Question about Panasonic PT-43LC14 43" Rear Projection HDTV
I have the same problem
Panasonic TH-42PHD8UK works for few hours then turns off and flashes 4 times.
Did any one got it fixed? what is the problem?
  • 3 Answers
SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
what is a UPS?? mines doing it too
Posted on Oct 05, 2008
  • 225 Answers
SOURCE: Panasonic Viera TH-42PV30 No picture & Stand-by light flashes 4 t
I would guess a power board failure. The blinking light is an error code.
Posted on Nov 17, 2008
SOURCE: panasonic viera hd tv th 50pz80u
We had a Pioneer that did the same thing. We called a Pioneer Service Center. It appears there was a recall on the Power Supply. They fixed it in our home at not charge.
Posted on Jan 07, 2009
jscruggs420
  • 36 Answers
SOURCE: Panasonic TH 42PX50U Red power light flashes 6 times
Most of the time when this happens it is the ysus board, that noise you heard was a capacitor popping. Another board runs about $175 and thats if you do it your self. A shop will most likely charge around 500-600, hope this helps, you could also try contacting panasonic and trying to get past the tech and onto casemanagement where you might get somewhere with an out of warranty fix.
Posted on Feb 07, 2009
djchillsnyc
  • 151 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
I have a Panasonic Viera TH-46PZ800A that is 3 years old and today has just started turning itself off. It flashes ten times a few times and then nothing. I turned it off for about 30 minutes and then it...
the common problem on that symptoms is leak/bulged capacitors on the power supply board..
try to replace it to get back the excellent quality of your TV..
regards.
chester
Jan 26, 2012 | Panasonic TH Televison & Video
I have a panasonic plasma tv. Model #
I don't know but I'm having a similar problem. I have a plasma
TH-50PZ77U. It will run for a while and then shuts off. Also, the volume goes up and up and then it shuts off at times. Like I have a ghost here. I had both of my sat. recievers replaced. It seems to get worse over time with shut down. I called panasonic and they had no info and denied this was an issue but I beg to differ from my research here online. It's only a few years and we paid lots of $$$. They gave me a # for service 1 hour away!
Jun 20, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Apr 27, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Grainy Sky+ Tv picture
Can't say it's a fix but when you press the tv button to make the picture better, cover the end of the remote and press sky so the tv and box don't pick it up.
It's more of a work around than a fix!
Mar 30, 2009 | Panasonic TH-42PHD8UK 42 in. Plasma...
Please help
When the red light flashes, it means that something has gone wrong wit h the set internally. The set will have to be taken to a service centre.
May 31, 2008 | Panasonic TH-42PHD8UK 42 in. Plasma...
Loud Fan
Yes, fans are somewhat the bane of these new TV technologies. With all the mechanical and optical stuf in them now, TV's are a lot less reliable than the good-ole CRT type.
Fans are easy to replace though.
Jan 03, 2008 | Panasonic TH-42PHD8UK 42 in. Plasma...
Panasonic TH50PH10 Turn off Automatically
Hi, if your plasma flashes 10 times it means that there is a problem with the sustain driver. This could be an intermittent problem, such as when the set heats up. It should be returned to the dealer as it is under warranty.
Dec 16, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
20 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
