Have 250Gb hard drive. Shows only 127Gb available. Used fdisk to remove and replace partition and reformat drive. No help. Drive is quiet running.
  • 6 more comments
  • ira2812 Oct 05, 2009
    Win XP. Also tried it on a machine
    running Win 98. Made no difference.
  • ira2812 Oct 06, 2009
    I'll try that...I have another 250Gb drive on the
    same machine that reads the whole 250. It also
    works in the win98 machine. Both drives are the
    Same brand, etc. I'm beginning to think some
    of the platters aren't being seen...Maybe an
    open trace on the pcb or a component gone bad.
    Forgot to mention the XP machine is a Dell 3000
    and the Win98 machine is a Dell 863.
    Show Full Headers | Printer View | Add Sender To Address Book | Report Spam & Delete
    To: ira2812
    Subject: Please clarify the problem you posted on FixYa.com
    Date: Mon 10/05/09 10:48 PM
    Name Type Save View
    Message text/html Save
    FixYa.com
    Dear ira2812,
    bc9412 has asked you to clarify your question to best assist with your Have 250Gb hard drive. Shows only 127Gb problem:
    what operating system are you using?
    Click here to respond to the request.
    Regards,
    The FixYa Team
    You were listed as one of the team working
    on this problem. Use the link below. I
    have tried to answer but I guess no one is
    set up to look at it.
    Thanks for your time and effort. http://www.fixya.com/ThreadAsker.aspx?th...
    To: ira2812
    Name Type Save View
    FixYa.com
    Dear ira2812,
    Regards,
    The FixYa Team
    Am running WIN XP Pro with SP3. Have two
    identical 250Gb drives. One shows 250Gb
    and the other shows 127Gb. The jumper
    settings on both are identical. Why
    the difference in free space? Have tried
    reversing the positions on the cable.
    Have tried using the cable I was using
    for my CD drives. Nothing seems to make
    a difference. Both are NTFS.
  • bc9412 May 11, 2010
  • Mark Gough May 11, 2010
    what operatingsystem are you using?
    President:
  • 414 Answers
Since you have already posted you are running win xp.
for more info the drive limitations prior to win xp home/pro sp2 is 127 gb.
You can use a seperate partition program for full access to the drive with it being partitioned.
The only way around it is to have win xp home or pro with sp2 already included on the cd.
Mark
Posted on Oct 06, 2009
  • Mark Gough Oct 07, 2009
    With that information what you are describing is a drive with problems. Try another 250 gb drive should'nt have problems. Have you done an update on your bios?
    Mark
    Scholar:
  • 115 Answers
Some computers, especially ones that are older can only read so much hard space. For example if you had a brand new computer but your put in 1 Terabyte HD then you would have to split it into two 500GB HD because the mobo cannot read an entire Terabyte. Do you know what I mean? It is possible the same thing is happening here. If this is not the case, what you can do is when you go to reformat the drive, create a partition but only a small one. This will let the computer know there is more space available and it should redirect all the extra space to the main drive. You should always have a partition even if it's only 1GB of space. Try that, it should work. If it doesn't than you have the other problem where the computer can't read all the space.
Posted on Oct 05, 2009
    Guru:
  • 81 Answers
You can go to BIOS and select the HDD to see the detail, if it shows 250GB in BIOS, its an O/s issue, follow the steps mentioned below or run a recovery (O/s reinstallation). If it shows 127GB in BIOS, its a HDD issue, It needs a repair/replace.
Go to Disk Management...Go to Start - Run - Discmgmt.msc ... Click on Disk Management on right hadn side list. On the left check if you have any unallocated space. Right click on the space and click on create new volume/partition. Follow the wizard and you will see a new partition with the left unallocated space.
Regards,
Shrey
Posted on Oct 07, 2009
Vish2
  • 74 Answers
SOURCE: Partition error
Try using the command FDISK /mbr. This should fix the master boot record. If not, then if you don't care about the data on your drive, you could wipe it clean with any of the several utilities available on the web and then try partitioning it. Search for "Wipe Disk" in Google.
Posted on Sep 28, 2007
Benimur
  • 6966 Answers
SOURCE: 175gb missing from 250GB hard drive
Appreciate the "Ask Me".
The only plausible explanation for the missing disk space would be the protected folder "System Volume Info".
Re-formatting would not restore your free space, however, re-partitioning would. May I suggest that you try PowerQuest Partition Magic. Of course like formatting, re-partitioning would completely delete the partition itself and would grant you back the entire disk space.
