Question about Garmin Nuvi 350 Car GPS Receiver
Was using my c350 . Drove in to a inside parking lot & parkedd. Came out reprogamed to to a new address & could not get a sattalite coverage. moved out side & gps wen black & would not come back on.
  • Garmin Master
  • 2,130 Answers
Please see this link for more info:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Oct 08, 2009
Transmission for 1999 cara van
did you check the fluid in the transmissin it could be low or also it could need a new transmission filter i wouldnt try to drive it it anymore without checkin or changin it because it will burn it up
Feb 16, 2013 | 1999 Dodge Grand Caravan
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
I install new imaging unit cyan and magenta but c350 machine shows still change imaging unit error. how to fix this error.
Did you turn the main power switch OFF then back ON? You need to do that to reset the counter. Also, did you put a brand new one in from a closed box or a used one? If it is a new one & it will not clear, return it to where you got it from... Good Luck
May 22, 2010 | Minolta C350 Color Printer/Scanner/Copier
Drove the car fine parked it went to drive it an
First guess is that your battery is worn out, a new one will probably do the trick
Feb 28, 2010 | 1999 Volkswagen Passat
Installed new battery yesterday, drove fine. Sat in parking lot while at work. After work drove home, car stalled and died in very cold weather. Restarted after 10 min. Drove home another 2 minutes. Two...
All lights are supposed to turn off when a subaru key is off right? No! There is a switch on top of the steering wheel column that will turn on lights for warning when parked. You somehow have hit that switch.
Jan 08, 2010 | 1991 Subaru Legacy
No sattalite service
Acquisition of satellites has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Aug 11, 2009 | Garmin nuvi 200W GPS Receiver
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
My samsung phone (model # SGH-A117) might have gotten run over. it fell out of my car in a parking lot without realizing it..about 10 minutes later i drove back to the parking lot and found my phone...it...
I would pull the sim and get a replacement phone or take it in for repair sounds like the board is fractured. Also try popping the battery out and back in.
May 03, 2008 | Cell Phones
Garmin Nuvi 350 Car GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
