Question about Samsung SyncMaster 710N 17" LCD Monitor
I have a sync master 710n and it keeps goin off and on, and have tried everything
    Scholar:
  • 101 Answers
Have you checked the caps in the power supply? Open the unit up and find the power supply, look at the top of the caps to see if any are bulging on top. If they are replace them.You can usually get these at radio shack. If they are 16v go to 25v,if 25 go to 35v. Keep the same mfd rating. Some caps they put in at the factory are under rated. They can't take the surge at start up and soon **** out. All of this of course is based on your understanding of electronics? Hope this helps.
Posted on Oct 30, 2009
My Samsung Galaxy Core Prime just recently unsynced all contact in my phone from my fb friends & now there is not even the option to sync phone contacts with fbook. What happened & how can I fix it?
Hi Kimb
I had a similar problem recently.
Lost all my data from one device.
It's a bit hard to put into words...
Sync means to syncronise e.g.. one list to another list, to make them the same.
It's supposed to sync the master with the copy
Trouble is, it often sync's the copy (0 data) with the master which makes both the same (or blank)
Some sync software keeps both copies and transfers new contacts only.... making them equal.
Check your sync settings to see which is replacing which.
You decide which is the master and always go from master to clone.
Although not Samdung G specific....
Hope this helps
Example of a program with good sync options.
Mar 16, 2016 | Samsung Cell Phones
Iv got band hero for ps3 and iv set it up and sync them. Da guitar and mic r working just fine but when i try conect and sync da drums it doesnt work. Da lights on da drum control keep flashing. Cn you...
Make sure you are syncing the drums by using the charging cable that is used for controllers. If you plug it in like that then turn on the drums it should sync up. If you are still experiencing the problem I suggest restarting everything and try syncing the drums by themselves without any other instruments, then connect the others.
I hope this helps!
May 16, 2011 | Video Game Consoles & Games
When I open the Monitor (samsung syncmaster 710n) everything is OK! As I soon as I connect the vga cable from my pc the monitor turns on stanb by mode and does not react to any buttons!
It sounds like you are connecting with the power on. NEVER do this!
Shut off your computer AND your monitor. When both are off, THEN connect your cable.
Then you can turn the PC and monitor on (the proven old school way is to turn on monitor first, then PC)
If nothing was damaged from connecting them "live", you should be OK.
Feb 10, 2011 | Samsung SyncMaster 710N 17" LCD Monitor
I have the same problem. The Sync DSL light keeps on flashing. According to the 3Com and Singtel, they both blame one another. From my understanding, the modem is not receiving and internet signal at all....
Yes, when the sync light flashes it meand there is no sync to the DSLAM located at the exchange. This is usually down to either bad wiring (too much line noise) or the provider not having set the line up.
Have you tried connecting the router to the master socket in the house with no other equipment connected - phones faxes modems etc? they can cause problems sometimes.
Apr 22, 2009 | Computers & Internet
I have the syncmaster 710N. I recently had a
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Feb 24, 2009 | Samsung SyncMaster 710N 17" LCD Monitor
710n "non optimum mode"
http://72.14.235.104/translate_c?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220&usg=ALkJrhiRO8V09Lo7lnjqW47LE8IE653r7w
I give you this link, but you must know about electronics that you can do this. If you can´t find wath you want, just write and I will give you everything about that in file (word). Do not be afraid do this because it´s working I try that.
Jan 03, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung Syncmaster 710n no display and no LED light
The power button should be on the FRONT BOTTOM RIGHT. and there should be a little led/light next to it. make sure everything is plugged in correctly and press the power button, the led should light up, and then boot your computer.
Let me know --
If this helped please mark this thread as FixYA
Dec 26, 2008 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
thank you
Oct 29, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung SyncMaster 710N 17" LCD Monitor Logo
280 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
