Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Inducer Fan Seems To Be Rattling
I have a Carrier Weather Maker 8000 and lately it started this rattling noise. Its when the furnace first turns on and the inducer fan kicks on to clean out the flue. I checked the blower while I had the fan on the thermostat and it was extremely quiet and running well. What could be wrong with the inducer fan/motor that is causing it to rattle like this. A guy said a screw popped out of place but I have a hard time believing that because there is so many other things it can be and sound like it would be realistic in happening. Can anyone help?
  • GarrettK Oct 06, 2009
    Its Carrier Weather Maker 8000 is the brand and how could birds get into there when on the roof its covered?
  • Anonymous Mar 19, 2014
    Normal operations will the blower motor run if the inducer fan motor faiks
    Problem Solver:
  • 6 Answers
What make of furnace check for birds and blockage
unfortunatley when they go there gone the squirrel cage wheel will not come of shaft u will need motor n wheel or a "plug n play housing all in one"
Posted on Oct 06, 2009
  • divywood Oct 07, 2009
    the exhaust has to exit some were hopefully not in the attic,,,,,weather maker 8000 is a non condensation furnace it has metal flu pipe wich goes into a chimney or power vented outside thru the wall.....in some cases the furnace and water heater are tied together to share a common chimney or flu liner mice chipmunks burds leafs bees all can find there way in thru the outlet...... its simple enough to remove the flue from the exiting connection of the furnace and look in just remember to put the screws back in place as well as the flu pipe
My janitrol furnace started to make a lot of noise over the last few days. Could something be loose or does it need to be cleaned?
I hate to say it but it sounds like the bearing in the fan is going out. If your lucky there's a replacement...if not then a new furnace. You will have to have it looked at by a furnace tech.
Its too bad I can't hear the noise then I'd have a better answer for you, sorry.
Dec 30, 2014 | Goodman 66005 Furnace Draft Inducer Motor...
Carrier furnace clicking/rattling
Hi some thing in the blower motor or combustion fan?
Feb 16, 2010 | Heating & Cooling
Flame sensor dirty
Sandpaper lightly scrubbed over the sensor tip to remove any contamination.
Sometimes cleaning is not enough and the sensor must be replaced.
Jan 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a new home 1 yr and when the furnace kicks in, I am assuming the fan it makes a noise but as soon as the heat starts the noise is gone, could this be the furnace blower
Check by turning the unit off and turn the fan to on. Do you hear the noise now? The noise your hearing could be coming from your combustion fan assembly instead. Newer furnaces have a in-shot burner and are nosier than the old style of heater.
Jan 04, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Fan Won't Spin
Is it humming like a stuck motor or rattling, like a loose fan. If it's rattling, the fan could eith be loose on the motor or, the center hub could have broken loose.
Aug 10, 2009 | Carrier 38CKC036 Air Conditioner
Carrier Weathermaker 8000 - furnace does not ignite
having a problem with a weather maker 8000. It will not come on at all unless I shut down the switch on the side of the furnace. filters is clean. it will start to light then stop
Dec 10, 2008 | Heating & Cooling
Caerrier weather maker 8000
Your cooling coil may be frozen. Turn the fan on and the cooling to off so air will circulate to defrost the coil. After air circulation is re-established in about 90 minutes turn the cooling back on. Operate the system with the fan on when in the cooling mode should eliminate the freezing problem.
May 26, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Ignition failure
THE AUTOMATIC IGNITION IS TIMMING OUT BECAUSE IT WILL NOT LIGHT PROBABLY A BAD THERMOCOUPLER TRY TO LIGHT IT MANUALY
Jan 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
1,052 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
