Question about Bausch and Lomb Optics
My rifle scope will not zero at 100 yards. It is a Busch & Lomb Elite 3000. Other numbers on the scope are: 30-3940G and AG02621. Is this covered by warranty? If not how much will it cost to repair? How and where do I send it for repair? Hunting season is here and I need my scope. Thanks for your responce and help.
5 Suggested Answers
  • 117 Answers
SOURCE: Elevation won't go any higher
Take the rear ring off and put a shim UNDER the scope.A small piece of plastic from a blisterpack works well and is very stable.Cardboard or paper will swell with moisture and then shrink when it dries.Good Luck
Posted on Mar 25, 2009
  • 2418 Answers
SOURCE: rifle scope fogging
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trashed can size. You will need to get your hands on some nitrogen or you can also use carbon dioxide. You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off your scope, let it dry out. Now ck for any o-rings and try to find new if you can, put the grease on the screw threads.Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Posted on Dec 05, 2009
  • 18 Answers
SOURCE: Bausch & Lomb Balvar 6x24 Rifle target scope
Bushnell owns baush&lomb scope I have called them to repair my elite series bausch&lomb and I have been very happy with there customer service.They might be able to help with your problem to.
Posted on Mar 11, 2010
  • 179 Answers
SOURCE: I took my 4x12 Redfield rifle scope off my 222
check the rings...number one problem when scoped wont stay on zero.
Posted on Jan 22, 2011
What should I zero my scope at when shooting my 7mm savage with 175g remmington core-locts?
Depends on how far you intend to shoot. Most zero their rifles at 100 yards, but if you intend to hunt plains game, you might want to use 200 or so.
Oct 15, 2013 | Pentax 4x-12x40mm Gameseeker Rifle Scope,...
I inadvertantly changed my elevation adsjustment.
this is an excellent article on zeroing a scope.
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
Apr 06, 2010 | BSA ® 2 - 7x32 A/O Sweet 17?? Rifle Scope
Mar 01, 2010 | Bausch and Lomb Bausch & Lomb Hunting...
Bosch & Lob elite ed foggy
Bushnell own bausch&lomb scopes and I have had good luck with there customer service. I would call them first .Just make sure you send a detailed letter with scope.Good luck
Feb 08, 2010 | Bausch and Lomb Bausch & Lomb Hunting...
How do I sight this scope. If I set the center mil dot at zero at 100yards,where will the other dots be sighted using a 22/250 with 55 gr. bullets
I think the mildots only go so far, you have to do your homework on these things. Your 22.250 zeroed in at 100 yrds, velocity 3800, drops 7.4 inches at 300 yards, and 37 inches at 500 yards, so your mildots being set at x number of inches per dot, will not hit at 500 yards, your bullet is not enough. Even sighted in at 400 yards, the bullet drops 13.6 inches at 500 yards. But,,, with the same 400 yard zero, at 100,+4.7,200,+7.7,300,+6.6. That is about the flatest you'll get. And your mildots will be set likewise. You know they made the mildot scope for the trajectory of the 308. They changed everything for that bullet.
Jan 25, 2010 | Brunton FV62450-4 Fast Focus 6-24X50...
I just bought a rifle with one on it. exactly how
the adjustment on the front eye PC is your zoom.
for your wind edge you have a series of numbers.
some scopes differ some read 5,10,15,etc
some read 1,2,3,4 etc, the # are estimated wind speed,left or right.if the wind isn't blowing set it on 0.
for your elevation you will have a series of #'s
50,75,100,etc.this is your yard edge sight it in at 75 yrd's and if what your shooting at is 100 yards just turn the knob to the correct setting.good luck
Oct 30, 2009 | Bausch and Lomb Bausch & Lomb Hunting...
Windage and elevation adjustment all over the place
Sounds like you want to "re-sight" in your rifle. Make sure mounts are okay and tight. Look down barrel and then thru scope and eyeball windage and elevation adjustments so the scope seems to be fairly in line.
Clean barrel if it needs it.
For basic sight in, start at 25 yards with a large(3 to 4 feet) cardboard or wood backdrop around target (bullseye). Fire at target. Once done, look through scope and position rifle such that the shot mark you created is dead zero. Hold rifle very steady and you or buddy move windage and elevation adjustments until scope moves dead zero back toward original target (bullseye). Fine tune from there. Air cool rifle between rounds. Once dead eye, fire another round or two to check grouping. Check your ballistics (sometimes on ammo box) to see how height at 25 yards affects your desired dead on target (100 yards, 150 yards, 250 yards etc.). Adjust accordingly. Example: you may need to sight in at an inch high at 25 yards, depending on your dead on target distance..
Always remove sling from barrel when sighting in.
Try to sight in at similar temperature as you intended shooting temperatures, if possible.
If not black powder, avoid cleaning barrel between sight in and hunt/competition unless you note bad buildup inside.
If you change ammo, understand that that may affect performance. Once a preferred ammo is found, some even try to buy a decent quantity with the same lot number on the boxes if storage allows for such.
May 02, 2009 | Optics
RIFLE SCOPE STUCK ON 8x POWER
If the scope's minimum power isn't 8x then it's broken. Call the customer service rep of the company and see how you can return it. Depending on the warranty they may fix it or replace it. I'm not familiar with Balfor as I don't shoot BB guns. You can move the ring around a bit, see if something loosens up, but don't force it.
Nov 18, 2008 | Bausch and Lomb Bausch & Lomb Hunting...
Optics Logo
147 people viewed this question
Top Bausch and Lomb Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Jeffrey
Jeffrey
Are you a Bausch and Lomb Optic Expert? Answer questions, earn points and help others
