Question about Samsung CLP 300 Laser Printer
Black Toner supply error code- when i print i get this code- i do turn off and print again and it print a few pages then same error code happens
  • 217 Answers
Replace black toner cartridge (ususal problem for this model)
Posted on Oct 06, 2009
Getting a black line on paper when printer warms up...
Black lines on copy come from toner cartridge, or drum unit, or fuser unit which is in the back. check drum and see if you can see line, back of machine with flash light you may be able to see line on fuser roller. Be carefull Fuser is hot.
A copy that is good and then starts to get lines usually the drum unit...
Mar 26, 2017 | Brother MFC-9840CDW Laser Printer
How do i override an empty color cartridge so that I can atleast print in black?
There is an error in the control logic of the printer that you can exploit like this:
  1. Start printing your document, you will receive the error message "missing toner"
  2. open the front door and close it again, this will reinitialize the test cycle
  3. the printer will now print one page before verifying the toner content again
  4. after one page you get the"toner empty" message again. Reopen the door and close it again to print another page.
This is only an emergency workaround if you really need to print something black urgently, in the long run you still have to buy a new toner.
Apr 15, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Hi when printing black or grey outside edges
sounds like your black toner cartridge is getting low or not filled evenly. To fix this until it get a bit lower on toner just take the cartridge out and holding it up right give it a few shakes side to side. The will spread the toner power out inside and you should be printing normally again.
This can also happen if you moved or bumped the printer. Usually you only see this when the toner is low or after you print a lot of pages. Most text is in the mid of the paper so thats where the toner get s used the most.
Oct 23, 2009 | Samsung CLP-350N Laser Printer
Black Toner Supply Error
you can refix this toner after shaking.
Sep 02, 2009 | Samsung CLX 3160fn All-In-One Printer
When we print manually the whole page comes out completly black.
edithvenzor:
Try replacing the toner cartridge first, then proceed with the other items.
Thank you and let me know what happens:
Binary Bob
Problem
Cause
Solution
How common*
Comments
BLACK PAGES
DC Controller PCA is defective. If the DC Controller turns on the laser beam continuously,
the entire surface of the Photosensitive drum is neutralized causing a completely black page
Replace the DC Controller PCA
10
BLACK PAGES
Defective toner cartridge
Replace the toner cartridge
9
BLACK PAGES
High voltage contact springs are dirty or defective. The high voltage contacts are mounted on
the High Voltage Power Supply PCA and protrude into the toner cartridge cavity
Inspect and clean the high voltage contacts. If damaged, replace the High Voltage Power Supply PCA.
BLACK PAGES
High voltage power supply circuit is defective (not supplying the correct negative voltage)
Replace the High Voltage Power Supply PCA
10
some printers have the high voltage power supply on the DC controller.
BLACK PAGES
Laser/Scanner Assembly is faulty (turning laser on continuously)
Replace the Laser/Scanner Assembly
5
BLACK PAGES
Light is leaking into the printer
Make sure that all covers are in place
possible, but not likely
Nov 30, 2008 | Office Equipment & Supplies
BLACK TONER SUPPLY ERROR
For anyone with a similar issue viewing this page (like me), first take a look at this video: http://www.youtube.com/watch?v=Ipw1RjwzUDg
You want to follow those instructions and see if they work for you. If they don't, which they probably won't, take a look inside the black toner transfer unit (by removing the metal plate with the 5 screws, see video for further instructions), if the transfer unit is empty then this probably means the printer does not supply enough toner to the transfer unit. You could compare the amount of toner inside the transfer unit with that of another colour and you'll will probably find that there is comparatively barely any black toner in there. A temporary fix would be to manually add toner to the transfer unit by simply pouring it in there, after which the printer should print perfectly again. You might need to actually drill a hole in the black toner cartridge or buy a toner refill kit. Of course this is only a temporary fix and you'll have to do it again once you get the same error message. Unfortunately I'm not yet aware of a permanent solution.
Nov 20, 2008 | Samsung CLP 300 Laser Printer
Copier light will scan but will not print.
Black toner supply mechanism malfunction. It could be a bad toner cartridge.
Nov 19, 2008 | Office Equipment & Supplies
Oki Printer c3200 error code
Suggest you order a black drum, which may include a black cartridge. Replacing BOTH the cartridge and the drum should solve the sensor problem, then you can swap parts to isolate where the problem is.
May 27, 2017 | OKI C3200n Led Printer
Error code 54.18
The error code 54.18 means that there was an error with black toner cartridge toner level sensor. Try taking the cartridge out and shake it a little to loosen up the toner inside, make sure all of the cartridge metal electrical contacts are clean and try it again. If it still has a problem you should try a new black toner cartridge. If that doesn't change things then you may need to replace the DC controller.
Sep 09, 2008 | HP LaserJet 3600dn Printer
Clean the sensor. Reset the printer and that should help you with this error. If thet doesn't work replace the toner cartridge.
Sep 01, 2008 | OKI C3200n Led Printer
Samsung CLP 300 Laser Printer Logo
325 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
