Question about Refrigerators
Water accumulates and freezes at the bottom of our freezer. Once the bottom of the freezer has formed a slab of ice the water eventually drains out of front of freezer and leaves a good size puddle on our kitchen floor. We thought it was an ice maker issue and disconnected the water line to the ice maker over a month ago however, water is still coming from somewhere? Please help.
  • 10,865 Answers
Your refrig. goes through a periodic defrost cycle whereby this water is produced. It is supposed to travel down to the evaporation pan near the floor of the frig. Your evaportation pan may be clogged, remove the front lower panel and get a flashlight and examine it., or the tube leading from the freezer floor may be clogged or have ice it it. Check that out and if the opening of the tube has ice in it, melt it with a hair blow dryer
Posted on Oct 06, 2009
My fridge is leaking, water drips out once day from the left side where freezer side is.
Not sure what model you have or the age, but it could be the door gasket. It could also be the door closure at the bottom of the hinge side being worn down and not closing the door all the way. These normally last about 15 years.
Nov 02, 2017 | Refrigerators
ICE FORMS IN FREEZER BOTTOM,
Keep the bottom of your freezer free from ice. ... The water from the melted ice and frost drains through a short tube and into a pan beneath the refrigerator, where it evaporates. Should the drain line become clogged, the water has nowhere to go and it freezes, forming a layer of ice in the bottom of your freezer.
How to Fix an Iced Freezer Bottom ' Home Guides ' SF Gate
homeguides.sfgate.com/fix-iced-freezer-bottom-42777.html ICE FORMS IN FREEZER BOTTOM Google Search
Oct 23, 2017 | Refrigerators
Water accumulates and freezes on bottom of freezer.
Orange glow is defrost heater and that is normal. Crackling sound is heater heating up area around it, normal. Water and ice build up in the bottom is due to a clogged defrost drain.
Sep 01, 2012 | Refrigerators
Bottom of the freezer keeps filling up with water and freezing solid. eventually leaks thru the door onto the floor. It takes 3 to 4 weeks for it to form thick enough to eventually leak thru the door on to...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | GE GSS25JF Side by Side Refrigerator
I have an 8 year old GE Profile Side by Side TPX24PB Refrig that is leaking water in the freezer, but not the refrigerator. There is a slab of ice on the freezer floor, eventually water runs onto the...
The drain is clogged. Remove the bottom bin out of the freezer. Once done you should see a trough at the back. This trough will be filled with ice, remvoe the ice. Then you have to clear the drain. The best way I know of to do this is to force hot water down the drain with a turkey baser untill water flows freely. Then mix baken soda with water and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Sep 24, 2010 | GE Profile TPX24PBDCC Side by Side...
Water is accumulating and freezing on the bottom of the freezer
YOUR DEFROST DRAIN IS PLUGGED, YOU NEED TO REMOVE THEBACK PANNEL THE DE-ICE THE BOTTOM TRAY TO FIND A HOLE, YOU NEED TO CLEAN IT OUT UNTIL YOU CAN RUN WATER THROUGH IT.
Apr 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Layer of ice formed on the bottom of freezer and a layer of water with no obvious source has formed on the top shelf on the right side.
That is an easy one. Instead of the defrost liquid draining down the drain hole it is blocked and a slab of ice is forming. You must thaw out the ice box and clear the drain hole. Another thing that could cause this slab of ice could be a leaky ice maker water valve or a faulty ice maker pumping in too much liquid into the ice mold.
Jan 15, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Ice forming on bottom of freezer section
The freezer should have a drain hole for the defrost water to flow through. This will drain into a pan outside of the freezer cabinet. If this drain tube becomes blocked it will not allow the water to drain out and it will accumulate in the bottom of the freezer section. You will have to verify that the drain is clear through to the drain pan. this can be done carefully with a piece of stiff wire. There should also be some sort of a water trap on the drain tube to prevent air from entering the freezer compartment through the drain tube.
Mar 09, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
613 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
