Question about GE JGBP24 Gas Kitchen Range
Removal and Replace bad ignitor in GE JGBP24
Anyone have a link or directions to remove and replace a bad ignitor. I have been told to remove two screws, cut wires and replace. The replacement will have two ceramic wire nuts. I have found that on my current range one of the wires has a plastic connector and the other connects directly to the oven safety value. Any help would be appreciated.....seems straihgt forward to want to double check prior to removal. Thanks!
  • bholdman Oct 06, 2009
    Thanks for the info. The screws on the ignitor are next to impossible to get out....had to remove bake burner. I hope it is the ignitor that is bad.....ha! Thanks again!
  • GE Master
  • 3,361 Answers
Cut the wires AT the ignitor and wire in the new ignitor. Ignore the plastic connector.
Posted on Oct 06, 2009
Oven wont light up and i smell a lot of gas so i quit trying before i blow up the house.
Greetings,
This could be alot of different things...Usually, the ignitor goes bad and will not open the gas valve..It should not be letting gas come on for the oven,..On the other hand, I have seen some open up and the ignitor just was not hot enough to ignite the gas....I'd look there first...the ignitor should glow , but again, just because it does..Does not mean its good..The only way to check this is to check the amperage draw on the ignitor...if by chance you have a clamp on meter or know someone who does...it should be drawing 3.2 amps at least...the round ignitors draw. I believe 2.5 or better................Bruce Denton
Dec 08, 2010 | GE JGBP24 Gas Kitchen Range
GE Profile Spectra XL44 oven- Makes a popping noise while heating up
assuming you have a gas rang here sounds like a bad ignitor, too long to light causes a "popping "noise when it finally does, as well as extending cooking time and perhaps slight smell of gas while cooking, all signs of bad ignitor.when you start the oven should light bake bar in 40-60 secs. any longer, bad ignitor
easy part to replace yourself part num wb2x9154, remove bottom of oven cavity, 2 screws mount ignitor to burner and 2 wires lead from ignitor( use wire nuts provided if needed . and makes no difference which wire goes where theres no polarity.
Feb 26, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
My oven won't heat borlier does
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 18, 2010 | GE JGBP24 Gas Kitchen Range
My ge gas range wont work on BAKE but everything else works model JGS905SEK2SS
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one.
Feb 09, 2010 | GE Profile JGB900 Gas Kitchen Range
GE Profile Gas Range, oven doesn't heat up on any
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list above.
Jan 28, 2010 | GE Profile JGS968 Gas Kitchen Range
My GE jgbp24 oven is stuck in self-cleaning mode. How can I fix this?
It sounds like the self clean solenoid has locked the door and you will need a service technician to come and release it for you. You will likely need to replace the door locking mechanism.
Jan 26, 2010 | GE JGBP24 Gas Kitchen Range
I do see an orange glow at the bottom. No heat
its a bad ignitor
the glow should be almost white hot
this heat is what opens the gas valve
dont go looking for a fuse
Oct 03, 2009 | GE JGBP24 Gas Kitchen Range
Burners and Broiler work, oven will not heat up. I have been told bad ignition....help
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
vc
Oven is not working; won't preheat or get hot
Called a reepairman who couldn't even figure out how to take the range door off. I called the GE Support Line and they gave me directions on how to take the door off. I ended up paying this guy $137.00 for me to basically do the repair myself ($62 for the part and $75 for labor). The ignitor was replaced. I just hope it will keep working. You smell alot of burning when the oven is on now. The old ignitor had burn spots on the wires as though they had caught fire. The old ignitor also had wire covers and the new ignitor does not have these (wires are exposed and very thin). When I asked the repairman about some other issues. He had no clue as how to respond. Don't call the repairman!!! You can replace the ignitor yourself.
Apr 28, 2008 | GE Kitchen Ranges
GE JGBP24 Gas Kitchen Range Logo
191 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
