Question about ThermoKool MR-138
Lights flash.. relays click.. fan spins slowly...
Sounds like this may be common. I took mine apart and noticed that the fan would spin slowly. I beleive this is because the relays are pulsing the fan. I am not sure if a relay is bad or there is an issue somewhere before the relay. The relay is on the board with the power supply. I have not take the board off yet. For fun, I did disconnect the fan and most of the other stuff which connects to the power supply board and still see the same issue. I would really love to find a set of schematics for this fridge...
Anyone have any additional thoughts/ideas?
Thanks.
David
  • tankueray May 11, 2010
    I am also having this issue. I got the part number from the board (S126SMD3) but I can't find it for retail sale anywhere. I've had friends with repair shops contact the manufacturers for a replacement, as I have also done myself, and we've not heard back in over a week. I guess I won't lose anything by trying to replace the components on the board... so maybe that's next. Have you had any luck with this? I cannot find any information on the 'net.
Why is the cooling fan not coming on
Disconnect wire connector from fan relay (located on fan frame) on fan side (far side from you).
Give it 12V juice.
* If fan spins, you have bad relay/module.
* If fan won't spin, you have bad fan motor (most common)
I've done three times, one on mine and two for my friend's.
It was fan motor on all three 2006 TCs. (not defective, just aged motor, less likely problem with relay/module)
Even your motor or relay are fine, change for both.
Lincoln dealer or Autozone etc, they sell fan and relay as set.
If you buy fan alone or set with module, it cost you almost same.
Check price for fan/relay alone and complete set.
It was "almost" same price set or alone at my local.
May 02, 2014 | 2006 Lincoln Town Car
On my indoor unit the fan just humms will not spin while energize
Did you change the capacitor on the fan motor. Could be bad if not bad fan motor. But sounds like a cap. Russ
Jul 19, 2009 | Heating & Cooling
Hoover steamvac brushes don't spin. everything else works great. Took it apart and no visible problems
my husband took it apart today and the impellers were gunked up with black stuff.
he used these pictures that someone else generously posted. ours was slightly different in internal design, but they are helpful regardless.
here is an exploded diagram of the 5903, 04, etc. it will help you see if any parts are missing or broken.
http://www.vacuumcleanershop.com/images/Hoover/F5903-900.GIF
parts list if you need some:
http://www.vacuumcleanershop.com/hvrmdlf5903.htm
it's working fine now. sucks much better too. what a difference!
guess for the $179 these things avg, they just need annual maintenance. I wouldn't pay someone to do it though.
Jan 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Kenmore HE2 flashing lights
had an old pressure switch that I thought was the problem I had from something else a year ago
That was the washer not starting, all kinds of lights
I took the back and top off and reconnected all the plugs.
Had a loose connection somewhere, it worked after that.
I blew into it and put it back on.
The rattleing quit in the pump after it pumped out, while the drum was spinning slow.
Now working ok
Nov 24, 2008 | Kenmore 46462 Front Load Washer
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
Ecofan only turns slowly
These fans can be rebuilt! Like many others, our fan died after being placed in the center of the stove top. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Nov 28, 2007 | Cfm 802 Ecofan Table
Gas range (oven)won't lite (gas broiler works fine)
Sounds like an ignitor problem or possibly a dirty orifice. Model #'s are usually on the frame behind the bottom drawer.
Oct 04, 2007 | KitchenAid KGSI901PBS Gas Kitchen Range
Open Questions:
See all ThermoKool MR-138 Questions
ThermoKool MR-138 Logo
283 people viewed this question
Top ThermoKool Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a ThermoKool Refrigerator Expert? Answer questions, earn points and help others
