Question about HP OfficeJet 6110 All-In-One InkJet Printer
When the setup program asks me to plug in the printer, I get the driver finder dialog box, which can't find the driver and doesn't install it.
    Scholar:
  • 115 Answers
Download your driver first from the link below. Install it and then try your software again. This should solve the problem. You can install the driver without the software and you can still print, you just won't have any of the software...but install first then do the software again. If this doesn't work then the issue may be deeper. Try this first. Just select your OS on this site and download your driver. Cheers.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=79478&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=79476
Posted on Oct 06, 2009
Printer is not scan but some problem she has. Error in scannor Turn off scannor and follow instructions ni manual. Scannor drive will closed. Code : 61,213,0 I want to new setup Canon PIXMA MP160...
  1. Select 'Program' (for Windows 2000/Me/98), or 'All Programs' (for Windows XP) from the Start menu.
  2. Select the name of the printer model to remove and select 'Uninstall.'
  3. When the MP Drivers Uninstaller window is displayed, click 'Perform.'
  4. When the confirmation window is displayed, click 'Yes.'
  5. When the Uninstallation Complete window is displayed, click 'Complete.'
  6. Reinstall the drivers.
Reinstall the Drivers
Note:
  • The MP drivers can be installed using Easy Install or Custom Install.
    Easy Install automatically installs the software which is in the CD-ROM.
    This method is recommended for first-time users.
    Custom Install allows you to select the software programs from MP Drivers, Application Software, and On-screen Manual.
  • Login as a user with Administrator privileges to install on WindowsXP/2000.
  • Close any antivirus software that may be running prior to installing the drivers.
  1. Turn off the printer and disconnect the cable connecting the computer and the printer.
  2. Insert CD-ROM in the computer. (The CD-ROM will start automatically and the following window will be displayed on the screen.)
    1. If setup does not start automatically, click 'Start' and then 'Run'.
    2. At the Run window, type x:\msetup4.exe (where x is your computer's CD drive) in Open box and then click 'OK'.
  3. At the main installation window, click 'Easy Install' or 'Custom Install'.
    When selecting Easy Install:
    (A) Click 'Easy Install'.
    (B) Click 'Install' in the following window.
    * Display varies according to the printer model.
    When selecting Custom Install:
    (A) Click 'Custom Install'.
    (B) When the following window is displayed, click 'MP Drivers' and the application software to be installed, and then click 'Next'.
  4. When the License Agreement window is displayed, read the content carefully and click 'Yes'.
  5. The installation will start.
    Messages may be displayed during the installation of the application software.
    Follow the instructions on the window and continue the installation.
  6. When the Printer Connection window appears, connect the printer to the computer and power on the printer.
    Note: If the installation cannot proceed even after 2 minutes, stop the installation by following the procedures below and start from the beginning again.
    1) Click 'Cancel' at the Printer Connection window then click 'Start Over' at the Installation Failure window.
    2) At the window to install the driver / applications appears, click 'Back' then click 'Exit'.
    3) Restart the computer.
    4) Install the printer driver again.
  7. For Windows XP, at the Welcome to the Found New Hardware Wizard dialog box, confirm Install the software automatically (Recommended) is selected, then click 'Next'.
    Note: The Welcome to the Found New Hardware Wizard dialog box may be behind the Printer Connection window.
    In this case, click 'Found New Hardware Wizard' button on the task bar to display the window.
  8. After the files are copied automatically and the dialog box Completing Found New Hardware Wizard window appears, click 'Finish'.
  9. If the Welcome to the Found New Hardware Wizard dialog box appears again, click 'Finish' again.
  10. At the Print Head Alignment window, click 'Execute'.
    Note:
    * The Execute button may not appear for all models. In that case, skip to step 13.
    * The Print Head Alignment can also be done after the installation of the printer driver.
  11. When the Start Print Head Alignment window appears, load one sheet of A4 or letter size plain paper in the sheet feeder and click 'Print Head Alignment'.
  12. At the Do not start another operation until current one has finished dialog box, click 'OK'.
  13. When the pattern is printed, click 'Next' at the Print Head Alignment dialog box.
  14. At the Installation Results dialog box, check the content then click 'Next'.
  15. At the Installation completed successfully dialog box, click 'Exit'.
    Note: When the Restart button appears, confirm that Restart the system now (recommended) is checked then click 'Restart'.
Dec 04, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Lo'st cd so cannot install printer on new laptop
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Dec 02, 2010 | Lexmark All-in-One Printer with PictBridge
How do you change "print page setup" from Default:
Go to the list of installed printers on your PC, right click on the name of the printer affected, and select Properties.
  1. Click the Device tab. NOTE: This may be listed as the Install Options tab in some programs.
  2. Most driver programs will have either an Update or an Ask Printer button. See the highlighted example in the picture below. Clicking this button instructs the program to check the printer's current configuration and settings. The program will then update the driver to reflect the current settings and installed items.
Dialog box
If your driver program does not have an Update/Ask Printer button or if the button is disabled or does not work, you can add the duplex option manually. Select Duplex Option and select your choices.Here you can configure the printer for your needs.
Oct 28, 2010 | Lexmark T632 Laser Printer
Can't install my x4270 lexmark to my laptop
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
Jun 02, 2009 | Lexmark X4270 All-In-One InkJet Printer
No install cd where can i get free download on line
Hey,
1.Download software
4.Done
Thanks,
Ekse
Jun 01, 2009 | Lexmark X75 All-In-One InkJet Printer
Lost installation disk for lexmark printer z600
Hey,
1.Download software
4.Done
Thanks,
Ekse
May 06, 2009 | Lexmark Z600 InkJet Printer
I need dawonlad printer lexmrk 615z . plessss send me .
Hey,
1.Download software
4.Done
Thanks,
Ekse
May 05, 2009 | Lexmark Z615M Printer
Lost my instaletion sd
Hey,
1.Download software
4.Done
Thanks,
Ekse
Mar 02, 2009 | Lexmark X2350 All-In-One InkJet Printer
I need software for my lexmakz615inkjetprinter
Hey,
1.Download software
4.Done
Thanks,
Ekse
Mar 02, 2009 | Lexmark Z600 InkJet Printer
Lexmark E322 Printer Driver
Hey,
1.Download software
4.Done
Thanks,
Ekse
Feb 26, 2009 | Lexmark E322 Laser Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
