Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
My tv turns on then off by its self
Ok i had lines down the tv, fixed those and now the Tv turns on and then goes to stand by its self and i don't know what to do
  • 1 more comment
  • tazz1243 Dec 23, 2007
    more info when i frist plug it in and turn it on it makes a high pitched noise and then it shows the screen for about a second and then it goes to standby and i try to turn it on agin it does nothing
  • LVOpus Jan 02, 2008
    what did it take to fix the black vertical lines? If it was a new part do you know which? I have the same problem as well as 5 others on this site. Good luck with your new problem.
  • tazz1243 Mar 02, 2008
    Problem Solver:
  • 6 Answers
Ok tazz u need to put it back in factory and that should solve your problem do u know how just let me know ok and lvopus for your problem u need a new part is the upper drive and the lover drive that should solve the problem
Posted on Feb 28, 2008
My Element 40" Tv is stuck in stand by how do I
hi have you changed the batteries in the remote, if the remote is ok there's a fault with the tv, could be a swollen capacitors shorted diode or poor solder joint,or a bad mainboard , thanks
Mar 08, 2017 | Element ELCHW402 40 in. LCD HDTV
I turn tv on, all seems to be good, after 1 min. the screen goes black, after another 30 to 45 sec. the sound goes. At the bottom where the on/off button is, the green and red words flash on and off
I checked GSPN.Com servicer line for Samsung technicians. This television has a fan for cooling the plasma panel. Can you tell if the fan or fans are operating properly. If fans don't turn on this tv would certaily overheat. Fan sensors would cause television to shut down if the y are not operating. First thing I would check.
Jul 14, 2011 | Samsung HP-R4252 42 in. Plasma HDTV
Tv goes to stand by mode and does not come on
u have alot loose connection on the power supply board is the same deflection board , if u have same solder skill u can do this job , have in mind this require alot of time to do this job and know wicht connection to do but is better if u hire a tv tech todo thid kine of job
Apr 13, 2010 | Televison & Video
Plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
Mar 23, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Sleep light
i have a simular problem with my sony kvfs120 32, my stand by timer is flashing and the tv will do nothing else. the flasing light is actually a self diagonistic code mine is flasing 5 times.
May 20, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv wont turn on
i have a nlc-3204bc funai hd ready, the stand by light keeps flashing red on and on, can not switch it on
Feb 17, 2008 | Televison & Video
After turning on the TV it turns off after being on for under 5 minutes
try leaveing it on stand by mode for 24 hours do not tuch the tv at all or you will have to do it all over a gain it might just be your back up battery is dieing it might reboot its self if you leave it for 24 hours on stand by mode ok
Jan 04, 2008 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
Sony KV-35S42 35" TV
Check first for bad solder on the vertical IC, Im not sure for your set as I do not have the service manual, but it may be location IC301. If after resoldering it does not fix it you may have to replace it and you should replace the electrolytic capacitors in the vertical section. Hope this helps. Don
Jul 31, 2007 | Sony KV-35S42 35" TV
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
