For the past week, when my Sceptre LCD monitor goes to sleep after inactivity, it won't restart immediately. The blue LED blinks every second or so; eventually, the screen begins to flash the display, and then a few minutes after that, will finally turn on. Sometimes the whole process takes five minutes, sometimes an hour. How can I fix this problem? (I can't find the documentation to say exactly what model this is; if that's important, I can look again.)
    Sergeant:
    Novelist:
  • 183 Answers
Hello there Jake.
Here's your geek-steer ...
== CLARIFICATION ==
  • When you say "sleep", are you certain it's sleep mode, as opposed to hibernate?
  • "...it won't restart immediately." ... you do mean of course AFTER you've given keyboard or mouse input, right?
  • "...the screen begins to flash the display" ... literally flash, as in strobe? Or do you just mean flash, as in "shows".
  • "...Sometimes the whole process takes five minutes, sometimes an hour." ... ???!!! If it takes anything longer than few/several moments, that's very abnormal, even if hibernate mode.
  • "...I can't find the documentation." ... not important, at least not at this point.
== SUGGESTIONS ==
A. RULE OUT THE SIMPLE FIRST.
1. Shutdown
2. Turn off PC and monitor
3. wait 5 minutes
4. unplug all cables/cords connected to monitor (both ends)
5. inspect/clean connect points
6. reconnect all cables/cords
7. plug monitor back in
8. startup system
9. try to duplicate problem
B. CPU HOG.
I'm curious to know what all your "Processes" are doing during this very delayed period of time. By knowing that, you can see which one(s) are running, and which of them are probably crunching hard at the CPU, which MAY explain the delay (I don't know about an hour, but minutes ... yes).
Do you have a "Processes" monitor utility of any kind? If not, get SysInternals' "Process Explorer" (no installation required, just unpack and launch). Make sure at least the "CPU History" item is included in the column header (View > Select Columns). Once launched, allow it to sleep.
Just as soon as able, after it comes out of sleep, review Process Explorer. What, if any, processes are hogging CPU? Post that back, and I suspect we may be a lot closer to a solution.
C. MONITOR FAILURE.
You might also hook up this monitor to a "known good" (functioning properly) PC with like "screen saver" and "power options" settings. If problem not encountered, you can at least isolate the problem to solely the monitor. However, if the only time you encounter problem with monitor is isolated to when coming out of sleep, this is likely a long-shot.
Good luck Jake, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback.
  • if you have any further questions,
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Posted on Oct 06, 2009
  • Craig The Geekinator
    Craig The Geekinator Oct 06, 2009
    @ Jake
    I very much appreciate you taking the time to reply and providing a rating as to how well you feel I answered your question. However, being the perfectionist that I am, and always striving to meet (or exceed) every expectation, I'm curious to know what the results were in performing each of my suggested actions ... particularly the CPU query.
    As this was by necessity a "ready-fire-aim" approach at determining the cause, if you could post back with those those results, it very likely could aim to your solution.
    Look forward to hearing from you. Thanks once again.
    "Today's the best day of my life...and NOW you're part of it!"
    Via con Dios and Godspeed ... Geekinator (aka Craig).
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Monitor worked fine for years, then permanent standby
hey
usually this happens due to static try to power cycle the monitor by disconnecting all the cables from the monitors
then connect teh cables back one by one
and see if it works and if not yes get teh monitor replaced
Sep 18, 2009 | Sceptre x22wg Gamer Monitor
Sceptre 20" Monitor will not stay on
First check the monitor sleep mode for your monitor in windows control panel, check that its not going into hibernation/stanby. if thats not it. and the monitor keeps shutting down. You may have to replace it newer models have more features and could be cheaper by saving you the hassel check newegg.com or orverstock.com
Jul 08, 2009 | Sceptre X7GNAGAV 17" LCD Monitor
The monitor turns black immediately after power cycle
i think it can be the capacitor problem, open monitor an look for swollen capacitors. if you will find them swollen or mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:IT;} @page Section1 {size:8.5in 11.0in; margin:56.7pt 42.5pt 56.7pt 85.05pt; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} loosing the electrolyte, signs of burn, change them
Apr 12, 2009 | LG 22" FLATRON LCD Monitor
I have a 20 sceptre widescreen lcd monitor
Have you tried any other monitor connected to your computer since your current problem? Check your connections, make sure your VGA cable/DVI cable are in good condition. If none of that works try to RMA it to sceptre if your still within the 1 year period.
Apr 07, 2009 | Sceptre X20g-Naga III 20.1" LCD Monitor
I have a sceptre x9g-naga III
Not an expert, but from what Ive read, this is a cfl inverter issue. I had the same problem on my Sceptre. Good luck finding parts. My solution: get another monitor.
Feb 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Monitor has a hard time starting up
replace the "keyboard board" and the "power inverter board" (both boards)....
Oct 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Sceptre 17" Naga monitor
try another monitor on your pc. I suspect bad video source.
Jun 09, 2007 | Sceptre X7G-Naga 17" LCD Monitor
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
