Question about Drills
Changing drill bits
I miss placed my manual and can't remember how to change the drill bits. Your help would be greatly appreciated. thanks in advance, Anne.
  • 687 Answers
If its a three jaw chuck l must either have knurled diameter across two parts just behind where the bit fits if so then twist the two parts in opposite directions.
Otherwise if there is a small hole near a circular rack then you will need the appropriate sized chuck key which will do the same job.
Hope this helps.
Posted on Oct 10, 2009
Holes missing from 5 tier bookcase metal Putting shelves together. Can I drill Holes in metal?
Yes you can, you just need a drill, the correct size SHARP drill bit, a pin punch - important!! - (to punch a dent in the exact place you want the hole to be - this will hold the drill bit in place when you start drilling)..take you time..use a piece of wood (2x4) to back up the piece your are drilling into... then deburr with a file..
Jul 02, 2017 | Drills
Drill bit does not stay gripped, chuckless drill
On this particular tool, you can't really tighten the bit in the anvil like a bit in a drill chuck. The bit is free floating but held in place by a small steel ball. The steel ball is held in place by the sleeve that slides up and down to release the ball so the bits can be changed. The sleeve is held down by a spring. Bits falling out can be caused by: Using bits without the groove in the bottom of them for the ball to catch in, dirt in the bottom of the anvil so the bit can't seat properly, the ball is missing or stuck, the spring is broke or binding, or the sleeve is bent or too dirty to slide up and down freely. Use compressed air to clean the anvil well and WD40 to clean and lube it further. If bits still fall out you'll have to take it apart and see if the ball, spring or sleeve need to be replaced.
Jan 13, 2013 | Dewalt DW056 18 Volt Cordless Impact...
Hi. I bought a Makita cordless drill, model 8391D. Whilst drilling a pilot masonry hole it suddenly stopped. The battery had only just started to slow so I changed it anyway to a fully charged one and the...
I would try changing the brushes and use compressed air I would blow out all the dust and lint I could from around motor.
If this does not help I would return for guarntee replacement. Thank you.
Mar 19, 2011 | Makita Garden
Have never used a hand dill, how do i change the drill bit. i need to drill a small hole. thank you anne
Typically, the end of the drill where the bit is inserted (called the 'chuck') rotates to loosen or tighten the arms holding the bit in place. Grasp the top of the drill with one hand and rotate the end the bit is inserted into counter-clockwise if the bit end is pointed towards you to loosen the arms and release the bit.
If it is an older drill it may have a 'key' that would look similar to end of a phillips screwdriver on a tee that can be inserted into where the chuck and the rest of the drill assembly meet and twisted to loosen the bit.
If neither of these work post what type of drill you are using as not all hand drills are the same. Hope this helps.
Dec 10, 2010 | Garden
What is trick to changing the bits? i unlock it but cant get it out
I think it is an issue of having to pull real hard with that model. The hex bits stick a lot especially when new or using another brand of bit. Hope this helps a little:)
Farmerbear
Aug 30, 2010 | Black & Decker Black And Decker Pivot...
Changing Bit
where the bit goes into the drill there is a metal ring. Pull the metal ring away from the drill with one hand and pull the bit out. this model you may have to pull the meteal ring twards the body of the drill.
Feb 26, 2010 | Makita 9.6v Cordless Impact Driver 6903VD
Drill bits do not lock in chuck or will not go in at all.
If the picture that I am seeing is of the same that you have then I can tell you that those are special bits that are fluted on the shanks so they can hammer. Also those drills do not chuck up like a regular drill. You have to pull the collar down insert the bit and rotate it until it falls in and then release the collar. Remember these bits are specific to the drill and can be hard to find, a rental store is a good place to find them for sale. Hope this helps. 2rns4u <*{{{>(
Apr 04, 2009 | Makita HR3000C Electric Rotary Hammer
How to change an air drill chuck
If the screw will not loosen use an impact drver with the proper size allen bit on it.
example:
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_36882_36882
Apr 01, 2009 | Air Tools & Compressors
Missing driver for mass storage controller
have you tried www.storagedrivers.com
scroll down to company list and you'll see acer in there
let me know and please don't forget to rate
thanks
Feb 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
Drills Logo
145 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
