Question about Whirlpool GBS307PDS Electric Single Oven
I ran a cleaning cycle on the oven and now it won't heat
The oven when turned on after the cleaning cycle does not produce heat. It starts a preheat cycle with a few clicks audible but no heat to either element. I turned off the breaker to the oven with now help... Any assistance would be great. RL
  • rosie40 Dec 23, 2007
    I had the same problem w/ my ge dbl. oven after cleaning. The tech came out yesterday. My upper oven baking element was fried where it plugs into the back of the oven. It was concealed under a panel in the botom of the oven. The high extended heat of the clean cycle must have pushed it over the edge....
    Has to order the part, but he was at least able to get my lower oven to work independently. It will run me about $215.00 when all is said and done for the trip charge, parts and labor.
  • Anonymous Jan 08, 2008
    I have the same oven and the same problem - I ran a 3 hour clean cycle and the next day when I tried to use the oven I discovered all the lights, fan, etc. come on but the element doesn't heat up.
    Since it appears that is an issue that others have had, I won't invest any more money in it. I'm off to replace it with another brand.
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Oven not heating
Gallow, Whirlpool put out a service flash on this model concerning the TCO located in the back. Regarding oven wont heat up, control panel normal. It has to do with the TCO (thermostat fuse) located just under the vent in back and it's tripping. Since you had the elements checked out, Im suspecting this TCO. Usually when these thermostats open, they are non resetable and you don't have any heat at all. The best thing to do is check this TCO with a meter. If it shows open, thats probably the culprit. They recommend moving the new TCO over to the left about 6 inches so it is not directly under the vent. You are going to need help pulling the built in out just far enough to get at the TCO. The part number for it is 4450934. The service flash is 22-647. Catriver...post back.
Posted on Oct 12, 2006
barkencoa
  • 3463 Answers
SOURCE: My double oven has stopped working, its only the
If the fan is working o/k, then you need to fit a new oven element, located at rear of oven behind removeable cover.
Please rate my solution.
Thanks.
Posted on Nov 18, 2009
  • 45 Answers
SOURCE: elements wont come on, although fan and preheat
Thermal fuse behind oven probably opened up.
Posted on Jan 25, 2010
fixyourboard
  • 310 Answers
SOURCE: My Whirlpool oven stopped heating. The control
There is a thermal fuse mounted on the back of the oven that feeds power to both elements. This fuse has open up. The control panel gets power via a different path and still lights up.
Posted on Jun 25, 2010
Ran the self cleaning cycle and now the preheat light will not turn off when it gets to the temperature I set it to. It just keeps preheating. Example: I set the oven for 375. It seemed like it had been...
Sounds like a circuit board issue. If in Warranty, contact the manufacturer and have the controller replaced. A routine cleaning has noting to do with the normal operation of the baking or broiling function. Cleaning is disengaged after the door is unlocked and ready for general aplications.
Feb 20, 2014 | Ovens
Turn the oven on to preheat, it beeps says that it is preheated but heats at about 100 degrees less than what I have set it for. This just started.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Thermador wall oven (POMW301/02) when bake is selected, heats up very slowly until the pre-heat light goes off. And then the oven light stays on but it doesn't hold the set temperature. While it...
Due to the nature of the self-cleaning cycle heating the oven to above normal temperatures what likely happened is that the temperature sensor went bad. The sensor is a small rod about 6 inches long and 1/4 inches wide that sits in the back of the oven. You can remove it from the back side of the oven which will need to be pulled from the wall. Replacing it should solve the problem.
Let me know how this works out for you.
Benjamin
Dec 28, 2009 | Ovens
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self clean doesn't start
i would pop the top up and see if there is a bad switch on the handle that locks the oven.
Feb 13, 2009 | Whirlpool RBD306PD Electric Double Oven
Smoking Kenmore
Hello oliver909
Welcome,
You said,Smoke is coming out of the back of my gas Kenmore oven. Oven is clean - no spills/debris. Ran clean cycle and broiler did not smoke. Warmer drawer at bottom, so nothing spilled there. Soon as you turn it on, downstairs is full of smoke. Sometimes after preheat goes off, smoke clears and its fine. But I'm afraid to use it because last time I saw a flame inside.
If your afraid to use it, do not hesitate to call service. Nobody wants a fire!
Huuum
Oct 09, 2008 | Kenmore 33464 / 33465 / 33469 Gas Single...
Self-cleaned the oven now it doesn't heat
We had the same problem earlier this week. My husband was able to get Electrolux to cover the service call. He just kept asking for the supervisor when he call their customer service rep. It apparently is an issue ... the serviceman came out today, but we have to wait another week for him to come back with the parts (something for the electronic panel that apparently will correct the issue for future cleaning cycles).
So - insist that they pay for the service call!
Oct 04, 2008 | Electrolux ICON Designer E30SO75ESS Oven
Viking oven broil keeps on
it is designed to preheat this way. after the unit cycles the red indicator light off the first time than both elements turn off. when it calls for heat again only the bake elements comes on. makes the preheating work faster.
May 05, 2008 | Viking 30" Professional Select Built-in...
Whirlpool GBS307PDS Electric Single Oven Logo
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
