Acer laptop keeps reebooting after win xp diagnistics menu (recovery console, safe mode, etc) also after changing boot order to boot from cd rom it does the same thing is it HDD or Bios problem, or both?
    Sergeant:
  • 195 Answers
Maybe the CD is not an original CD, insert and original CD to boot from......some CD's are counterfeited so for all PC their are codes that they udentify in order to reboot...have come across this problem more then u can imagine....i used an original SP1 XP CD to boot when finished, i insert a copy of an already activated version of windows then boot from the desktop then restart...
Posted on Oct 06, 2009
Acer aspire 5315
well i think you are asking for to use your dell cd to install in your sister's laptop.maybe it will not work because they are specific system configured .you can't use them everywhere.
Mar 31, 2010 | Acer Aspire 5315 Notebook
Will not boot cannot get to safe mode if I do a recovery will I lose all data files, not going to do advanced
from my exp recovery CD is of no use at all....if ur OS is corrupted.....use a WinXP install CD and boot from that. to do that...insert the CD in the CD/dvd drive and switch on...if the boot seq in BIOS is set to CD drive then it will boot first from that else it will boot from HD...so if u can get into BIOS by pressing the F1/F2/Del key etc and change the boot seq to the foll:
1st boot CD rom
2nd boot Floppy
3rd boot HDD0
u can even just disable 2nd and 3rd apart from keeping 1st boot to CD rom
if u have more than one HD or more than one partition in ur HD then u can install a new fresh Win XP in that and once that's done then change the boot seq back to HDD0 from CDROM drive in the 1st boot order
it will get back ur machine live then u can copy all ur imp files to a pen drive or CD then once u r safe of ur data u can do a low level format of the full HD and then aprtition that as per ur requirment
Feb 11, 2010 | HP Pavilion a1610n PC Desktop
HP Pavillion dv9000 will not boot up in normal mode, only safe.
Have you tried an XP repair?
Then you can save your data .
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 18, 2009 | HP Pavilion dv6208nr Notebook
Won't go past window xp logo
You will need to launch Windows XP Recovery Console..here are your to options you have to perform this to correct your boot issue..
Option 1: If you have already installed the Recovery Console loadTOCNode(2, 'moreinformation'); If you have already installed the Recovery Console, you can select it during your usual Windows Startup. To run the Recovery Console:
  1. During Startup, select Recovery Console from the startup options menu.
  2. If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
  3. When you are prompted, type the Administrator password.
  4. At the command prompt, type Recovery Console commands, and then you can refer to the commands that are listed in the "Available commands within Windows Recovery Console" section.
  5. At any time, you can type Help for a list of available commands.
  6. At any time, you can type Help commandname for help on a specific command.For example, you can type help attrib to display the help on the attributes command.
  7. At any time, you can exit Windows Recovery Console by typing Exit at the command line.
uparrow.gifBack to the top Option 2: Starting the Windows Recovery Console from the Windows XP CD-ROM loadTOCNode(2, 'moreinformation'); If you have not preinstalled the Windows Recovery Console, you can start the computer and use the Recovery Console directly from your original Windows XP installation disc. If your computer is already in Windows and you want to add the Windows Recovery Console as a startup option, go to the next section "Adding the Windows Recovery Console as a startup option."
  1. Insert the Windows XP CD into your CD drive and restart your computer. If you are prompted, select any options required to start (boot) from the CD.
  2. When the text-based part of Setup begins, follow the prompts. Select the repair or recover option by pressing R.
  3. If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
  4. When you are prompted, type the Administrator password.
  5. At the command prompt, type Recovery Console commands, and then you can refer to the commands that are listed in the "Available commands within Windows Recovery Console" section.
  6. At any time, you can type Help for a list of available commands.
  7. At any time, you can type Help commandname for help on a specific command. For example, you can type help attrib to display the help on the attributes command.
  8. At any time, you can exit Windows Recovery Console by typing Exit at the command line.
May 21, 2009 | Acer Aspire 3000 Notebook
HELP! Laptop will not boot up!
Try an XP repair:
Boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
Thanks, Joe
May 10, 2009 | Gateway 3550GZ PC Notebook
My sony laptop with windows xp home media center keeps rebooting
When XP gets into the rebooting mode, you will have to run a chkdsk or do an XP repair. You will not lose your data. But you do need your recovery cd or a WinXP cd.
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Type chkdsk C: /R at the prompt in the recovery console.
XP repair
Lastly, your drive can be taken out of the unit and set into an enclosure or adapter. The data can be saved, the your hard drive can be formatted and programs and data reinstalled.
Good Luck,
Thanks, Joe
Mar 10, 2009 | Sony VAIO VGN-NR120E/S Notebook
Blue screen of death
Hi there
"Unmountable Boot Volume." means that the system 32 folder has become corrupt and probably you will have to recover the system.
If you have XP CD for a clean install, you have to change the boot order from within the bios (F2 on boot up) and tell it to boot from CD.
This will change the boot order and allow you to reinstall the OS.
Be warned that you WILL loose data if this is the only option open to you.
Good luck
Jan 26, 2009 | Dell Inspiron 1501 Notebook
Toshiba a205 laptop wont boot
try to boot the windows from external DVD or CD ROM on USB if you have acces to your BIOS set the bios to boot from USB. i think your CD/DVD rom is not working properly, or is no booting from it bios is not setup corectly.
Jan 17, 2009 | Toshiba Computers & Internet
Acer aspire 3680
You need to boot with your windows vista cd and select repair install. This will reinstall the windows files, including the ntldr file, leaving your data intact. Make sure you only do the repair install, if you do the full install, it may wipe your data.
Thanks and please take a moment to rate as fixya.
Nov 07, 2008 | Acer Aspire 3680 Laptop
System won't start.
try to run in safe mode when u start your computer Press F8 key continue.
then u get menu of safe mode etc....
if u able to login go to run then type: chkdsk /r"then "y"
if u not able to login u must have win xp bootable disk or recovery setup.
then boot your susstem with first boot device as cd rom.
if u want more help i help u bye chat support to.
Oct 25, 2008 | Packard Bell iMedia 6826 (P481000502) PC...
Computers & Internet Logo
David Payne
David Payne
