Question about Mitsubishi WT-46807 46" Rear Projection Television
I have the same exact problem
I hit power, the timer light comes on for 5 seconds and then it goes off.
SOURCE:
SD Tech
  • 14553 Answers
SOURCE: The green timer light flashes when i plug in the
MODEL NUMBER WT-46809:
2,2 is the error code for short protection.
The most common reason for this is one of the 2 pico fuses that protect the convergence circuit is blown. Changing the fuses will not help! They are green in color and soldered into the middle circuit board and are F9a04 and F9a05----look like resistors but are 5 amp fuses.
99% chance if one or both are blown---you have to have someone change the STK-392-570 convergence IC'S that this set uses----the IC'S can be purchased on Ebay for under 14 dollars and the same seller sells the pico fuses 5 @ 2.95.
The best thing to do here if you or someone you know is able is to unplug the set and look for the fuses---middle board towards the back---there are 5 of them and the two closest to the back of the row are for the convergence IC----If someone checks them (like testing any other fuse) you will know--if either or both is blown--the convergence IC got them.
I have start to finish, step by step instructions and photos of the fuses etc----If you or someone you know can solder and is handy--you may be able to do the repair yourself.
If not, shops usually charge 300-400 for this kind of repair in this set.
LET ME KNOW IF YOU NEED ANY ADVICE or help.
Regards, SD TECH
Posted on Oct 28, 2009
ladywinn
  • 5138 Answers
SOURCE: Timer light comes on for
Replace Both of your STK ICs they are big black ICs example STK392-570 Call Mats Electronics they have them in stock 1-800-628-1118
Posted on Dec 19, 2009
  • 453 Answers
SOURCE: power will not stay on
u have a problem with the convergen ic , and 2 pico fuse on power supply , this repair normally cost about $300
Posted on Apr 13, 2010
Cragon
  • 33 Answers
SOURCE: timer light comes on and off tv won't come on
it could be that you hav to reset the lamp timer on your tv, when you change the lamp on your tv you should also reste teh timer other wise the tv will think that you are still with your old lamp, and will turn the tv off when it has reached the designated time limit.
Posted on Jul 23, 2010
eagle338
  • 4889 Answers
SOURCE: turn power on the timer
Unplug the unit and re-plug it. Press and hold the Menu and Device Buttons for 5 seconds and count the blinks before and after the pause. This set is notorious for deflection circuit related failures.
Posted on Aug 18, 2010
We had a aube timer for years and we changed the outside poll light with a new top somehow when we screwed in the post lamp we hit one of the wires and when i went to turn it on the breaker flipped after...
Aube/Honeywell timers have internal rechargeable battery that powers the display.
Battery is not replaceable. Plus the electronics inside timers are susceptible to power surge.
Without the display, timer cannot be used.
These timers come with standard 1 year limited warranty.
http://waterheatertimer.org/Aube-timers.html
Jul 10, 2011 | Aube Technologies Aube 7-Day Programmable...
I have a 52" RCA
The deflection board needs replacement. You need the PSB260 deflection board available from www.tvrepairworld.com
May 17, 2011 | RCA R52WM24 52" HDTV Projection Television
Tv will not turn on,just has the flashing green light.after reseting the tv via the reset button the same problem persits
try hitting the sleep button over and over it reset my timer and I have had no more blinking green light problems
Nov 15, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Switch oven on and it fails to light and goes off again
gas man told us that the timer was not linked with oven and this was solved by correcting the clock
Sep 11, 2009 | New World G90m Gas Double Oven
Light on my sharp xg-nv4su projector comes on for a few seconds then goes off. how do i reset the lamp timer?
To reset the lamp timer you:
1. Turn off the main power button on the back of the projector.
2. Hold down the down, right, and enter buttons on the projector.
3. Turn the main power button on the back back on.
4. The projector should come on, hold down the buttons for at least 3 seconds after it comes on. If it doesn't come on, repeat the steps.
5. Turn the projector back off using the sleep button on the top of the projector. Then turn it back on. If it comes on and is functional, you have successfuly reset the lamp timer.
Jul 25, 2009 | Sharp BQC-XGNV4SU/1 Projector Lamp for...
Blinking Timer Light
Relay or capacitor on or by the power supply
Jul 08, 2009 | Pioneer DV-285-S DVD Player
We plugged in the tv and hit the power button the green timer light blinked for about a minute. We hit he power button and it stayed on for about 5 second and turned off. We just bought this tv used and...
This is a common problem with this kind of tv. When you give the unit power the green light will blink because it is telling you that the projection lights are warming up. Sometimes it will take up to a minute. When you hit the power button again after only 5 seconds it told the tv to power off. I hope this will help you out.
Nov 23, 2008 | Televison & Video
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
TV doesn't turn on
I bought a LG 39" flat screen 6 months ago. TV has been working great until this morning. Power comes on for about 5 seconds and then cuts off. Have checked all connections and have unplugged from wall to reset, NOTHING!! And a brand new TV!! Any help would be great!
Aug 10, 2007 | LG RU-52SZ51D 52" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
