Question about RCA R52WM24 52" HDTV Projection Television
Dark area on top and bottom of screen
I have a 55 in. proj. screen. the screen has dark areas on top and bottom. can i fix this myself?
4 Suggested Answers
  • 1030 Answers
SOURCE: Distorted Screen for RCA HD56w66
convergence is the problem. first question do you have convergence in the customer setup menu. if you do not it could be a special small fuse if you do have "convergence" in the setup menu then you most likely have a convergence power board issue. and generally they are replaced. in our shop such board replacement average 124 labor and about 100 for part. if the fuse bout 15 for part and 80 for labor. there are solder connection that cause the blown fuse
Posted on Feb 21, 2008
SOURCE: Dark, ghost-like, triangle-shaped area in upper
I had the same problem on my 50" DLP. Today I took the light projection mechanism apart to get to the mirror tunnel (a piece about 1.5" long located between the projection bulb housing and lens housing) and, for now at least, the shadow problem has been corrected on my TV.
It would be difficult to describe in detail without photos of how to remove the mirror tunnel. Briefly, once the lower rear cover is removed, it involves completely removing the entire assembly of the projection bulb and lens, along with disconnecting 3 or 4 cable connections. This assembly is held in place with 3 large screws around the projection lens housing in the lower center of the TV. After it's completely removed from the TV, removing smaller screws will break down the component parts. Once you locate the color wheel (about 2" in dia.) between the bulb and lens, the mirror tunnel is directly adjacent to it.
Handle it all with care, and I strongly suggest that you immediately cover the protruding projection lens will a lens cleaner cloth (held by rubber band) so it doesn't get scratched or smudged while you're working on the assembly. This will all make more sense after you get into it. Just remember where everything goes, both cables and screws!
My four mirrors had indeed shifted into a flatter parallelogram than it should be. On my set the metal tunnel casing is molded so that it doesn't allow for the mirrors to be in the shape of a rectangle; it requires a parallelogram shape. The mis-shapened tunnel caused a small portion of the metal mirror housing (on the lamp end) to protrude into the interior of the tunnel, hence the shadow on the screen.
To re-shape the mirrors I gently inserted a nylon cable tie--with a sharpened leading edge--into the tiny gap behind the mirror that had shifted. In doing so the mirrors shifted back to the proper positions and stayed there when I removed the cable tie. (Be very gentle with the mirrors and do not insert anything into the tunnel!)
It's not clear why this (now restored and larger) gap behind that one mirror even exists, but to ensure the the mirrors don't shift again, I inserted and left in a length of cable tie (which is near perfect in thickness and width) in the gap. Time will tell whether heat will deform it.
Perhaps a similar-size strip of metal would be better but I didn't have one. And I would not use any kind of glue or adhesive on these mirrors (as others have suggested); with their small size and the need to keep them crystal clear there is just too much potential to royally mess them up.
After putting it all back together and testing, the shadow is gone. Hope this helps and works for others!
Posted on May 03, 2010
Slinteriors
  • 8617 Answers
SOURCE: my rca r52wh74 hdtv has
The deflection board is the usual cause of that symptom. You can Get THE ITC222A deflection board from www.tvrepairworld.com which also includes a 6 month warranty on the Circuit board
Posted on Sep 21, 2011
Dark pic on screen, unable to correct with regular means.
Regardless, my answer stands. It needs repair by a qualified technician. Rates vary by area. Make telephone inquires.
Jan 09, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Dark area on screen
Try moving different devices away from the tv, there may be some type of interference.
Hopefully it's not your TV going bad...
May 25, 2009 | Dynex DX-LCD32-09 LCD TV
Red lines on black color area
Its probably the inverter. its a device that powers lcd screen's. ebay the model # and include inverter. it will give you a ballpark number to work with
Feb 03, 2009 | Dell Inspiron 1100 Notebook
Screen appears blue
Try Moving The Speaker You Have There Away From It?
www.Myspace.com/CrossRoadsToNowhere2007
Jan 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
Black Lines
Just to reset first before proceed another procedure;
Resetting the TV
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet for 4 - 6 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards,
VOTIT
Oct 07, 2008 | Hitachi 61SWX10B 61" Rear Projection...
37in Proton
Those are the symptoms when the power supply is giving up.
Unfortunately there are not many replacement service parts around to swap the power supply assembly, but It will need to be fix to the component level instead.
I service these power supplies.
Let me know if you need more assistance.
May 02, 2008 | Protron PLTV-37 37 in. LCD Television
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Dark area on screen
If it's a circular area you might be delaing with magnetism. Check the menu and there should be a control for geomagnetic correction and adjust accordingly.
Feb 07, 2007 | Panasonic CT-34WXD65 34" TV
RCA R52WM24 52" HDTV Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
