Question about Mitel Computers & Internet
Mitel 5550 Console cannot obtain ip address. - Mitel Computers & Internet
How do i get a IP Address on a Mitel 5312 IP Phone if i connect it to the router it works i work at home my router is
hard to get to so when i connect it to my laptop or desktop all wireless nothing happens ?
Posted on Jul 27, 2010
  • 37 Answers
Follow the proper boot-up sequence in the manual, and verify the PC boots up on the native lan first.
Posted on Oct 14, 2009
How can I get a second hand Mitel 5215 to accept an IP address?
Your phone needs an IP address in order to communicate. Normally, it asks a "host" for that IP. You need to be connected to the internet for it to connect to the normal host, and your router should be willing to give it that IP address. "DHCP" is how devices ask for and get an IP address.
May 11, 2015 | Mitel 5215 IP Phone
How to get my ip address
IP address of your router can be obtained from Ip-details.com .I use this site to get my IP address. It provides additional information about an IP like Internet service provider, location of an IP address,latitude,longitude etc
Jan 16, 2013 | Sony PlayStation Portable (PSP) Console
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
How do you reprogram mitel
You need a program called mitel db programming.
You will need to know the system IP address and the usernam and password.
Once on you can reprogramme any extension, as well as many other things.
Apr 17, 2012 | Mitel 5220 IP Phone
How do i manually configure and ip address for the mitel 5224 ip phone?
Press and hold the up arrow.
Configure Phone - Yes
network parameters - yes
press no until you see "change" and press yes.
You will need to set the following appropriately.
IP address, Subnet address, default gateway, ICP controller address, TFTP address, VLAN ID, VLAN priority, DiffServe Value, DNS address.
Normally it is not necessary to set the phone static except for testing. If your network and DHCP server is set up properly, you are not gaining any benefit for setting it static.
Also, you should find out what the other IP addressess are that are static on the Voice subnet. Along with that, you will need to know the DHCP range. These are needed so you don't assign a duplicate IP address to your network. Assign the phone to the wrong device could do great harm to your network. Assign it to use the same IP address as the phone system and none of your phones will operate.
Use with caution,
Mark
Feb 10, 2011 | Mitel 5224 IP Phone
Hi, I need to set the IP configuration on my MITEL 5212 IP Phone manually, but I do not know how to do it. I guess that there is a sequence of key to press, any help will be appreciated.
Press and hold the up arrow key while booting the phone. Configure telephone - YES, Network Parameters - yes, then NO until you see Change. Set the appropriate information, IP address, default gateway, ICP IP address, TFTP server address, etc.
You should be warned that this gains nothing except making another device on the network that requires deliberate management.
- Mark
Feb 02, 2011 | Mitel 5212 IP Phone
On the 5330 i have a Discovery option 128 missing message. There is not a dialtone on the phone, how do I make the phone operational?
I had this problem as well. This is a configuration that needs to be added to your DHCP server to enable the mitel system to obtain an iP address. If you reboot the phone and hold the down arrow it should bring you to a screen you can manually enter the IP address of the network you are useing.
Jan 26, 2011 | Mitel 5220 IP Phone
I am trying to register my Mitel 5201 IP phone to our mitel system but it is not working. The message indicator light does want to flash anymore, nothing happens when i connect it. Please help!!!
the 5201 set must be registered manually in the phone system. Log into the system. Change the extension. Type the MAC address of the phone in the proper field in the form. The MAC address is located on the bottom of the phone.
Sep 14, 2010 | Mitel 5201 IP Phone
I want to change the time on the face of my 5020 mitel phone. I have a user manual but it does not address this issue. Please help! It's an hour and 10 minutes ahead and it's hard to work thinking it's 5pm...
Login to phone system or you can setup the time thru the console or a sub attendent phone. If the class of service has that option. It is a little different for the different Mitel phone systems.
Dec 21, 2009 | Mitel 5020
Computers & Internet Logo
1,080 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
