Question about E-Machines eMachines Desktop PC
Turn computer on. Three beeps, fan on, won't go through set up.
Won't boot up. Fan on. Three beeps, nothing else.
  • 788 Answers
I have left you a webpage to get your infomation on.
Without knowing what BIOS you have or model number of motherboard, I can't go any further.
http://www.techspot.com/vb/topic95391.html
Posted on Oct 06, 2009
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Nov 02, 2012 | HP Pavilion a1720n PC Desktop
Alienware Area-51 Desktop won't boot up long beep
The fan to the left of your RAM slots needs to spin, it may be the reason for your problem. If this is the CPU fan then you may have a dead CPU.
Contact a computer technician for repair or claim warranty support.
Take care!
damnor01
Sep 21, 2012 | Alienware PC Systems Alienware Area-51®...
Computer won't boot
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 26, 2012 | Computers & Internet
PCV R44G, won't boot, no fans, won' turn on.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 22, 2012 | Sony Computers & Internet
Gateway GM5442 PC Desktop Won't Boot!
3 BEEPS -RAM
Guest Posts: n/a 01-24-2005 We had a power failure in the office this weekend. All the systems are back
up and running fine, except for the receptionists. It's a Gateway
Professional Series. P4 1.3 Ghz. It is giving me three beeps. No boot up
screen and no video source (monitor light stays yellow instead of turning
green). I looked up the beep code and it says three beeps means the ram
needs reseated. Which I have done several times. Also, I have just put in
one stick in difference seats. I have also reseated all the cards at least
three times. I have switched the jumper to try to boot into setup mode.
Nothing there either. Popped out the cmos battery and put it back in. No
good either.
Has all the ram been fried? The fan on the cpu is still spinning. The cd-rom
ejects. I can't hear the hard drive spinning. I guess I can swap the hard
drive for a different one.
Anything I'm missing? YEP
http://support.gateway.com/s/MOTHERBD/INTEL/m00262/beepcode.shtml
Apr 06, 2012 | Gateway GM5442 PC Desktop
Acer computer won't boot has long buzzing noise
The long buzzing sound indicate the nature of the problem. Depending on the manufacture of your bios will determine the problem. With only one long beep you may have memory problem. The computer cannot initiate the boot sequence. Did you add any devices to the computer prior to your problem. if you did undo what you did. Make sure the computer is on, if nothing happens ( no lights, no sound, no fans etc.) the computer has a power failure. Make sure you listen to the beep if it is a numerous beep sequence note it down and check the web for computer beep during boot up.
Mar 25, 2012 | Computers & Internet
DELL 8400 MAKES A LOUD FAN NOISE AND WONT BOOT
There are 2 basic fans in Dell tower one for the power supply and the other for the Processor. If your computer is not booting then the Processor fan is most likely to be the culprit. What could be happening is that the Processor fan is no longer turning fast enough to cool the processor, so normal the processor when it over heats there is either protection to switch off the computer automatically or the computer won't boot. The best thing is to change the fan and make sure it is working properly but checking on the cables that they won't entangle on top of the fan to impede it's movement. You can easily damage your processor if the fan is not working properly.
Oct 18, 2011 | Dell Dimension 8400 PC Desktop
Acer aspire sa80-9b7z won't start up. Fan starts
Firstly check the monitor, if you get 8 beeps as it is starting up, this points to graphics problems. Trying another monitor. If the problem remains, swap the graphics card or use the onboard graphics card.
If this fails and, more importantly, you are not getting any beeps (single beep would indicate your CPU is ok), the problem is likely to lie with the motherboard.
To help you further, please repost with the number of beeps if any, you get as it tries to boot up
Jun 16, 2011 | Acer Computers & Internet
Motherboard won't boot up cpu fan comes on hdd
Just after that there was NO correct answer to fix this problem causes the problem not solved even if it is marked as solved. Me too I have this problem, I was fix it by setting jumpers to default 60 Hz AC power because I won`t have 50Hz AC power or some AC power converter before PSU, I mean this is voltage errors, it`s need to be set to default +5V(60Hz) PSU not +5VSB(50Hz) PSU, (Step1) like might be set to USBPW12 to pin 3 both USB to right side inserted jumper it`s in left side of, near ATX 12v advanced CPU power cable connection socket. Next (step 2) is set up front USB jumpers to +5V or system won`t start up, it`s on motherboard about between PCI1 and PCI2 on right side it must be set to USBPW56 and don`t set it to USBPW78(5+VBS) because system won`t start up, the jumper must be set to right side I mean it`s last jumpers to right side need to be set up, because it`s +5V(60Hz) PSU supply. The USB wake-up feature requires a power supply that can provide at least 500mA on the +5VSB lead when these jumpers are set to +5VSB otherwise the system won`t power up. Next step if it still not starts up its BIOS fault, it`s easy to repair, just (Step3) turn off PC remove BIOS battery (it`s down to IDE cables), start it up wait a bit, then turn it off and turn it again on wait a bit again, turn it off place BIOS battery in to socket to be able save BIOS settings i mean battery is need to save them otherwise settings won`t be saved and Chassis will be broken. (Step 4) Turn PC on press del key after BIOS is load in open Power\Hardware monitoring\Chassis Intruder set to Disable, save settings exit. (Step5) If BIOS (PC won`t power up) it`s Chassis1 jumper fault, it`s need set to Default (Chassis signal, and GND(Ground)), it`s between SATA 2 and SATA1(Serial ATA connectors 7-pin it`s near and down to BIOS battery, the jumpers might be set to right side, after it`s completed repeat Step3 and Step4. CMOS is BIOS battery. If that all doesn't works Take BIOS clearing jumper in it`s clear state, near BIOS chip. Turn on PC with CMOS clear jumper turned on its work. Take beck jumper in its default state after that take bios chip out and CMOS battery out both them an two times restart PC after insert all beck if PC will be working all keyboard flashes once, after its in AC power.
May 07, 2010 | ASUS P4P800-VM Motherboard
No video
change the boot sequence from the BIOS and set the first boot to the Hard disk and check.
Nov 11, 2009 | Gateway GT5220 PC Desktop
E-Machines eMachines Desktop PC Logo
107 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
