Question about Insignia NS-LCD22-09 LCD HDTV
Troubleshooting Insignia NS-LCD22-09 LCD Haveing problems with volume going up to max and remote & tv controls locking up. Tryed unplugging, then everything works, but only for a few mintues, volume goes up again and controls lock up.
SOURCE: Controls Don't Work
I have this EXACT SAME problem with my Insignia 26" LCD TV. I was three weeks out of warranty when it happened and Insignia wouldn't do anything to help me. I brought it to three repair shops and each repairman said that they couldn't guarantee they could fix it even IF they got the right parts. Anyhow, the TV repairman had it for three months (getting parts shipped from Asia, repair time, etc.) and he couldn't fix it. He also told me that tons of other people have the issue and that Insignia is replacing their TVs under warranty. So, if your TV is still under warranty, call Insignia. You just have to pay for shipping and shipping insurance. Hope this helps!
Posted on May 18, 2007
SOURCE: I have a a insignia lcd tv model ns-27lcd turns off by itself
check timer it may be set it will continue until its turned off
Posted on Sep 17, 2007
SOURCE: Insignia NS LCD32 standby light blinking off and on. No Power
I had this problem as well. Actually best buy just left my hosue to fix it. This is the second time they were here to fix it. The first time they said a part was loose. This time they had to replace a part.
Posted on Apr 01, 2008
SOURCE: Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Posted on Aug 26, 2008
SOURCE: my lcd tv is locked how do i unlock it
The lock code that COMES with the TV is factory set to 0000. If it was changed, I think you may be out of luck
Posted on Sep 08, 2008
Volume display on max on my 47
What likely is wrong if volume is at max and cannot turn down--the volume down button on the set is bad---seen this and to say the least irritates me.
The buttons on the set each engage a tiny switch--a momentary one--means only should react when pressed but they fail in exactly this way.
Remote is number 2 in line--that is to say the buttons on the set have priority over the remote control.
Only way to prove this is gain access to the vol up button/switch and unsolder the switch (two pins).
If set now is normal (thank god) you can either leave the switch out or replace the board with all the buttons/switches. Remote will still be able with defective switch out to operate sound.
If you think your problem is bad I have seen same issue with channel up and down buttons--always it is the switch.
SD TECH
Apr 25, 2012 | Insignia NS-LCD47HD-09 47 in. LCD TV
I own an Insignia flat screen tv, NS-LCD27, & I was given the Insignia converter box, NS-DXA1; how do I program tv remote for the box? Thanks, frances b.
The digital to analog converters did not exist when the TV was built and the remote programmed. Thus you will have more luck programming the converter box's remote to control the TV. (At least with my converter box, the included remote could only turn on and off the TV. It would only change channels on the converter.)
Most universal remotes only have codes for devices released 6 months or more before the TV was programmed. So a new universal remote will probably control both the TV and the converter box. (Program the converter box using a code for LG or Zenith set top boxes if Insignia isn't listed. LG makes Insignia video products for Best Buy.) The remotes that are programmable by a USB connection to a computer are the fastest to set up.
A replacement remote for your TV is available here: http://www.mcmelectronics.com/partfinder.aspx?brand=&mdl=NS-LCD27&mode=part . An exact replacement remote for the converter box can be purchased at: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13055197980390&smodel=NSDXA1&brand_pn=INSIGNIA_NSDXA1 . The manual for the converter box (as a PDF) is here: http://cbsdallas.files.wordpress.com/2011/01/insignia-ns-dxa1-manual.pdf .
I hope this helps.
May 16, 2011 | Insignia Televison & Video
Insignia/tvflat32" automatically channel will change to ch8
i hve the same tv and the same problem. heres the fix; you must take off the back cover so you have the back of the lcd exposed. its about 30 r so screws to get it all off. once you have the back panal off look at the side where the power button channel button and volume ect. button are. follow the wire thats connected to that, to the motherboard. simply unplug this wire from the mother board and use your remote control to change channels and power on off the unit from now on.
Sep 30, 2010 | Insignia NS-LCD37 37 in. LCD TV
I need a remote code for my insignia tv model NS-CL19C Serial # DC0UEOEO300DW78X0288
Many remote control codes can be found at InsigniaProducts.com. Just search for your TV model number and click Support!
Jun 29, 2010 | Insignia NS-LCD19 19 in. LCD TV
Insignia NS-PDP50 Plasma TV - Remote Sensor failure
Change batteries.Reboot everythings.Tv unplug,replug couple mins later.Ur Directv box,push off/on for new update software.After that sould work.Rate me after u done this.
Jan 02, 2010 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
Volume
Sounds like it's locked. Either hold the remote control "DISP" down for 3 seconds, or press it repeatedly about 10 times & it'll unlock.
Jul 16, 2008 | Insignia NS- 27" TV27 TV
Accidentally locked out of my TV
Unfortunately with this model of Insignia you MUST have the remote that comes with that model number in order to unlock it. Other Insignia remotes won't work. So I have ordered another remote from an online company. Hopefully that will work. I'll probably have to call Insignia to have them walk me through it once the remote arrives.
May 24, 2008 | Insignia LCDTV26 26 in. Television
Tv is locked
hi guys got same tv same prob......finally after hours of frustration found a solution.
steps:
  • Turn on tv
  • Press and hold the menu button (you will hold this through the next few steps till the menu comes up)
  • turn the tv off using the silver button on the back of the tv
  • push the button back in on the back of the tv
  • tv should come on and bring up the menu
  • using the channel and volume get to the menu with the v-chip controls there should be a reset menu button change it to on.
  • turn off tv using power button on front of tv.
  • turn it back on and problem should be solved
Sep 08, 2007 | Televison & Video
Insignia NS-LCD22-09 LCD HDTV Logo
180 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
