Question about Nikon COOLPIX S200 Digital Camera
LCD screen is white. Doesn't display what you are aiming at. Takes photos.
My screen has gone white?
The display being white can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the images/picture is seen to be of good quality, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Please click on the link for tips to replace a LCD
http://www.youtube.com/watch?v=aB4x7F5Chow
Dec 14, 2011 | Nikon COOLPIX L20 Digital Camera
My wife dropped her DMC-Z53. Still takes great photos but their is no display as the screen is white with some vertical lines. Can it be fixed or get a new one?
Seems lcd screen got damage that is why not showing image, lcd screen replacement would cost approx new camera price so better option is to buy new camera.
Hope this will help.
Thanks.
Apr 10, 2011 | Panasonic Lumix DMC-FS3 Digital Camera
Hi, I have a camera, a Sanyo VPC-T1060 and it's having some problems. It turns on, flashes, takes photos apparently, but the LCD screen won't work. It turns white when I turn it on and when I take a photo...
Try to remove the memory card if used, and blowing out the connectors in the camera cavity with compressed air (to remove dust if any).
Make sure the contacts are clean. If necessary try another memory card.
I'm not sure about the lcd screen, except it may require service from sanyo.com.
http://us.sanyo.com/Customer-Support-Service-Center-Locator
Aug 14, 2010 | Sanyo VPC-T1060 Digital Camera
No picture on view finder
you need to request to replace your lcd unit to the service center.there's no chance to repair LCD.
Jun 03, 2010 | Olympus FE-280 Digital Camera
Wont show image in the lcd display while taking photo?
Can you more clearly what you mean "while taking photo"?If lcd not display image...is that any text or symbol in the lcd?If you can still see the symbol or text in the lcd, I think you have trouble in your lens or ccd.
Trouble in the lens usually make the lcd display white screen. And, if ccd trouble the lcd display white horisontal line and if so hard broken the lcd display black screen, but the symbol or text is shown.
Sep 20, 2009 | Canon PowerShot A75 Digital Camera
Screenon my camera is all white but i can still take photos
Try leaving the battery out of it for up to 24 hours, let it fully reset, then try again.  If it still doesn't work, it sounds like the mainboard could be bad - is it still under factory warranty?
May 27, 2009 | Fuji FinePix Z5fd Digital Camera
HP R717
The LCD is not working and may need to be replaced.
Nov 12, 2008 | HP Photosmart R717 Digital Camera
LCD screen flashing
Hi!
This is a feature and not a defect of the K100D. You can turn this off by going to the menu and going into the second tab (playback menu). Once there, go to preview display, where you will have 3 options - off, histogram and brighten areas. Set this to off (your camera is set to brighten areas, that is why the white parts of your photos appear to be blinking).
Hope this helps!
Oct 27, 2008 | Pentax K100D Digital Camera
Finepixz20 digital camera
That is actually the exact same thing I am experiencing but mine has grey lines on the display window. I was able to take photos to a grey screen connect it to my comp...low and behold my pics showed....I am furious....need some answers as I will never hear the end of it from my daughter.
Grrrrr
weelassy
Oct 20, 2008 | Fuji FinePix Z10fd Digital Camera
White Screen
I have Fuji FinePix 2650 Digital camera with same problem. I can almost guarantee this is not a firmware problem. I went mountain biking a few months ago and take pictures. I take out camera and turn on. I get lines then white screen. I banged on camera and fixed it. Later a few weeks ago I turn it on and white screen. i beat this thing and get bad menu selection screen for a moment then white again. It takes pictures well and talk to computer no problem but no LCD picture. I thinking it is loose connection for LCD. Send it for repair or if you seek adventure try to fix it yourself!
Nov 12, 2006 | Fuji FinePix S5000 Digital Camera
Nikon COOLPIX S200 Digital Camera Logo
35 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
