Question about Ariston Technologies ASL75CXSNA 24" Ventless Dryer with Delay Timer in Platinum
Ariston ventless dryer- "Clean Filter" light won't turn off, so dryer won't start
I had this same problem. The dryer would turn on for a few seconds and I could hear the water pump working followed by the "clean filter" light. This dryer has a float sensor which detects whether the pump is successfully getting rid of the condensed water. The only problem is that lint and other particulates condense out in the water and over time the float sensor gets stuck in the up position. The Ariston call center explained that the float sensor can trip the "Clean Filter" light.
In any case, the float sensor is located in the back of the dryer where the pump outlet tube comes out (when facing the back, it is in the lower right). I had to take apart quite a bit of the dryer to get access to the sensor. I ended up taking the near side off to release the plastic snaps that hold the cover over the sensor.
To fix the sensor, all I had to do was clean out the "bath" that the sensor floats in. And then figure out how to put it all back together.
Posted on Nov 30, 2009
  • Kevdaddy Mar 26, 2011
    I got the light to turn out by just taping the machine where the hose exits And moving the hose around a little! Kevis
So my solution is to just get jiggy with it,
As in jiggle the hose a little.
Posted on Mar 26, 2011
My clean filter light won't go off on my frigidaire & my dryer won't turn on
Did you try to remove the back cover after unplugiging your dryer ,to find a lot of lint in the back of the dryer? Some times you may have to clean in this area for fire safety. Maybe this would sold your problem.
Jul 20, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Machine won't swallow the conditioner and leaves some of the powder behind
take the power draw out and clean then clean the inside top with a old tooth brush it gets clogged with lime in the water jets
Dec 04, 2011 | Ariston Technologies Ariston AWD12 Front...
How do I unblock the filter and where is the filter located on my Ariston front loader
Remove the lower plastic panel at the front of washer.
The filter is located at the bottom front right.
Unscrew anti-clockwise to remove and clean.
Have some cloths handy as thetre will be some water that will come out.
Jan 05, 2011 | Ariston Technologies Ariston AWD12 Front...
I CAN'T FIND THE FILTER IN THE ARISTON MARGHERITA 2000 AB43 IN ORDER TO CLEAN IT
The filter is usually in the top tray or bottom in the little square.
Hope I helped
Dr Reed
Apr 06, 2010 | Ariston Technologies Ariston AWD12 Front...
I have a Supra ventless washer dryer combo
Not enough information. Does the drum turn but no heat? Dryer won't start?
Nov 20, 2009 | Dryers
Red light on,check filter
Is this a ventless dryer? I.e. a condensing dryer?
If so, there is a filter that filters the lint out of the water in the condensing unit. Check your owner's manual to find out how to service this. It is usually a little door on the front, bottom of the unit.
If it is not a ventless dryer, then the only filter I know is the lint screen.
Good Luck!
Oct 10, 2009 | LG WM-3677HW Front Load Washer / Dryer
Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
Feb 13, 2009 | Ariston Technologies Ariston AWD12 Front...
I need advice on dryer for my kitchen.
This isn't an add its two different units that I have installed and are both condensation dryers. Which in my opinion is better for your needs and lacking venting.....LG and Miele also have 15 cycle so now the decision is what your needs and Budget. Prices range from 700-1500 but well worth the money. Bosch Axxis Condensation Dryer (model: WTMC8320US) you can machine-dry clothes without venting hot, moist air (or indeed any air at all). The Axxis Condensation Clothes Dryer condenses the moisture in the hot air to water and releases it through the water the need for ducting and a blower motor to help expel hot air. Ventless dryers make installation easy, fast, and very cost effective. And since little heat is lost when the air passes through the condensing chamber, it takes very little energy to raise the temperature back to optimal drying levels, thereby saving you energy. The Bosch Axxis ventless dryer features the unique DUO TRONIC system with 11 auto dry cycles that tailor the drying cycle to your clothing. And Bosch's exclusive DUO TRONIC system combines two moisture and three temperature sensors to automatically deliver precision drying. This machine virtually operates at the touch of a button to prevent over drying and damage to your clothes. With the stacking unit I think this is your best option due to keeping moisture, and later mold problems due too condensation. The Ariston Stackable Condensing Dryer ASL75CXSNA is the perfect choice for any home lacking venting capabilities and is the largest condenser dryer on the market, bringing the convenience of a compact laundry system to any home. Wrinkles are minimized with the innovative Pre and Post CreaseCare feature - periodically tumbling the clothing until you come back to remove it - and the handy Bidirectional Rotation of the stainless steel drying drum. Clothes gone musty from long closet stays can be quickly and easily refreshed with the ASL75CXSNA using the intuitive Air Fluff cycle, and the 12-hour Delay Timer allows for freshly-dried loads at your convenience.Key features include: spacious 16-pound load capacity; 180º reversible full metal door; removable lint filter; included stacking kit; Easy Iron option; and electronic Sensor Controls. The Ariston Stackable Condensing Dryer ASL75CXSNA has the high class, top performance, and compact convenience to be a welcome addition to any energy efficient home.Note: This item pairs with the matching Ariston Stackable Washers. I hope this was helpfull~ Have a good day
Feb 05, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dial continuously turning
hiya
to reset the dial, switch the power off, then turn the dial to a dot on the selection then switch the power on, the light should flash about 3-4 times this should be it reset.
for the machine to start doing this mid cyle though usually indicates something is wrong, i would hazard a guess at the pump filter is blocked and the mahine was trying to drain at the time it started clicking.
the best thing to do is empty the machine manually by placing the outlet hose into a bucket or large dish, once empty remove the plastic kick plate on the bottom of the machine and behind this you will find the filter.
before you unscrew the filter you will need to place some towels or old cloths on the floor as there will still be water left in the pipes, remove filter and any foreign objects (possibly coins, hair clips etc) and then screw back in. job done.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 02, 2008 | Ariston Technologies Ariston AWD12 Front...
Stars cycle thin stops lights reg and eco start blinking
Clean out the filter really well, then replace it. This should reset the dishwasher. If it does it again when you try to run the dishwasher. Take the filter out and re-seat it. Some times it's not sitting exactly right. Good luck and I hope that helps.
Mar 04, 2008 | Ariston Technologies LI640S Dishwasher
Ariston Technologies ASL75CXSNA 24" Ventless Dryer with Delay Timer in Platinum Logo
241 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
