Question about Mitsubishi Televison & Video
Lamp model #wd 52525 yr 2004 there is a dud
Lamp model #wd 52525 yr 2004 there is a dud switch, does this mean that the make and year are problematic? A repair technician in town told me he found the lamp and can order it but I bought the television used for $325.00. The replacement is $250.00 when all is done. The lamp indicator on the television tells me that this is something th manufacturer preppared for. Do these lamps burn out often
  • 557 Answers
Depending on amount of use and how many on off cycles. Its not good to turn these sets on and off within short periods of time. The lamp only lasts a couple years. This is all DLPs. Dont know what you mean by dud switch, there is a switch that is closed when the lamp door is secured. DUD usually refers to the old lamp much like a CORE that refers in rebuildable auto parts. The old lamp housing can be relamped.
Posted on Oct 06, 2009
Flashing lamp light on mitsubishi 52525
The lamp cover is not installed properly or the lamp door switch isnt working thats what causes the 32 error.
Apr 08, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd60735 code 37
A 37 error code means one of your fans is bad. It would either be the DMD fan, or the lamp fan. Take the back cover off of the set and tape down your lamp safty switch. Turn the TV on and see which fan is not working, and replace.
May 17, 2012 | Mitsubishi WD-52525 52" Rear Projection...
I replaced the lamp in my WD-52525 and I still have a solid red light and no picture......is there any instruction on how to replace bad capacitors?
hello make sure the lamp is fitted securely and the lamp; cover as well this it due to the safety switches hope it helps
regards
shaun
Jan 24, 2011 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 will not turn on, Flashing Red light.
if that is a dlp tv . not shure just by model. but if it is then they do have a lot of problems with vented filtor capacitors on power supply and other boards. magor work unless you replace chassis. but the very first thing to try is lamp and make shure cooling fans and vents are clean. J.D.W.
Jun 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi WD-52525 and replaced the lamp.
We have runn in to this with this type lamp, And we are a service center so we do hundreds of these. We too have had bad lamps straight from the box so best guess would to take the lamp back Mitshubishi will warenty the lamp for 90 days so act fast
Dec 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Timer light keeps blinkin!! i unpluged it and plugged back on and it does the same wat do i do
This would be a result a of your lamp going out. You will need to replace your lamp and reset the timer.
The Following are a couple of sites that have lamps for your model of TV.
http://www.bluestar-online.com/Mitsubishi_Model_WD_52525_Replacement_DLP_Lamp_p/wd-52525.htm?gclid=COS58_Xr05sCFSENDQoduFtFDA
http://www.purelandsupply.com/GeneralSearch.aspx?search=mitsubishi%20wd-52525
Make sure you reset the timer on your TV or it will continue to blink.
Jul 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No picture
Lamps have been known to burn out the power supply to the DM assembly. If there is no visible damage to the lamp, your problem may be the power supply or the board. Good luck.
Oct 09, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
