Question about Video Game Consoles & Games
Remotes light up and do not control game
Controls light up at bottom and do not control game
    President:
  • 787 Answers
Try to open the Wii front cover and push the red button there.Then open the batteries cover on Wii Remote and press the red button there.If the controls not connected and still not work may you have a problem with a bluetooth device in your Wii and it need service.
Posted on Oct 09, 2009
Remotes won't connect. put in new batteries, tried pressing red button in side remotes, all 4 blue lights are flashing on both remotes
Hello kellyanne_ma,
The Wii must be searching for remotes before one will connect. If you are trying to connect controller #1 (meaning there are none connected) and it fails, there may be a problem with your Wii.
First, remove power from the Wii by unplugging it. Wait 30 seconds and then plug it back in. Once powered on and you see the health/safety information press and hold the red SYNC button on your Wii for 20 seconds.
Now press the Sync button on the controller and while the blue lights are flashing, press the Sync button on the Wii.
Hopefully, that will connect the controller! If it does not, you may need to contact Nintendo!
Jun 28, 2011 | Nintendo Wii Console
We have a Nintendo Wii and no the remote controls aren't working with the console. Ihave tried replacing batteries. Do I need new remote controls or a new charger for the controls?
If your remotes are showing power lights at the bottom when you press buttons, then you may have a problem with the sensor bar that receives signals from the remotes.
First, try unplugging and plugging back in the sensor bar to the Wii. If it still doesn't work, the next step would be to replace the sensor bar. You can find them just about anywhere you buy Wii accessories and they are fairly cheap.
Mar 02, 2011 | Nintendo Wii Console
Wii powers on..at start up screen press a to continue wii controllers/wii does nothing..batteries are all new in controllers..
Are your controllers sync'd with the Wii? In another words, on the bottom of the Wii Controllers are 4 blue lights. Is one of those four lights illuminated? If not, it will not know that you're pressing it -- you will have to sync the wii remotes.
Aug 06, 2010 | Nintendo Wii Console
Wii Controllers not causing anything to happen.
OK so do led lights on the on the bottom of the controller just keep blinking or ever light up under "1" to signify that it is connected? What you do if they keep blinking is take off the battery cover on the remote and press the red button and the red button under the sd card cover at the same time. This syncs the wii remote with the console. You will need to do this with all new wii remotes.
Jan 11, 2010 | Nintendo Wii Console
Wii controllers not working, new batteries, but will not move on screen...
You need to synchronise the remotes. Take off the battery covers on the wii remotes and open up the flap on the front of the wii where you can put a memory card in. Press the red button that is above the memory card slot and at the same time press the red button that is above where the batteries go on each remote. The wii remotes should flash and eventually give a solid light on either the first or second led at the bottom of the wii remotes. When this happens both remotes are synced.
Dec 29, 2009 | Nintendo Wii Console
Wii remotes blinks several times but doesn't work.
you see the little flap on the wii open it and the back of the wii remote then press both red buttons and wala good as new
Jul 21, 2009 | Nintendo Wii Console
Two remotes do not work on some games
I would try reconnecting the controler that is the problem to the wii. There should be a button y ou can hit on the front of the wii that is inside of a little door. It is a red button. Right after hitting that there should be a button on the wiimote's bottom, it the battery area. The lights should blink a while and it should finally connect.
Feb 12, 2009 | Nintendo Wii Console
Problems with a Wii game
if you are in the mulitplayer mode and still have trouble adding the remote then try syncing the remote with the wii first by pressing the home button then go into the wii remote settings on the bottom then re-sync each control. Then try going back into mulitplayer mode and try again or while the screen is on when you want to add more players press the '+' button.
Dec 28, 2008 | Video Game Consoles & Games
Hand control
is your sensor bar hooked up? is it visible where the remotes can sense the remotes?
Aug 02, 2008 | Nintendo Wii Console
Wii controllers
Sounds like the remotes aren't sync'd up with the Wii in a way to turn it on. I had a strange occurrence with ours where only 1 Wiimote (ha!) out of 4 would turn on the Wii with the power button. Try following the instructions to program the Wii to the Wiimotes again and see if that works. Also try holding the power button on the remotes a little bit longer.
I don't recall but you push the red button behind a hidden cover on the front of the Wii and then the button on the Wii controller behind the battery cover.
Dec 31, 2007 | Nintendo Wii Console
Video Game Consoles & Games Logo
66 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
