Question about Delta Saws
Replace bearing delta table saw - Delta Saws
  • 2,176 Answers
What is the specific question?? If you give me the model number I will try and find a breakdown for the tool. If you are asking how, some can be removed with a bearing splitter and some I have had to crush the outer race and cut the inner race to pull them It really depends, I would try and take the armature to a repair shop and ask them to remove and press the new ones on for you, it would save you a lot of time and headache.
Posted on Oct 06, 2009
Model 36-979. Where can I get a wiring diagram for the power switch?
images for Delta Table Saws wiring diagram for power ...
Replacing a Table Saw Power Box and Switch. Rocket ...
? 7:45
https://www.youtube.com/watch?v=8A25b9BjkmY
Feb 12, 2014 - Uploaded by AdventuresInDIY
See how an in the way power box on a 10 inch Delta table sawwas switched out ... Would you happen to have a wiring diagramfor your saw.
Oct 28, 2015 | Delta Saws
My delta table saw keeps blowing the circuit breaker on the saw. It does not sound quiet and smooth like usual. I got a good blade its on tight what could this be?
a bad centrifugal starter or inside capacitor and or the electric field if an old type with induction motor , but if it has carbon brushes in the motor instead of an induction motor the commutator on the armature short brushes or a bad bearing(s) on the motor or other gearbearings on the saw drive are worn , it must have a smooth turn if turn on the armature if remove the field /motor house.. look in the motor if running at the end if the carbon brushes you see are make to much sparks a worn bearing without the balls or bad armature collectors or electric field . watch if the bearing is worn by blue hot it can have melting the seat in the motor house replace it all.
Mar 28, 2015 | Delta Saws
How do I lubricate my Delta Table Saw Motor for saw model 34-670
You don't! Why do you think this would be necessary? Bearings are sealed.
Aug 18, 2013 | Delta Saws
Rip capacity is too small (24
If you can locate an old Delta Fence, I have seen those transplanted to a number of other table saws quite easily and reliably.
Otherwise aftermarket, there is the Beismeyer fence, it was adopted by Delta and licensed. You can get them through Delta or even Amazon. There are other vendors. You will want to add outfeed tables and extension tables as well.
You did not indicate which saw you have, but in general terms this applies to most saws.
Feb 14, 2012 | Saws
I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Mar 02, 2011 | Delta Saws
The belt in the motor of my 10 inch delta table saw broke its a Bando synchronous 100XL belt...Think I can find a replacement...However, before it broke whenever I started the saw I noticed unusual sounds...
I have the delta 10 inch cabinet saw with the uni-fence, I bought just before somebody at delta smartened up with the left tilt blade, that is the worst design I have ever seen. I came real close to buying a Powermatic the same day I got this thing. Anyway, my saw sounds like a mack truck in reverse slamming the dump gate when it starts, I don't think there is anything to oil, it has bearings on the shaft. I found a ring of some sort on the floor one day that fell out of the saw, broken in half, I have never found where it came from. We just laugh at it, It is a bad saw. I bought the 12 Rockwell/delta planer the same week, Oh boy did we have fun with that, instantly went through the set of knives on it, maybe 3 passes, I said what the heck. I called delta and told them this is the biggest piece of junk I have ever seen, I said for $1300 it should put a finish on the board when it comes out, and it should have carbide knives, I said, If I had know it was made in Taiwan, i would have bought a grizzly. and saved $500. And gotten a better planer. She said, I'm sorry, I can send you some new knives. I sold it. Still have the saw though. Never had problems with the bearings. Hope this helps.
Feb 21, 2011 | Delta 36 982 10 Inch Left Tilt 1 1/2...
Delta saw model no. 28-245 saws a taper form top of wood to bottom why does it not saw a stander line Delta saw model no. 28-245 s/n 91B1335
Sounds like your table is tilted. Put a small square on the table against the blade, then adj the table to it. If that is not it, then the blade guides are off up and down, back off all the guides, wheels, turn the blade by hand, get it tracking in the center of the tire, then bring the bearings up the blade, don't push it , just touch it, then bring in the guides, again, make sure it doesn't push it, the guides stop it from going off, it should track by itself. Hope this helps.
Feb 05, 2010 | Delta Saws
Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
Jun 21, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Delta table saw motor trips breaker
The motor needs a new start capacitor.
Apr 09, 2009 | Saws
Saws Logo
79 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Delta Saw Expert? Answer questions, earn points and help others
