Question about Sony STR-V555ES Receiver
No Audio from any source.
Audio not passing from any source or input config. Is there a fuse inline on the Audio Xfrmr sec to test ? Primary fuse ok, all display working correctly, relays sound functional.
  • 1 more comment
  • mendelectric Dec 25, 2007
    Good try, but there are no pre-amp in on this model Sony STR V555. This has been working for years in its present location without any problems. Suddenly stopped passing audio. I suspect a secondary fuse or circuit board issue, because the main fuse is ok and I get function control. Wish I could get a schematic of this thing so I could trace the fault out myself. Probably not worth the cost to send into Sony service for repair. Are there any tests that can be made on these circuits without the need of an expert or special diagnostic tools?
  • rademacg Mar 08, 2008
    Help. I have the same exact problem with my Sony V555ES.
  • viking55y Mar 24, 2009
    Sony STR-V555es has no audio or video. Digital displays all seem fine. Snapping noises from speakers but now sound or picture. Bob Sr
    Problem Solver:
  • 6 Answers
Have you got a Preamp in and out
Posted on Dec 23, 2007
  • neville bolton
    neville bolton Dec 24, 2007
    is the preamp in and out, at the rear of the amplifier.
    are these connected.
Turn off captions on magnavox tv model 32MV304X
What is your video source? If the source is TV (OTA or cable with an RF input), then press Home. Use the left/right arrows to navigate to Setup. Then press OK. Use the up/down arrows to navigate to Features and press OK. Use the up/down arrows to select Caption settings and press OK. Make sure that you are on Closed Captions and press OK. Use the left/right arrow keys to change the value to Off.
If your source is not the TV, you may need to adjust the captions on the video source. For my IPTV box, I need to press Menu and go to the settings menu. After pressing OK, I need to enter a pass code provided by my TV provider and press OK again. Once in this menu, I found the caption options under Hardware Settings and the Audio sub-menu. On some satellite receiver setups, one receiver was the primary box and fed a signal to a secondary box. In that case, the captions could only be enabled or disabled at the primary box.
The manual for the Magnavox 32MV304X/F7 is available on the product page: https://www.magnavox.com/en/products/129-32mv304xf7.html . Expand the Download Support Documents section. The direct link to the manual in English is currently: https://www.magnavox.com/en/index.php?controller=attachment&id_attachment=150 . See page 27 of the manual for images of the Captions sub-menu.
I hope this helps. If you need further advice, please add a comment with the video source.
Dec 04, 2017 | Magnavox Televison & Video
Interior lights and door locks not working
The central element here is not a relay but the multi-function alarm lock & lighting (MALL) module. You indicate the 20A fuse in the relay center is OK. The MALL also receives BAT power through 15A CTSY/PWR MIR FUSE 6A and IGN input through 15A IGN CHIME/CLSTR FUSE 10 in the I/P fuse block. Voltage from 20A SIG/BU/LP BTIS/CCR FUSE 18 in the I/P fuse block passes through the park/neutral position switch in PARK position to supply PARK POSITION INPUT to the MALL. All of these inputs are required for the MALL to function correctly.
Apr 21, 2014 | 1996 Oldsmobile 88
Speakers on cinema surround sound working on test only
More than likely the optical connection is defaulting to another source. The optical may have been intentionally assigned to another source and either needs to be reassigned or try switching the inputs on the unit until you hear sound...
Feb 04, 2014 | Logitech Z-5500 Audio Subwoofer Thx...
There seem to be no power. Nothing is on. I change the 9 Volt battery and still nothing is on. No radio, No clock. For a Bose clock radio. David Fong
Sorry for the late answer to your solution. There was some problem with my account in fixya.
I was not able to post any solution from yesterday as the new site is in development stage as told by the customer care of fixya.
I seen your question. You have to check the power cord of your bose wave radio first. Is there is any loose contact at its socket at the both ends. If its seems ok, Then you have to check the inline fuse inside the wave radio. For that you have to open the wave radio. I am giving you this solution assuming that you are aware of reparing electronic items. If you have some knowledge on fixing electronic items then you can fix it yourself.
Before removing the wave radio remove the power cord from the sockets. There will be 6 screws at the bottom of your wave radio in some models its 8 numbers. After removing the screws turn the radio and pull out the top cover. You can see the inline fuse near the AC input socket where you connect the power cord. Using a multimeter test the contnuity of the fuse. it should show zero ohms. if no, then the fuse is faulty remove the fuse and replace with a new one and power up the radio and check
If there is no other fault the wave radio will work ok. If the fuse blows again then the transformer of your wave radio is faulty. The primary winding of the transformer have some short inside. As it is a custom design the C core transformers are only available through bose service centers. If they are willing to supply the transformers to customers then buy it from them and replace yourself. If not, then you have to give the radio to them to be repeired. If you need any more assistance feel free to conatct me through fixya.The fuse will look like one in the picture.
Dec 05, 2011 | Audio Players & Recorders
Replaced the battery in the car but now unit seems dead although power to inline fuse is OK. KD G386/385 Has it got an internal fuse ?
It might be a good idea to check all of the fuses in the car. The radio requires two power sources in order to work properly.
Aug 22, 2011 | JVC KD-G340 Car CD/ MP3 Player
Where is the fuse on the philips fr965 receiver ?
The mains fuse would be located inline with the primary of the powersupply transformer inside the amp chassis. Exercise caution when servicing electronic equipment. Good luck.
Feb 09, 2010 | Philips FR965DHT Receiver
Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Apr 22, 2009 | Yamaha RX-V663 Receiver
Changed battery cable now radio will not even come on.
When you said inline fuse I get the idea that this is not the original radio. Do you have power on the inline fuse? The 50 amp fuse you checked is a bit much for a radio. There may be a smaller fuse in another fuse area of what car type you have. If you do not have power at the inline fuse find some where you do have power (12vdc) and connect to it. If you have power at the in line fuse check the ground wire. If you have a test light or someway of checking for power test all fuses everywhere. If you have a fuse location guide for this vehicle look for the fuse for radio. If it was a add on or after market radio they probably caught power from the original source That is fused under the dash.
Jan 13, 2009 | Alpine CDM-9821 CD Player
ASA 5510 sec - bun k9
Basic Commands pixfirewall(config)#hostname PIX !--- Naming the PIX is optional. PIX(config)#nameif ethernet2 fo security20 !--- Naming the interface is optional. It is recommended that you !--- hardcode the speed/duplex. PIX(config)#interface ethernet2 100full !--- Bring up the interface. PIX(config)#ip address fo 192.168.1.1 255.255.255.0 !--- Assign an IP address. Failover Commands PIX(config)#failover ip address fo 192.168.1.2 !--- IP address for the failover link. PIX(config)#failover lan unit primary !--- This unit is primary . PIX(config)#failover lan interface fo !--- The 'fo' interface is used for LAN failover. PIX(config)#failover lan key cisco !--- The Pre-shared key. PIX(config)#failover lan enable !--- Enables failover. PIX(config)#failover !--- Start the failover process. This message appears on the console:
LAN-based Failover: trying to contact peer failover_01.gifLAN-based Failover: Send hello msg and start failover monitoring
Nov 27, 2007 | Cisco ASA 5510 Firewall
Sony STR-V555ES Receiver Logo
256 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
