Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Cant Get The Chain To Stay On
The chain in kinda old had for 3years only used it some,any suggestions,i tighted eveything up as much as could,and extened the bar out as far as it'll go,please help
    Sergeant:
  • 302 Answers
Well, you have 2 choices. First one is to buy a new chain. Second one is to take your chain in somewhere and have a link removed. If you think this chain is that stretched you should check your chain oiler and make sure that it's working. Take the chain and bar off and run the saw and look at the oil port and see if oil is coming out. Also check the oil ports in the bar and make sure they are clear. The only way a chain can get this loose is from wear in the pins in the chain from running dry or too tight. Also make sure the surfaces on the bar where the chain rides are flat and square or your saw wont cut straight. Hope this helps you.
Posted on Oct 06, 2009
Testimonial: "Awesome !!!!!!!!Thanks So very Much I Was At Wits End trying to figure out what i did wrong or wasnt doing,Thanks very much for this web site,A++ rate"
How do you tighten the chain
Well it kinda depends on the saw you have. But either way you have to losen the bolts on the side of the saw by the bar and look for a flat head screw either between them bolts or at the front of the saw, some were beside the bar and chain. turn till chain is tight but not to tight and then tighten side bolts. Now if you have an older saw the do the same thing with the bolts only on the bar there should be a slot for a flat head screw driver just turn till chain is tight and tighten the bolts back up...
Apr 19, 2015 | Garden
How easy is it to fit a cam chain and link in sit to a Honda CB 750 1994. and what is the main problem with a rattling chain on one? is it mainly the chain for the cam, or the lower drive chain for the...
eaasy take off the timing /rocker cover and the top chain guide exposing the top of the chain undoo locknut and back off tensioner then break chain after tying both ends with cord so they cant fall in then splice the new chain onto the old and wind it through taking care to not let it jump teeth on timing wheels, detatch old chain from the new one, swage rivet pin in join of new chain crank engine by hand with a spanner two full rotations to check for valve piston interference and reassemble tighten tensioner until chain feels tight then back off 1/4 turn put back upper chain guide and bolt down rocker cover and you are done easy
Oct 21, 2014 | Motorcycles
The chain/bar won't stay tight. Becomes loose after several minutes of use.
If the nuts holding your guide bar are not worn, then you must replace the tensioner adjustment
Jul 29, 2014 | Poulan Garden
Chain wont stay tight
Proper lubrication.
Don't over tighten. (looser is better).
New chain on old sprockets. (very bad) or vice versa.
Proper alignment of rear wheel.
Apr 01, 2014 | 2007 Bajaj Bajaj Avenger
After fitting new drive and chain sprockets i still have tight spots
When you fit new sprockets you also have to fit a new chain if you dont your sprockets will wear out very quickly, as your old chain is stretched to the old sprockets.
Feb 21, 2014 | Triumph Thunderbird Motorcycles
Chain tenion on chain saw
A new chain will need frequent adjustment untill it is broken in. Hold the tip of the bar up when tighting the bar nuts
Apr 07, 2013 | Garden
When using the saw, the chain doesn't stay tight on the bar.
Should be a nut on the side of chainsaw that covers the chain, sometimes all that is needed is to loosen nut them pull outwards on chain bar and retighten nut. Chain should have some play in it so dont make the chain hug the bar tightly. There is also an adjustment screw next to the bar that will tighten and loosen the chain but is used for small adjustments only.
Sep 07, 2010 | Remington 111409 - 01 6" Branch Wizard...
Is the chain being properly oiled? Make sure the cover fasteners are tight after adjustment. If the chain is dull or is improperly sharpened, it will heat badly causing the chain to become loose. Adjust the chain (cover fasteners finger tight) so that the chain just comes up to the lower bar, but not so tight that you can't pull the chain by hand. Make sure the teeth cut toward you on the bottom run. Run the engine at speed with the bar tip near some cardboard for a few moments, it should throw off a thin line of oil onto the board. Hope some of this helps!
Jun 23, 2010 | Poulan Pro Chain Saw 46cc 20"
My 1990 nissan sentra has a noisy timing chain when running idle.
Your timing chain tensioner is using oil pressure to stay tight.Could be your oil pressure is so low at idle the tensioner just can't stay tight.At the next oil change you could go for a thicker oil and see if the tensioner keeps the chain tighter at idle.
May 05, 2017 | 1990 Nissan Sentra
Cant find the screw to tighten chain on saw
Hi
You have to look from profile to the chain saw(clean it)
best regards savumihai71
Dec 08, 2008 | Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
106 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
