Question about Polaroid V30DMBT-UP2 Television
Polaroid LCD FLM-3232 Television
Indicator light not on and no sound or picture. Outlet has power and fuse in TV okay.
  • 1 more comment
  • Anonymous Jan 02, 2008
    I have a 32" Polaroid FLM-3232. No power seems to be going to the TV. I changed the fuse but it didn't help. Any ideas? Thanks
  • LITAPORTIS Nov 04, 2008
    i have no sound. and black screen. i remember reading that someone fixed there tv on this site. they purchased a few screws from radio shack. i just need the info again on how to take out the control box. please email me with the info agin please. litaportis@yahoo.com
  • Raul123 Apr 17, 2009
    Hi Alan,
    I think your solution is the only one for the FLM3232. The other solution works only for the ones who have a different power supply. I need your help, I have the same problem, no voltage in CN2 and CN3 at the begining, but after replacing the components you suggested, I found 24VDC in CN3, but no in CN2. What else do you recommend me to change to have voltage in the CN2 pins.
    I will appreciate your help.
    Raul
I can only tell you what I found out. There is vertually no documentation supporting this product to componant level, so I just had to wing it.
I had no power 24VDC from CN2 or CN3. I figured the problem was a switching problem,
So I replaced two Diodes D7 and D6 (They are in the mid board area and real close to each
other) I also replaced the two electrolitic caps 10UF 50V that are in the same area just
because I was in the mood to change out parts. (I changed em with 10uf 35V) the diodes
were also changed with parts I could get D6 I changed with a 276-1102 and D7 with a
276-1114 Radio Shack. I know that they are not the correct values, but I was in a hurry
and just wanted to see if I could some it and get it off my table. Well Low and Behold''
it sturned on, and has been working. I cant say this fix will help you, but if that other
harolded fix does not work for you, then try mine. worst you can do is Blow it up. I really
Should have taken the time to order the correct parts, but after pulling my hair out for two
days trying to find a schamatic for that stupid power supply I guess I got depressed. I knew it had to do with the switching on of the power, but so many things can do it. I just hoped it out be those swistching diodes. If you do want to try this, go ahead and remove the componants and order
the correct ones. and GOOD LUCK.
Alan LaBerge
Posted on Jan 09, 2009
Go to http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen. Stiv0 posts the fix at the top, but go down about 10 posts or so and read mine (BlakeFromGa). I have some slight differences to my fix and a list of what you'll need.
Posted on Sep 29, 2008
  • 56 Answers
Check power supply.
Posted on Apr 09, 2008
My polaroid model 3232 lcd tv has picture but no sound
Manuel, there is a 10 ohms resister, location r385 open on main board.
Oct 29, 2011 | Polaroid FLM-3232 Television
Tip
Polaroid FLM-3232 Service Manual Download
Download Polaroid FLM-3232 LCD HDTV Service Manual
Models: FLM-2632 / FLM-2632M / FLM-2634B / FLM-3232 / FLM-3232M
Models: FLM-323B / FLM-3234B / FLM-3732 / FLM-3732M / FLM-373B
Models: FLM-3734B / FLX-374
Have you misplaced your Polaroid FLM-3232 LCD HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3232 LCD HDTV Service Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Polaroid FLM-3232 Manual Download
on May 01, 2010 | Polaroid FLM-3232 Television
Tip
Download Polaroid FLM-3232 LCD HDTV Manual
Have you misplaced your Polaroid FLM-3232 LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3232 LCD HDTV Users Guide?
Follow this link
I hope that helps.
_____________________________________________
Have FLM 3232 Polaroid turn on get a picture then black screen but have sound
Ur LCD inverter board it dead.Must replaced this board to get picture back.The board part is usally a long board part.
Jan 29, 2010 | Polaroid FLM-3232 Television
Are the Polaroid FLM-3232 and the Element FLX-3202
not sure if there the same but the boards inside may be.
This sounds like the problem most LCD tv's get with swelled up capacitors in the power supply board. look for circular cylinder shaped parts rapped in plastic with writting on the sides, and metal tops, if the top is rounded over, not flat, it is bad. replace them.
Jul 22, 2009 | Polaroid FLM-3232 Television
Sound but no picture.
It sounds like it is the picture tube. The same thing just happened to me. The back of my television started smoking and then there was no picture.
Jun 21, 2009 | Polaroid FLM-3232 Television
Universal remote code for a Polaroid LCD TV
I may be able to help with your Universal remote and your Polaroid LCD HDTV.
You can find some Polaroid HDTV Remote Codes here.
I hope that helps.
Feb 26, 2009 | Polaroid FLM-3232 Television
No power Polaroid 3232 LCD HDTV
Power supply must be something wrong. You may need to bring it in a service center near you.
Sep 23, 2007 | Polaroid FLM-3232 Television
Polaroid V30DMBT-UP2 Television Logo
367 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
