Question about Mitsubishi WT-42311 42" Rear Projection Television
When turned on green power light clicks on and won't stay on
When turned on green power light clicks on and then goes off and it won't stay on. WT-42311 model. This happened just after my wife used the DVR to record a program. The set is 6 years old. Any advice
ctf1800
  • 4402 Answers
SOURCE: mitsubishi tv wt-42311
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 15, 2007
style_points
  • 34 Answers
SOURCE: Mitsubishi WT-42311 DLP Bulb Replacement
Your access should be a a panel near the back or side. You will see that it is somewhat easily removed and should have maybe one or two screws. You will see the casing to the lamp. Go ahead and remove it. Now unscrew the old bulb and replace it with a new one. There is not a lot of screws holding it together. It's a fairly easy process once you find the lamp. You should see the lamp once the panel is removed.
Posted on Apr 27, 2009
ladywinn
  • 5138 Answers
SOURCE: i have a mitsubishi 1080 series wt-42311
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
Posted on Sep 18, 2009
SD Tech
  • 14553 Answers
SOURCE: I have a wt-42311 that turns on then immediatly turns off
2, then 2 is short protection. What it usually means in this model is one of the two STK-392-110 convergence chips has shorted and taken one of the 5 amp pico fuses out that protects the chips.
The set will detect no voltage to Convergence circuit and shut down instantly----It could be a short elsewhere but 95% of the time it is one of the convergence chips.
This model uses a light box---with the back removed and several screws removed and one large square plug on the left side(as you look from the back) unplugged-----everything comes out in one piece--the sides are plastic and actually have handholds to pull the box out once it is unbolted.
The question is can you do this? You will need to get the box out and check the pico fuses near the chips--they do not look like regular fuses but can be tested like testing any other fuse---If one or both are blown--you need to replace them and BOTH chips---you can get replacement chips for about 12 dollars for a pair on Ebay---I buy mine there.
Each chip has 18 pins and is black in color (about 2 1/2 inches wide by 1 1/2 inches tall with the STK number printed on them in White) and in this set they are located on metal heat sinks near the very front of the Chassis.
Let me know if you have questions or need help--IF YOU CANNOT DO THIS REPAIR LET ME Know and I will give you advice.
I am here to help people.
SD TECH
Posted on Oct 16, 2009
Testimonial: "Thank you for the advice. Very helpful."
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi tv model wt-42311, error code 2-2. what can i do?
2,2 IS short protection and 95% chance it means one of the two pico fuses that protect the convergence IC chips are bad.
This model uses two of the chips: STK-392-110 and you would have to pull the light box out to replace them safely (total parts cost will be under 30 dollars).
It involves getting at the chips and the fuses and replacing them: how much skill do you have?
SD TECH
Posted on Mar 25, 2010
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
