Question about KitchenAid KSSP48QMS Side by Side Refrigerator
Whirlpool profile refridgerator model TFX25PPZ water filter prob
My fridge needed a filter change which I do every 4-6 months. This time I bought a MWF Brita instead of the smart filter that I normally buy. For whatever reason, although it fits fine, I have no water coming from the fridge. I have taken off and reinstalled it twice - still nothing. Any help?
  • 351 Answers
SOURCE: do add water ge smart water mwf cartridge
i dont believe so water will fill it, it should reconize the filter and fill it... i believe i may be wrong but that is how it usually is.... did it come with instructions?
Posted on Apr 19, 2009
jumptrout51
  • 3361 Answers
SOURCE: Water Filter Output
Let me know what happens.
Posted on May 13, 2009
Maytag317
  • 1136 Answers
SOURCE: water not working but ice does - kitchen aid superba
When you activate the switch, do you hear the inlet valve buzzing? If you do, check the container or tubing in the fresh food side and make sure it is not frozen. If you do not hear the valve buzzing, chech the valve. If it appears to be ok, then you will need to check the switch inside the door control panel.
Please let me know if I can help further.
Thanks
Vic
Posted on May 20, 2009
  • 3600 Answers
SOURCE: top of water filter broken off
use a pair of plyers in you can grab it on the outside if it's in the inside get a small pair of vive grips and try to get a bite on the plastic and turn it couter clock wise to remove.
Posted on Aug 21, 2009
  • 1218 Answers
SOURCE: I purchased a Kitchenaid Refridgerator 6 months
If you purchased this machine NEW 6 months ago, everything on it is under warranty. You should contact the selling dealer to verify you are entitled to a free service call. Changing the filter is routine maintenance and in no way should affect the warranty.
Posted on Oct 25, 2009
I just changed the water filter on my whirlpool refridgerator and got the message off the door. Now neither the ice maker or water dispenser will work.
Possibly the filter is not in all the way or maybe it has a clear sticker/seal over the middle hole. Most filters need pushed in slightly while turning about a 1/4 to 1/2 turn. If it worked before the filter change it has to be in that area.
Apr 14, 2015 | Whirlpool Refrigerators
Whirlpool refridgerator ice machine mod.ED2PHE water will not come into ice machine. it was working fine until 2 days ago.
check water line is open, check filter seated properly,make sure of on/off lever or switch or turn off water supply to fridge and check line for possible clog, and also on filter
Jan 24, 2013 | Whirlpool Refrigerators
Amana green water filter light off
If your machine is only 2 months old and wasn't used when you bought it call the number on the label that has the model and serial number on it that is located either inside the refridgerator on the upper wall somewhere or somewhere on the frame. Being that whirlpool now owns Maytag, which encompasses Amana, you have a one year manufacturer warranty where parts and labor are both covered free of cost.
Apr 27, 2012 | Amana 22.6 cu. ft. Side-By-Side...
We are contemplating buying a samsung fridge However we currently have a whirlpool with the water filter on it. How would we disconnect the water filter currently installed to connect a new samsung fridge?
I'm not sure I understand your question, so forgive me if I'm incorrect. I'm confused as to wether your whirlpool has an internal filter or if you have an external stand-alone unit.
I have a samsung refridgerator and the water filter is inside the fridge located at the back on the upper right. In fact, all Samsung RAF/AES models come with this internal filter. Depending on where you buy it, often times the delivery guys will set it up for free. They will simply disconnect your old fridge, remove it , reconnect the water hose to your new Samsung and be on their way.
If you choose to do it yourself, simply remove the old fridge, follow the hose to under your sink and remove the old one. Run the new house by attaching it to the appropriate place on your sink and over to the back of the fridge. Also, many modern homes have a cold water tap behind the fridge, so you might be able to connect it there if you do.
Either way, whether you have an external unit or inyernal hose
Apr 03, 2011 | Samsung Refrigerators
I cant believe i cant find the model # of this fridge but anyway , i installed a new water filter a purr #4396841 and did it according to the instructions , did everything but the red light remains, wonder...
The model # is located inside refridgerator door on the upper right side panel.To reset the light you have to open fridge door and by the light there is a button you have to push in the button 5 times in 10 seconds to reset.Hope this helps if so give us a 4 thumbs up. THANKS
Mar 03, 2011 | Whirlpool GD2SHGX Refrigerator
We have a GE Profile, sise by side refridgerator . we need to change the water filter, but can not find the filter on the machine. where is it please?
hello js... go to searspartsdirect.com
Enter the model number and you will see a full set of schematic parts diagrams for your fridge. This way you will see exactly what you have and can even order a new part if you need to. Joe
Thanks for choosing Fixya!
Dec 30, 2010 | GE GSS25LGM Side by Side Refrigerator
Low water flow after changing the water filter in a gf profile re
Just a suggestion, you could try installing a filter on the water supply line to the fridge. A nice one should dramatically lessen the frequency of replacing the one in the fridge. As for your the pressure being low, look for a kink or pinch in the water supply line.
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water filter question
WOW! I'd say that the filter is definately due for replacement.
The manufacturer recommends the filter be changed every 6-8 months, as with ice and water dispensers in the door, folks tend to use the chilled water and ice more often, hence you get alot of gallons of water thru the fridge each month.
Once you replace the filter, you'll need to flush out the lines, (see the instructions with the new filter) to get rid of any loose carbon in the filter element, but once you done this, you should also notice better water flow and better tasting water and ice cubes too.
I tend to change my ice/water filter on my fridge every year when I change my smoke detector batteries. That way, I don't forget, sort of like my personal "once-a-year" house task list to change batteries, filters, resetting timers, etc., etc.
It's a good idea to change these smaller filters at a minimum of once a year, as they are no longer providing the filtration you want, and can actually be letting some of the contaminents fow out and into your water and cubes.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | KitchenAid KSSP48QMS Side by Side...
Refridgerated water spout suddenly stopped producing water
Have you changed the water filter. It should be located in the front loer grille of the refrigerator.
Jan 10, 2009 | Refrigerators
KitchenAid KSSP48QMS Side by Side Refrigerator Logo
67 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
