Question about Garmin Rino 120 2-Way Radio
Cant turn on backlight - Garmin Rino 120 2-Way Radio
Click the power button again - don't hold it down, just tap the on/off button. The backlight by default is shut off when the unit is powered up. To turn it on you press the power button again
Posted on Jan 19, 2010
Cant get menu up to go to scan air channels it either shuts itself off or flashes the screen with no time to hit the up/down channel button to get to the air screen any ideas?
1. Check out is the backlight on when you power up the TV?
2. If the backlights is on, then turned off when you power up the TV, please check the backlights power supply voltage (usually is 12V, or 24V), backlights ON voltage should be 3.0 V or higher, the DIM control voltage should be 2.8 V or higher.
If the 12V (or24V) voltages is missed after shuts down, you do have a power supply problem;
If one of the control voltage is missed or low, you do have a defective main board.
3. If both of the control voltage are high, the backlights turned on and then turned off, you my have a defective backlights inverter board, or defective lamps inside the panel.
Good luck to find the problem.
May 01, 2015 | Sanyo DP46849 46 in. HDTV
Tracker 5600 cant see display worked fine last week
Last fishing trip was at night and due to the brilliance of the display my son turnred it down and unknown to me actually turned it off ( the backlight) and it was only after trying everything else found it was the simple solution of turning it (the backlight) back on. oops
Jan 05, 2010 | Navman Tracker 5600 GPS Receiver
Phone display is very dim-can barely read
Well, first you will have to check your options, if you can read it enough to get in there.  You may have the backlight turned off.  If the backlight is not turned off, then you probably have a bad backlight and will have to take it to your provider to get it fixed.  Replacing a screen/backlight is not something I would attempt to do unless you are certain you know exactly what you are doing as you can render the phone completely useless.
May 28, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Display dark
The backlight is turned off. Slide down the power switch (on side of unit, lower right) and hold it for more than 2 seconds. This should turn the backlight on.
Apr 03, 2009 | Sony CLIE PEG-TJ35 Handheld
Sansa clip 4 gb wont turn on
You probably already did this, but here is the proper method to change the backlight timer:
1. Press Menu button to return to the Main Menu.
2. Move to Settings and select it.
3. Select Display.
4. Select Backlight.
5. Press |<< or >>| button to select desired backlight timer.
-Tha mp3 Doctor
Feb 26, 2009 | SanDisk Sansa Clip MP3 Player
Cant see anything on my sony vaio pcg-72dl screen its just blank
Your backlighting may be out.
Try shining a flashlight onto the screen with the lights off in the room.
If you can vaguely see your desktop on the screen, then your backlighting is out.
Let me know if this works,
Simon.
Nov 20, 2008 | Sony VAIO VGN-FE880E/H Notebook
Vizio p42 very dark screen backlight off
There is no back light in plasma TV, Base on the description, the Z Sustainer board is bad. Replace the board will fix the problem.
Jun 02, 2008 | Vizio L37 Television
Backlight on sidekick 3
Because your screen is broken and that can only be fixed if you have it replaced.
Jan 14, 2008 | T-Mobile Sidekick II
Nokia 1600 backlight switched off cant see a thing!! :( help!!
just pull out the batery without turn it off that will reset the original configuration
Dec 27, 2007 | Nokia 1600 Cellular Phone
Garmin Rino 120 2-Way Radio Logo
391 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
eradiostore
eradiostore
Steve
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
