Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Hot Tub Blower trips breaker
Acquired a 12 year old Hercules Caliante 6-man hot tub. The electrician hooked it up and the breaker tripped. They figured it was the fine mist blower. So I bought a new blower and the new blower still trips the breaker. The blower cord just plugs into the control box with a 4-prong amp plug. It is a Balboa DLX240 control box. I replaced the 10a time delay fuse and that didn't work. All wiring matches the schematic and all wiring looks good. Could it possibly be the (relay) switch for the blower??? I need a low cost solution besides not using the pump. Replacing the board is not an option right now.
    Top Expert:
  • Dream Maker ... Master
  • 6,465 Answers
Bad blower motor
Posted on Sep 20, 2017
4 Suggested Answers
  • 990 Answers
SOURCE: My electric went out for 24 hours. I hooked up my
You should start with checking all your breakers to be sure the breaker did not pop just half of your breaker. This is something you should do with all your breakers. When you do this you should shut down all your 220v breakers so you don't get bleed back through the system. Other than that you need to look for resets on the tub. The heater is a good place to start and don't forget the gfci's on the tub or in the bath or laundry room.
Posted on Dec 16, 2009
Coastsider
  • 331 Answers
SOURCE: My hot tub keeps tripping the breaker and will
Check for a water leak in the electrical areas of your spa... specifically look closely around the heater terminals, look for wet and corroded connections... If this spa is wired to a plug-in outlet, look at the GFCI plug assembly as well... You can also try disconnecting the blower, pump, heater, etc, from the control pack (one at a time) to determine which item is causing the tripping.
Posted on Apr 14, 2010
john224
  • 1378 Answers
SOURCE: breaker on the end of
I have had a few troublesome units over the year that did as you describe due to 'dew' overnight collecting around the tub and the increased moiture sent the motor of the circ pump "over the edge" iinto a grounded state. A leaking pump seal was adding to the problem. Once the seal leak along with the dew got high enough the GFI would sense the grounded condition and trip. Fixing the pump seal and drying/cleaning the motor fixed the problem every time. If you find any other leak sources around the pump you will need to fix them as well.
Posted on Oct 12, 2010
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ehottubsandpools.com/?p=320
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 | Pool & Spa
Hot tub breaker trips but only when people are in it?
Because it is a GFCI. Try making sure that the grounds are all good. Maybe go the extra step of putting in grounding rods into the ground and grounding to the unit. These are just guesses.
Nov 17, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Power trips out when jets are switched on
I'm going on somewhat limited information here not knowing if the tub is newly installed or if this is a spa that has been working in the past and just started doing this. It would be helpful to know if this is a recently installed pump as well. That said here are a few things to check.
If it's a new install: Your electrician has more than likely wired the spa incorrectly. Be sure that the spa pack has 220V going into the pack and that the GFCI is wired correctly.
If it's an old spa with a new problem: A lot of times a bad heater element can cause a spa to trip the breaker. If you have a bad element the spa will operate normally for about a minute when you turn the power on, then trip the breaker as soon as the heater kicks in.
If it only trips the breaker when the pump is turned on to high speed, more than likely there is a problem with the wiring of the pump or the relay on the pump itself.
May 04, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Oct 02, 2012 | Electrical Supplies
Why is my 50 amp GFIC breaker tripping out? I have just installed a new hot tube.I had one there before(smaller 40 amp) so there was already #8 wire there.The new hot tub requires a 50 amp. #6 wire. I just...
There might be a few things here:
1) Big problem >> the #8 wire is a fire hazard connected to a 50Amp breaker
#8 is a 40 amp breaker
#6 is a 55 amp breaker
We put #6 on a 60 amp breaker
Are you saying you hooked the #8 wire to the new 50 amp breaker, and the hot tub called for #6 wire?
Upsize your wire and breaker to meet code
http://waterheatertimer.org/pdf/Wire-size-amp-rating.pdf
2) After putting the correct wire and breaker, you can still have a short in the circuit somewhere
We used to set equipment out in the field in early morning >> the grass was wet >> our equipment was fine, but the tiniest short would cause the GFCI to trip
I don't know where the problem is without a thorough checkout of every possible grounded surface. You need a good multi-meter
3) You better get an electrician over there to have a look before the place burns down or somebody wakes up dead in the hot water.
If I sound a bit scary here, it's because something doesn't sound right with your installation.
Oct 19, 2010 | Inline 60 Amp Circuit Breaker
My breaker is conected to a hot tub. tub was working fine in auto mode. Turned on jets and breaker tripped. will not reset can you help me
I am assuming this is a GFCI circuit breaker? If it is it will have a "test" button on the breaker. When you say "jets" i'm assuming you mean when you turn on the blower to make the air bubbles? It could be you have a problem with the blower motor. When you start the blower, it trips the breaker. Be sure the blower is in off position when you reset the breaker. The most common fault though on a spa/hot tub is with the heater. If the element goes bad, and current flows to ground, it will trip the GFCI breaker. Again try and turn all functions off. Reset breaker, and then turn on one at a time till the breaker trips. First the pump, then the heat, then the blower.
Oct 06, 2010 | Square D Trilliant 40 Amp Circuit Breaker...
The hottub keeps kicking the circuit breaker off.
Either the breaker is bad or you have an electrical problem. Unless you know how to work with electrical problems call for service. If you unplug the hot tub and plug a lamp or hair dryer into the outlet does the breaker trip? If yes, call an electrician. If the outlet is fine call for service on the hot tub.
May 01, 2010 | Home
My hot tub still trips the breaker,and i replaced it with a new gfci. What other things can i ck.
If your hot tub is pulling more amps than amps sent your breaker box, you'll keep tripping the breaker. Check the rating on the hot tub and compare that to the breaker rating. You may need to uograde the wireing. Make sure the wire gauge is up to code.
Mar 21, 2010 | Balboa Instruments Duplex Digital Panel 2...
My hot tub keeps tripping the breaker and will only stay on for a short period of time before tripping the breaker. What can I do?
Dec 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
373 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
