Question about Garden
112L - steering not working correctly. When the wheels are on the ground and you turn the steering wheel, the entire front axle turns, not just the steering links. The axle swings on the single pin in the center, and it looks like something in there is worn. Also - when you set the tractor back down so the weight is on the wheels, the axle angles backward and moves FORWARD. Can the pin that the front axle on be that worn?
    Sergeant:
  • 302 Answers
It sure can be. I once was mowing and had the whole front axle come off and I almost ran over it.
Posted on Oct 06, 2009
Noise from right front tire
jack up front left on level ground ,support and chock rear wheels and set park brake ---look and check the cv axle for leaks,tears or damage -put in neutral and watch axle should turn smoothly turn steering wheel to left and rotate tire again watching axle if their is binding or grinding or studder movement than axle is damaged and needs to be replaced
Apr 08, 2014 | 2005 Ford Freestar
Power steering issues
I'm going to agree with the rack conclusion. Keep in mind I can't see it for myself.
If you take the load off the front wheels, you should be able to turn the steering wheel without effort.
If the effort changes while turning the wheel, the only things affected would be the rack and the column.
If you notice it turns ok with the engine off but not with the engine running, it could be something with the pump or one of the lines, or still something with the rack.
Jul 05, 2012 | 2004 Ford Freestar
What is the foot pounds for the front wheel bearings on a 1995 chrysler cirrus
Hello, If you Chrysler has replaceable wheel bearings and seal. This is the way it goes---pack the wheel bearing with new grease-install the bearing in the wheel nub--install new back wheel seal--coat the axle shaft with grease lightly, thing coat-----install wheel hub on to axle shaft...be careful here don't damage the rear hub seal------------insert front race washer---install axle shaft nut--tighten nut down wheel nut until it is firm with water pump pliers----spin the hub/with tire mounted.
(the wheel and hub will turn but not freely)----take the pliers and back off the axle nut 1/4 turn----now spin the wheel and axle hub, it should spin freely---now if doesn't spin freely---back off the axle nut about 1/16 or 1/32 (or just a little bit)-----now, spin the wheel and hub and if turn freely------------Now grab the top of the wheel/tire and move it back and forth.-----if there is some movement ---try tighten the axle nut just a little little bit, unit the one can barely feel some little movement in the wheel/tire and hub.-----------Now, spin the wheel/tire and hub and it should also turn freely.
If it does----install new and correct size of cotter pin and bent the ends around the axle nut.----
coat the inside of the hub cup with grease. Now, use an rubber or plastic hammer to install the cup on the wheel/tire hub. You are finished with one wheel bearing maintenance. Now do the other side.
I really don't know if you Chrysler Cirrus has replaceable wheel bearing. All the auto/trucks have replaceable hubs, that means that the replacement is total hub with axle shaft, sealed bearings, and seals. This is bolt to each wheel steering hub. This work to remove these one unit hubs.
Four bolts hold the axle hub to the steering hub. Hear is the problem!! it has rusted to the steering hub. Also, these hubs cost more than replacing bearings, races, seals to cool turn of $180 to $250+ I wish you luck in your replacement of wheel bearing on your Chrysler. GB..stewbison
Sep 24, 2011 | Chrysler Cirrus Cars & Trucks
Transfer case on 2006 F150 will engage but no power to front wheels?
SOUNDS LIKE A BAD HUB TRY THIS TO DIAGNOSE THE PROBLEM
Put the transmission in park, set the parking brake and raise the chassis so one of the front wheels is off the ground while the other is still on the ground. When the transfer case is in two-wheel drive, the hubs should be released allowing the wheels to turn freely when spun by hand. If the axle shaft turns when you spin the wheel, it means the hub has not disengaged.
To check engagement, rotate the axle shaft backwards. This should lock the hub. Try turning the wheel by hand again. The axle shaft should now turn with the wheel if the hub is locked. If the hub fails to lock, the hub will have to be disassembled and inspected or replaced.
To check release, hold the axle shaft steady and rotate the wheel backwards. You should hear a click as the locking mechanism slides back out and disengages the hub. Rotate the wheel forward again and it should turn freely.
