If the machine is on the old side , ditch it and start new.
Oct 06, 2009 | Maytag Dishwashers
Dishwasher only runs for 21 minute cycle
I bought and replaced the control board in the door. $145 CAD it took 5 min saved myself $300
May 07, 2009 | Dishwashers
Water does not turn on. It is ok in sink area...it runs out.
You have 1 of 2 problems on this 35 year old DW...
1. The water solenoid is out.....need replacing.
2. The timer is going bad (has gone bad)...needs replacing....what happens over the years...with timers is that the teeth wear out , break,, wear down, and will not engage specific functions of the dishwasher as in activating the water solenoid. The odds are these parts will be cheap...but having been in the industry for 35 years...I have found that often when you install a new part in an old unit ....it places a load on all the old parts...that they are not used to...and other parts start to fail...you will probably be better off buying a new one....hopefully (and probably) the last you will ever need since you only use it once a week.
I hope this helped thanks ...the Fang.
Mar 27, 2009 | GE Dishwashers
Viking Designer Series DFUD041 Built-in Dishwasher
Did you try the power on button all the way to the left?
Jan 27, 2009 | Viking Designer Series DFUD041 (Premium)...
Doesn't run
I asked for help when the dishwasher (GE 1991) started up and then quit. Your site was useful as we found a priority list of things to check, thus saving much time and confusion. Our problem turned out to be a disconnected ground wire.
Thanks for the help. You probably saved us a couple of hundred dollars for a repairman. We intend to replace the dishwasher next year when the kitchen is renovated so the timing was important.
Nov 23, 2008 | GE 24 in. GSD4020Z Built-in Dishwasher
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
Bosch 24in SHU43, 3 years old
Un plug it for about an hour and  try it again.Its probably built a static problem on your circuit board.
May 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
93 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
