Question about Car Audio & Video
I have a static noise coming from my speakers, I have a system set sens last year my 4 channel amp burne so' I replase the amp,no wiring was change just the amp,now I have a factory radio wish is what I am using and has you know the remote cable runs from the fuise box to the amp.when the radio is turn off is that a hear the noise coming from the speakers and is not engine noise,it sound more like static or some sort of cranking noise.the minute I turn my engine key in turn on position I hear the noise. thank you please help
  • 36 Answers
Change the ground wire. Make it as short as possible also.
Posted on Oct 06, 2009
I have a marantz st100 receiver, and everything seems to work well with one exception. There is static in one channel that comes and goes, and sometimes gets quite loud. The problem follows the channel...
It could be a burned out resistor in the main power amp. Follow the channel wires from the speaker that is playing up till you get to the power amp. Look around for anything odd. Compare it with the other channels, as they are good.
Oct 03, 2017 | Marantz Audio Players & Recorders
Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Jan 03, 2008 | Pioneer VSX-54TX Receiver
Hi, I have JVC CA FSY! and it has static noise on speakers but its ok on headphone. How can I solve this problem?
http://books.jvc.com/booklist.asp?Model=fsy1
Choose your submodel.
So the good news is that the amp isn't implicated but an electrical conductor somewhere in the path may be flaky.
Headphone insertion mechanically disconnects output to the speakers. Hence, headphone removal relies on spring-loaded contacts to restore the output to the speakers. Perhaps there is oxidation on the normally-closed contacs. Repeated headphone insertion/removal MAY help wear it off.
Also try swapping the speakers (wire and all) to see if the static follows or stays with the amp channel.
Jul 12, 2011 | JVC FS-Y1 Theater System
Pioneer VSX-1015TX 7.1 Receiver AMP ERROR I just recently started getting this AMP ERROR message when I try to change input sources, it does not matter which source I click on, for example, whenever I...
I would recommend checking your speakers polarity ( + on the + - on the - ). Also check to make sure the wires are not touching each other where they connect to the speaker or amp. Also check your input connections if you are not using HDMI or Optical. Worst case is you have to send it in to get serviced. Hope this helps
Mar 15, 2011 | Pioneer VSX-1015TXK Receiver
It is an old speaker (DM601 S2) but well cared for. Have clear sound in one speaker and static in the other.
It sounds like a ground problem with the speaker crossover circuit or the amplifier. Turn the amp off and disconnect one speaker and interchange it with the other using the same speaker wires. If the static speaker is now working interchange the speaker wires and try it again. Or if the same speaker still has static it is the speaker. If the static is on the same channel then you have a bad wire or if both channels work it was a bad connection. If the problem remains on the same channel change the speaker wires. If the problem switched to the other channel then it is a bad speaker wire or connection. If the same speaker has the same problem it is most likely the crossover circuit in the speaker which is used to filter frequencies of the audio signal by using capacitors and coils. If the static speaker is now working and the other speaker is now not working it is the amplifier. If the static problem is on all input devices I would trouble shoot the preamp section of the amplifier.
Jun 23, 2010 | B&W DM602 S2 Speaker
Static crackle on yamaha 6030 in 5.1 ..static dissapears if you switch to two channel. coming from bell hd pvr...and sony ps3. with ps3 i have to select audio from dvd or blu ray menu and then 5.1 and...
It might be a bad connection then. First try and swithch it to a different outlet and settings. If it does not work it mightn have to be fixed then.
Mar 28, 2010 | Yamaha HTR-6030 Receiver
Monster MPA 5150SS
Might be a failing semiconductor component (usually an old transistor) in the amplifier's front end. This caused by the oxidation through the component legs or pin. I usually touch and move each transistor's body to exaggerate the noise. You can research also what kind of noise is it producing- intermittent, static, etc.
hope this helps..
Sep 20, 2008 | Monster Cable MPA 5150 SS Amplifier
Hafler power amp has one side out. Would like local repair.Series 9300.Approx.10-15 years old.Not used much.Second time to blow.Runs 4, 8om speakers including 2 bose 802,s (no bose controller or eq in...
just discovered same problem with my Hafler DH-200...right channel out but no obvious problems inside (no loose/burned wires, components, etc). Driven by Hafler pre-amp, but definitely power amp problem.
Sep 03, 2008 | Audio Players & Recorders
Scratchy single channel on amp
I had the same amp! It is the JL 300/4 and one of the chanels came in really fuzzy. It sounded as if the the wires were touching during my installation. I called JL and a JL authorized dealer it would have costed me 190 dollars total to get the amp fixed. Instead I opened up the amp to see if anything looked out of the ordinary. When you open the amp, see if the green fuse looking things are aligned. If they are not aligned then straighten them out. I think they had gotten out of place from being dropped becaue I baught my amp used. My amp works perfectly now!
This is no joke man, I did this just yesterday and was really excited to save 190 bucks. I'm not a technical guy or anything all I know is the green things are located behind the out puts inside the amp.
Jan 09, 2008 | Jl Audio 300/4 Car Audio Amplifier
Multiple speakers in same outlet
How this reciever is set up is there are left and right A and left and right B Only one 8 ohm speaker should be attached per outlet. if you exceed that your driving the channel at a much lower resistance then the units designed for and the channel will burn up.. Oh it might last a short time but bet your last dollar it will burn up the channel if you over load it. Please dont forget to rate this.
Oct 15, 2006 | Pioneer VSX-454 Receiver
Car Audio & Video Logo
822 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
