Question about GE 46GW 948 46" Rear Projection Television
Shuts down after power up sound for a second then nothing
Just wondering whats wrong with it!
Just a guess but the capacitors are not susutainging enough power or a bad power supply
Posted on Dec 23, 2007
My chrome tablet has a blue dot wont turn on or shut off whats wrong
Shut it down by simultaneously:
Holding down power button
Holding down volume down
Holding down Home button
For 10 seconds.
After shut down, restart it.
Aug 31, 2017 | Tablets & eReaders
My WD 57733 will attempt to power up (almost like a whistling sound as it attempt to power up) then will power back down.
When was the last time you replaced the lamp? That sort of sounds like the ballast is unhappy with a bad lamp. The 57733 is a good TV. The other possibility is a stuck/dirty color wheel.
Check the lamp and see if it looks worn out(dark or grey in the tube down the center). Also make sure its either a Philips brand or Osram brand.
Let me know and Ill see what I can recommend next
Sep 12, 2016 | Mitsubishi WD-57733 57" HDTV
Peavey DPC1400x turns on, plays sound for a split second, buzzes, then goes silent. All lights show green though. What could this be?
This sounds like a power supply capacitor leaking causing a dc bias problem and amp protection shuts it down.
May 06, 2014 | Peavey Audio Players & Recorders
Sanyo flat screen lcd 46 inch
Probably the power supply is failing intermittently, just shutting down without affecting picture or sound.
Mar 10, 2014 | Televison & Video
My infocus IN1 projector won't turn on anymore.
It may be the lamp is out. Normally a projector will try & fire the lamp 3-5 times then shut down with a different color light like amber or red. If the lamp doesn't light then it could be the lamp or perhaps the lamp ballast that starts the lamp has failed. A stuck fan also causes similar symptoms. There's 2-4 fans in the projector if one is stuck or bad it will turn off within 5 seconds or so after the lamp lights.
Does your lamp light at all? Are the lights a different color after it shuts down? Answers to these questions help figure out what's wrong though it's impossible to say for sure without looking at it. I service almost all Infocus projectors if you would like a quote please reply with your email address or write me at prmhelp@earthlink.net
Good Luck,
Jim
Jul 24, 2009 | InFocus Televison & Video
When the power button the red button flashes but nothing else hap
the red light flashing means the set is in auto shut down, could be a power supply problem or a convergence IC problem. tech should first check all diodes and caps in power supply then replace convergence IC's
Jan 11, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Immediate power shutdown on Vio Desktop
it appears like you have a bad power switch. or its connection to motherboard is wrong.
do let us know how you found the solution and do rate the solution
Dec 06, 2008 | Sony VAIO VGC-RB53 PC Desktop
Power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Jan 24, 2008 | Computers & Internet
Open Questions:
See all GE 46GW 948 46" Rear Projection Television Questions
GE 46GW 948 46" Rear Projection Television Logo
29 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
