Well it looks like you have 2 slots on that mobo so yes, 2 1GB cards would be pretty good. You could buy two 2gb cards, it depends really on how fast you want your computer to be. If you have a large HD, such as anything over 500 gb then I would say get two 2 gb cards. If it is under that, then there is no need. The larger cards are for larger HD's because they have more space to search when it looks for something and needs more speed. Hope this helps. Cheers.
Regarding the Acer Aspire 5810TZ-4657 what is the most powerful CPU it can be upgraded to, from the...
(More)
Regarding the Acer Aspire 5810TZ-4657 what is the most powerful CPU it can be upgraded to, from the SU2700 that it comes with? I would like to upgrade it to the Intel SL9400. Regardless I want to upgrade it to the fastest DUAL CORE this motherboard will take. Thanks
set up my routter and still having a low id where it doesn't even get close to the speed it used to...
(More)
set up my routter and still having a low id where it doesn't even get close to the speed it used to get only downloading at max 20kbs which it used to get it up to 200kbs what could be the problem i am using d-link dgl-4100
