Question about Cell Phones
I was unlocking my iphone and put in the wrong password now it says iphone disabled "connect to itunes"... i connected to itunes and it said cannont connect because my iphone is locked how can i unlock it without restoring my phone and losing all my numbers
  • Amanda Stinson Oct 06, 2009
    helpful need more info. confused on how to do it.
  • 835 Answers
You can get one of tose mini-sdi cards, go into your contacts and copy all of them to that card,.. take the sd-mini card out, then restore your phone.
Posted on Oct 06, 2009
My iPhone 6 is dsabled. How do I get my phone back
Hello Jabob. If your iPhone 6 is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPhone unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Apr 04, 2017 | Apple iPhone 6
How do i disable the passcode on a iPhone 6 plus with IOS 10.0.2.
You can't unless you do a factory reset, this wipes the phones memory clean along with the password or code.
Oct 06, 2016 | Cell Phones
I put in wrong code and now it says disabled connect to iTunes but I set the phone up with wifi so how do I get in my iPhone?
Your iPhone is currently on disabled mode after entering wrong combination of password. There are several ways to gain back the access to your iPhone:
First Method: iTunes
1. Using your computer, open iTunes where you have recently backed up your iPhone.
2. Connect your iPhone. Once your iPhone is detected, a notification will appear to enter your passcode. Note: If the lockscreen doesn't show, proceed to next method.
Second Method: Update
1. While your iPhone connected to iTunes, powered on. Hold down the Power key + Home button simultaneously until the screen off, keep on pressing the Home button then release the Power key until iTunes detected that your iPhone is on Recovery Mode. Note: An iTunes logo will appear on the iPhone when Recovery mode is enabled.
2. On iTunes, click on Update iPhone. It may take a while to download the software, so leave it for a while connected until the installation complete.
3. Once updated, try unlocking your iPhone. Note: If you still can't unlock your iPhone proceed to next method.
Third Method: Restore (last option)
1. If method 1 and 2 fails to unlock your iPhone. Then try to restore your iPhone into its factory default and restore your backup after.
2. Go to recovery mode. See method 2 step 1 process to enable recovery mode.
3. Then choose Restore iPhone. Note: Restoring your iPhone will delete and remove all of your data including apps, music, photos, messages, contacts, notes, etc.
4. It may take a while to download and install the software, so leave your device connected until the process complete.
5. After your iPhone has been restored, choose restore from a backup or iCloud, then wait until your iPhone successfully synced your old data.
6. Try unlocking your iPhone.
-joshd
Mar 28, 2016 | Apple iPhone 5c
My phone says its disabled
You need to log into iTunes and then connect your iPhone to unlock it. Maybe the password was entered wrong too many times? If that doesn't work you may need to call Apple or your carrier for help.
Jun 04, 2015 | Apple iPhone 3G
IPhone is disabled, says connect to iTunes?
This happens when you have entered wrong combination of pin code multiple times. To be able to use your iPhone, it must be connected to iTunes on a PC or Mac, an iTunes that have recent backup of your iPhone, then your device will unlock after connecting to a computer, once it detected.
Feb 26, 2015 | Apple Iphone 4 - A1349
My iphone says it is disabled and connect to itunes. how do i unblock it ?
did you put the password in wrong to many times.When an iphone gets disabled all you can do is put it in to restore mode and restore it you will lose all your data thats on the phone but if its backed up you can load it back on.If you had it unlocked do not update to the latest firmware or you will lose your ability to unlock, without changing your bootloader to the ipad one.
hope this helps
Dec 23, 2010 | Cell Phones
How do i unlock an iphone that has been disabled
To recover your device from being disabled, you need to put it to DFU mode and restore it thru iTunes. I made a guide that can help you with that. Click below to read it.
http://www.fixya.com/support/r5541493-put_iphone_ipod_touch_dfu_mode_restore
For more iPhone / iPod touch tips, click here.
Nov 22, 2009 | Apple iPhone Smartphone
Iphone is disabled connect to itunes and when i connect to itunes it says "cannot connect since it is locked with a passcode. unlock the phone. what can i do?
To get iphone to connect to itunes disconnect it from USB cord, press on/off button until you see slide to turn off, slide to turn iphone off. After iphone is off press and hold home button and reconnect to USB cord (do not release home button) continue holding button until you see itunes has detected an iphone in recovery mode then release home button. Proceed with restore.
Aug 10, 2008 | Apple iPhone Smartphone
Iphone is disabled
I read a tutorial on disable iPhone backup password, hope it help you:
http://www.windowspasswordsrecovery.com/iphone/disable-backup-password-in-itunes.html
Jul 28, 2008 | Apple iPhone Smartphone
Cell Phones Logo
42 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
