Question about Sony KDS55A2000 55" HDTV
I was replacing the bulb in my sony kds60a2000 and when replacing the door I broke a small plastic piece on the edge. can this door be purchased? will glue be enough to fix it?
5 Suggested Answers
  • 21 Answers
SOURCE: sony sxrd bulb doesnt last 9blinks
IF SET HAS ERROR 9 THEN THE S1 and S2 board ARE PROBABLY THE REASON. DID YOU USE ORIGINAL SONY LAMPS ? GENERIC LAMPS (ESPECIALLY IN SONY) DON'T LAST. AND IS THE SET IN A CABINET ? I HAVE ALSO SEEN PROBLEMS WITH THE FANS GETTING DUSTY AND THE VENTS ON THE SIDE OF THE SET FILLED WITH DUST.
DON..
Posted on Jan 29, 2008
premtech
  • 934 Answers
SOURCE: can you tell me HOW
Kcasey,
It's covered in the owner's manual which you can obtain here: http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DOCS
Just type in your model number and it will display a pdf which you can navigate to lamp replacement...
Bill
Posted on Dec 02, 2008
  • 175 Answers
SOURCE: (4) Light Tunnel Mirrors Came Apart
i will email you piks u need to use high temp sealer
Posted on May 28, 2010
Slinteriors
  • 8617 Answers
SOURCE: Optical Block needs replacing
unfortunately the optical blockissue kills any resale value except for the chassis boards value for used boards. Parting it out will be your best bet as alot of people may be needing the boards.
Posted on Feb 28, 2013
The plastic lugs to the lid and edges of the battery case on the camera have broken ,this is causing the lid to not close properly
yep, happens to most all of them eventually. mine has broken twice. i had it repaired at the camera shop and the next time i put in new batteries it broke again. i'm sticking to a piece of tape. i've seen you can buy the replacement door online and i've seen the instructions for replacing it yourself via a google search.
Jan 23, 2011 | Sony Cyber-Shot DSC-W1 Digital Camera
How to replace the third brake light (hatch) on a 2005 hyundai accent. I took off the 4 screw on the the plastic cover and it still won't come off. Tried taking off cove of back hatch but don't want to...
Above the third brake light is a small panel, remove this panel using small screwdriver.
1. You'll see four (4) bolts, remove the three bolts that are painted black, do not remove the center bolt holding the plastic molding, this is for the door molding, and has nothing to do with the light.
2. Once those three bolts are out, you'll see two more small screws, remove them and you'll have access to the third brake light bulb.
Be careful when pulling out the bulb, my bulb broke, and I'm still trying to get pieces out! - Good luck.
Jan 16, 2011 | 2005 Hyundai Accent
The plastic piece that holds the headlight bulb is broke. Can I replace that piece without buying the whole headlight?
you might be able to find one at a salvage yard but you should be able to purchase that piece on it's own at the dealership.
Jan 03, 2011 | 1999 Nissan Quest
NEC VT595 Projector - Status light blinks red constantly
We had this same problem. In our case it turned out that a little bit of plastic broke off of a tab on the inside of the plastic lamp cover. Without that piece it was not pressing against the sensor that tells the projector that the lamp cover is closed. Without that, it doesn't start. We got it working again by drilling a little hole and sticking a screw through that spot to replace the missing plastic, but I'd rather replace the cover if I could. Really dumb that a little piece of plastic can mess up thousands of dollars worth of equipment (Smartboard 2000i).
May 26, 2010 | NEC VT595 LCD Projector
The plastic piece that holds the pin for the ice dispenser door
not repairable..have to replace whole door..stuff a rag in the hole/buy door/or get a new refrigerator...sorry. Greg
Jun 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No light under console shifter
Half the answer?
There is a small access panel to the right of the shifter where a small flathead screw driver can be gently placed. Pry out the plastic panel. Now gently work the black trim off that surrounds the shifter using the inside of the hole that you just opened.
The trim will pop up. The silver piece of plastic will pull up. (The part that the shifter works through.) Now you can pull up the piece of plastic that has the gears listed on it. Set this aside. There is a small led bulb under this piece- to the left of the shifter.
Now, I have no idea how to get the bulb out. I have tried prying it out, and I broke the bulb, but it did not work anyway. My point is be careful because the glass went everywhere. Wear eye protection. I am stuck at this point.
There is a piece of black plastic around the base of the bulb, but I cannot figure out how to remove the bulb itself. Access is tight. The bulb is in a "ditch" of plastic with no real room to work in.
I tried to remove the armrest, but there is no access from this side.
Mar 15, 2009 | 2000 Acura TL
Can you tell me HOW to replace the bulb on the sony kds60a2000?
Kcasey,
Bill
Dec 02, 2008 | Sony KDS55A2000 55" HDTV
Door handle 1996 thunderbird
sounds like a plastic Sir clip of course you say external handel detached from door consider linkage clip has fallen down!
Dec 01, 2008 | 1996 Ford Thunderbird LX
Sony KDS55A2000 55" HDTV Logo
65 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