Another way to check the hubs is to raise the vehicle on a frame contact lift so all four wheels are off the ground. Then start the engine and place the transfer case in four-wheel drive and the transmission in drive. If the front wheels don't turn, look at the front axle shafts. If both shafts are turning, but one wheel is not, the problem is a bad hub on the wheel that isn't turning. If the front driveshafts are not turning when the transfer case is in four-wheel drive, the problem is inside the differential (broken side gears) or the transfer case (broken chain, shift linkage, etc.). If the driveshaft between the transfer case and differential is turning, the problem is in the differential. If the driveshaft is not turning, the vehicle is going to need repairs to the transfer case.
Hope this helps.
Dec 28, 2010 | 2006 Ford F-150
Acar using ackerman steering gear ha a wheel base of 2.8m and a track of 1.5m .The track rod is 1.2m and each track arm is 150mm long .The distance between the pivots of font stub axels is 1.25m.If the car...
easy this one all wheels turn through a central point of a line from the rear axle which is projected alongside the vehicle and iam not doing maths at this time of night after a hard days work then being nagged when i get home for coming on here ,its just basic trigernomitry . I studied this 40 yrs ago and passed with distinction on my technicians exam so if i could do it then so can you i had no internet in my time just black and white TV with 3 channels and 4 track car tape players were not even out then ,OK how do you set up the front steering wheels on a 4 axle vehicle like cement mixer or bulk carrier with the two front axles turning ,or remetal a big end bearing with white metal or set up rod brakes with the correct angle in relation to the centre line of pull ?? what about setting up a clutch pressure plate ??
Dec 13, 2010 | Hyundai Accent Cars & Trucks
The steering wheel starts to shake when I make slow sharp turns. Usually when parking or in aparking lot. Power steering fluid level is fine and fluid doesn't look dirty. Suggestions?
a steering wheel shake with the wheel fully turned usually indicates a seizing constant velocity joint (axle). it can also be accompanied by a clicking noise while turning at higher speed. this is easy to confirm. raise and support the front of the vehicle and put in neutral. turn the wheels by hand with steering wheel pointed straight ahead. there should be minimal resistance. then try rotating the wheels with the steering wheel turned all the way to one side then the other. if you feel any extra tightness or binding, you indeed have a seizing joint. if the axles look ok visibly, you will need to remove the axles to confirm which side is the problem. good luck!
May 25, 2010 | 2006 Honda Element
Put new power steering pump on 92 bronco ,flushed 2 quarts through system, still milky and still does not work ?
the milky colar is caused by air in the system. this takes a little to get out and will cause your power steering nt to work correctly.jack the front axle off the ground then start. turn the steering wheel slowly fom right lock to left lock. check fluid in resevior top of if needed and repeat. this might take a while, but it will get the air out.
Mar 07, 2010 | 1992 Ford Bronco
Creaking sound while turning steering wheel
i'll bet this is a front wheel drive or four wheel drive. when the front wheels are tied to the drive train. the front axle shafts bearings can go kaput. jack up the vehicle and turn the steering wheel all the way to one side and spin one tire at a time by hand. you are bound to hear snaping and cracking coming from the axle shafts.
Dec 12, 2009 | 2000 Jeep Grand Cherokee
I crashed and need to straighten the steering. The front wheel is turning to the left. How do I re-align the handlebars and front wheel?
First, support the bike so that the front wheel is off the ground. Then, loosen (do not remove, just loosen them) the bolts that clamp the fork tubes into the upper and lower triple clamp braces. Loosen the front axle attachments to the fork legs. Now stand in front of the bike and hold the front wheel between your knees and turn the handlebars until they are straight - and re-tighten everything. Also, check the large nut on top of the steering stem, making sure it is tight.
Dec 11, 2009 | 2004 Yamaha YZ 250
Front End noise and vibration
Check the U-joints and axle baerings. But its most likely because the truck is in four wheel drive.
Aug 16, 2008 | 2002 Ford F350 Super Duty DRW Reg. Cab
Garden Logo
117 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
