Question about Epson PowerLite 53c Multimedia Projector
Epson powerlte 53c no image coming out
Lamp was changed (tried to 2 new lamps), but there is still no light coming out of the projector. No problem lights either. What could be the problem and how can i fix it. Should i open it and try to fix, where would i start if its optical problem?
  • 682 Answers
Please confirm that lamp cover is closed firmly and safety switch is connected and proper actution(make good contact when cover is closed).otherwise it will shut down the lamp.
Posted on Mar 14, 2008
Projected image too small
Did you replace the lamp with the EXACT type that was in the projector prior to changing it? Sounds like there is difference in lamps.
Feb 26, 2014 | Epson ELPLP42 PowerLite 280 Lamp
Origional Epson 3010 bulb burned out after 2 years. New bulb died in a month
our company supply the Original lamp ,unit price is USD200
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Dec 08, 2013 | LC EPSON ELPLP68 / V13H010L68 Projector...
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Jan 02, 2013 | Epson ELPLP41 EB S6 Lamp
Epson Powerlite 830p lamp light comes on and turns off projector with new bulb.
Clean the fans and filters. Check the lamp door switch is making contact.
Jan 27, 2018 | Epson PowerLite 830p Multimedia Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
My EPSON EX70 flashes green when turned on then
the lamp may not be striking. check the lamp for bulges and/or black spots inside. if there are, replace the lamp. if the lamp is ok, replace the ballast.
Nov 29, 2009 | Epson EX70 LCD Projector
Eiki LC-XG110 lamp going off
Lamp is near end of life. Try reseting lamp timer and order new lamp if unit stays on
May 13, 2009 | Eiki LC-XG110 Multimedia Projector
Epson ELP 3000 clicking noise and all lights flashing
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 26, 2009 | Epson (1023661) Projector Lamp for...
Projector lamp flashes and the temp red led lights.
Purchased our76C in Jan, 2007. It is our second unit now that has had the same symptoms. When the unit starts up, the Power light is steady green as normal for a few minutes, but no image is projected. After a few minutes the lights do as you described. Both times Epson support authorized a new unit to be shipped out immediately. They said they had no known issues about it and didn't indicate what was causing the problem. Apparently it is not just the lamp wither. Also, the lamps both had under 20 hours on them.
Jun 17, 2007 | Epson PowerLite 7500 Multimedia Projector
Epson PowerLite 53c Multimedia Projector Logo
120 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
