Question about Espresso RMI La Cimbali Espresso Machine
I have a cimbali m29 selectron i have no power
I have a cimbali m29 selectron i have no power to my left group solenoid.everything else woorks and if i take my no 2 group wires and hook them to the no 1 solenoid it works any ideas.
    Problem Solver:
  • 6 Answers
Sounds like a frozen solenoid valve, take apart and clean or replace(24Vac)
Posted on Mar 27, 2012
    President:
  • 1,618 Answers
Sounds like the problem is in the keypad.
Posted on Oct 07, 2009
How do I get a operating manual for La Cimbali M49
http://www.manualsdrive.com/captching.php?lang=en&search=LA+CIMBALI+M29+SERVICE+USERS+GUIDE#.VOaFM5N_vbx
Aug 01, 2014 | Gaggia Expresso Machine
M29 wiring diagram
M29 is a semi automatic machine. Wiring is straight forward with the normal variance for single phase and 3 phase. Sorry i don't have a digitized diagram on hand. Maybe later. Dosing, is done with the control board which will need replacement if its not working.
youtube; ukeboy57
Mar 14, 2014 | Espresso RMI La Cimbali Espresso Machine
La Cimbali Espresso Machine: How do you calibrate the dosing for a Cimbali M29 ...
Press and hold any Group stop button until beeping, then all the button will copy what you press. Hit any stop button to leave program.
May 18, 2010 | Espresso RMI La Cimbali Espresso Machine
How do you calibrate the dosing of the La Cimbali M29 Select?
should be the same method unless the stop button needs replacement. The stop button is one of the most often used (abused) buttons and frequently needs replacement.
ukeboy57
Mar 26, 2010 | Espresso RMI La Cimbali Espresso Machine
WANT TO BUY A SECOND HAND M29 SELECTRON 2 GROUP- LA CIMBALI
The price for the m29 select new is about 5500 to 6000. So for one of 4-5 years you can give about 2500-3000. However I sugest to open the machine and check if their are rusting points or any leaking points which propably be white points from calcium color. Also ask if their were any water filter like everpure or and a water softener conected to water supply of machine during the operation of the machines.
If you see minor points as above and the water was treated before entering the machine then your machine can work for minimum another 10 years.
Water calcium (scale) is the biger enemy of the machine.
Good Luck
Mar 10, 2010 | Espresso RMI La Cimbali Espresso Machine
Can you turn off one of the left or right sides on a La Cimbali m29 Espresso machine?
1-Cover the buttons on offending side (paper and 1 min to do)
2-Reprogram one side to give it a short dose. (5 mins to do)
3-remove power to group valve (screwdriver and 20 mins to do)
Note if you do remove the power, please leave a note for the crew as they will probably call a technician in to 'repair' it again.
Aug 19, 2009 | Espresso RMI La Cimbali Espresso Machine
Problem with Cimbali M29 steaming wands
Check the water level, if you remove the top panel you will notice that the steam valve are connected at different heights on the boiler. If the machine has the silver probe remove it and clean.
Aug 04, 2009 | Coffee Makers & Espresso Machines
La cimbali m28 selectron manual could anyone tell me where to buy or down load one
This is for you....I hope this M29 will do what you need...I called he Cimbali 1-800 number and this is all they had...I tried...been working on this one for about an hour...found one in Russian....Italian...Spanish....but when I translated them and tried to paste them they came in both languages and intermingled somehow....wierd....but here you go ....I hope this helps...good luck and thanks for rating my effort....The Fang
P.S. any probs...call 1-800-724-6225 and speak to Trish. Thats 1-800-Cimbali. Take Care
May 19, 2009 | Espresso RMI La Cimbali Espresso Machine
Cimbali M29 Select
Remove the 3 screws on the side of the bell they might be bolts or allen wrench screws. That will give you easier access to the screen and screw(make sure you have extra screen and screws).
Aug 18, 2008 | Espresso RMI La Cimbali Espresso Machine
La Cimbali M29 Select - No power
sometimes italians use brown colour for neutral, please check it. if it is so than the problem is solved
Mar 19, 2008 | Espresso RMI La Cimbali Espresso Machine
Espresso RMI La Cimbali Espresso Machine Logo
382 people viewed this question
Top Espresso RMI Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Espresso RMI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
