Question about Yamaha TSS-1 Computer Speakers
Speakers work sometimes, and sometimes they don't
I have a gateway gm5422 with bose companion 5 speakers, with a vista ultima sp2 OS. The speakers worked fine until I upgraded to Sp2. I tried other speakers and they did the same thing. Bought a new sound card, and it still does it. I can be watching a video in regular view and when I go to full screen, I lose my sound. I can reboot the computer and sometimes the sound comes back. I can unplug the bose system for 30 seconds and they start working again, but sometime during the day they stop. I have talked to bose service and done everything they told me to do but the problem continues. Not the speakers, not the sound card (connected to the mother board) or the new pci sound car. I don't know what else to try. Any suggestions?
trintek
  • 111 Answers
SOURCE: Front Speakers stopped working
turn on your video and start something playing, press the speakers button repeatedly until the sound comes back. this should bring back your front speakers, if it doesn't, double check your speaker connections and sound field program.
the speakers button should cycle through all available front speaker options.
Posted on Nov 16, 2007
SOURCE: Amp powers off after switching on
the last click you hear before the amp turns on is the power relays for the amp circuit,these have 2 very small copper contacts inside them which after much time get corroded and cause high resistance when they try to power up the amplifier circuit.awkward to get to and desolder but can be opened up and serviced,done mine and a few friends with yamaha amps which use similar system,had no problem since,also worth checking for dry joints around amp chip i.c legs onto main board.
Posted on May 02, 2008
sparky1500
  • 1066 Answers
SOURCE: 1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
Posted on May 17, 2008
  • 151 Answers
SOURCE: No sound coming out of back speakers when watching DVDs
Make sure you have set blu ray player out put to bitstream,if you have set to pcm for hd master audio and dolby true you need to have a amp to decode this and hook up with a hdmi cable.If your amp has hdmi in and out but no high def audio you may still get multi channel audio.
Hope this helps.
CABLE GUY.
Posted on Jun 29, 2008
easyq
  • 144 Answers
SOURCE: The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Posted on Apr 17, 2009
Hello, i have a dell Windows vista and my companion bose 5 wont work.. and ive tried it in another computer and it still wont work. what can be the problem?
Is there any system to which you can connect your BOSE *and* have it work?
If not, then check that the BOSE is getting electrical power into it.
Jul 19, 2011 | Bose Companion 5 Multimedia Speaker System...
Bose Companion 5 doesn't work with OS 10.6.4. Help!! How can I fix it???
i am not sure it is the OS because since it is software it doesnt really select hardware such as speakers. try checking to ensure your connection is correct or the sound system is still functioning, you can try it on another pc
Oct 10, 2010 | Bose Companion 5 Multimedia Speaker System...
BOSE Companion 5 speakers connected to an Apple but no sound.
if you have a bose disk then you will need to run the install disk firsthope this helps if it does please rate this answer
May 12, 2010 | Computers & Internet
Do you have the USB cable plugged into your Mac?
Mar 20, 2010 | Computers & Internet
"This device has no output controls" Bose Companion 5 problem!
Metal detectors/ Xray devices have been known to destroy magnet based electronics (speakers). This could be your problem.
Sep 22, 2009 | Bose Companion 3 Computer Speakers
Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Aug 12, 2009 | Bose Companion 3 Computer Speakers
Sound from 1 speaker bose companion II
you must check the connection with the other speaker.
Feb 13, 2009 | Bose Companion 2 Computer Speakers
Bose Companion 5 Problems
email support@bose.com or contact a Bose Support Specialist in Germany; or call US support at 1-800-367-4008. Something very odd is happening here. You are using the same laptop, correct? If not, let me know, as there are some things to try. If Bose has a solution, I'd love to hear it.
Mar 19, 2008 | Bose Companion 3 Computer Speakers
Yamaha TSS-1 Computer Speakers Logo
51 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