Unfortunately you can not use the same with the 1st partition since that is your active partition and presumably where your OS is residing. A workaround is to use another hard disk temporarily and transfer all the contents of partition 1 and make that eventually as your primary HD. Thereafter, re-partition again the entire 250Gb HD.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 28, 2008
  • 33 Answers
SOURCE: hard disk failure..
yes, this can be fixed. if u r runnig on xp the best software for this would be Partition Magic or if u r on vista then Paragon Partition manager.
all the best :)
Posted on Oct 22, 2008
  • 33 Answers
SOURCE: Samsung 40 GB Spin Point Hard Drive problem
try to use some Hard drive recovery programes or try Paragon partition manager.
anaesarora
  • 180 Answers
SOURCE: barracuda hard disk 80gb
the first boot sector of the hard drive is corrupt so fdisk wont work
please use software to repair the boot sectors zero and 63.
usually the softwares are superfdisk which is free on net.
also if you fail use seagate disk manager bootable version. it will be very quick and handy in long term too to format seagate hard drives
Posted on Sep 06, 2009
My new Western Digital Desktop PATA EIDE 3.5 Inch Internal 250GB Hard Drive only shows 127GB on My Computer. I am running XP SP3 with IDE Connectors. Is the Mother Board too old to handle that many...
The motherboard BIOS most likely have a hard drive size limit. Yes you can create two or mare partitions to use the rest of the hard drive space.
Go to Control Panel - Administrator Tools - Disk Manager to create a partition and format this partition.
Aug 12, 2012 | Western Digital Caviar SE 250GB 7200rpm...
I have an Acer 3002LCi laptop. I upgraded the RAM to the maximum 2GB. I also installed a WD Scorpio Blue PATA 250GB HDD. I installed Windows 7 from disk and computer shows drives C and D but drive C...
Install a partition manager program like
http://www.partition-tool.com/personal.htm
open it and you will see the entire hard disk. In there either create another partition in the unallocated space or add it to the D partition.
Mar 23, 2011 | Western Digital Scorpio Blue 250GB PATA...
My 250 gb hard drive is only showing capacity of 127gb
Firstly install SP3 if that doesnt work you need to update your bios to get large disk support. If you dont want to perform any of these fixes you could simply split the drive into 2 or more partitions to access the full 250gb. Goto Control Panel/Computer Management/Disk Management you will see in there the missing gb's of your drive. Simply right click it format it and give it a drive letter.......Cheers from Scott
Apr 18, 2010 | Microsoft Windows XP Professional SP2
80gigs partition then reformatted and displays only 31gigs
If there are files on the drive that you need to recover, then do not format it. It sounds as though the computer that you put the drive into has an issue where the bios perhaps does recognize the drive correctly. Perhaps that can be corrected by updating the bios in the computer, and trying the drive again. Or you may want to put it back into the original computer, back up the files to other media, and then put the drive in the computer and re-partition.
What does the FDISK - "DISPLAY PARTITION INFORMATION" utility report? Do you have a copy of FDISK? If the partitoins in FDISK add up correctly, then it could just be that the data is corrupt, and windows is just unable to read. If that's the case, you should try a recovery application to restore your data..
Nov 15, 2009 | Dell Tablets & eReaders
I have a black caviar 1tb hard drive but its only showing up as 127gb? ive tried it as internal and have now put it in external caddy but still shows as 127gb drive were as should be 1tb
Depending on your computer, if it is older, it may not be able to recognized and more than 127GB. I don't know anything about your computer, which makes this very hard for me to be more accurate. Try using it as an external on another computer and see if that changes things.
Older motherboards (before the massive Memory Increases 500Gb, 1TB) nover planned on it getting that high, so it was not in the programming.
Give that a try.. Sorry I could not be of more help..
Nov 05, 2009 | Western Digital Caviar GP 1TB Internal...
I have a emachines and i want to install a new hard
windows 98 uses the FAT 32 file system and will only read up to 127GB. You could format the drive and divide it into smaller sections and windows should be able to read it fine. Either 2 sections of 80GB each, or multiple smaller sections.
-Download and use the updated FDISK.EXE utility program from Microsoft.
-Keep your partiton size for the Primary partiton that is to be used for drive C: to 127GB or less.
-Use the Windows 98 FORMAT.COM utility program. Note that while the prgram is running it will display an incorrect size for your partition. After it has finished, the summary screen will show the correct size that was formatted.
Formatting large hard drives is extremely slow. If you have a disk setup utility that came with your new hard drive, use it instead of FORMAT.COM. This can save you HOURS of waiting.
Dec 31, 2008 | Western Digital WD1600AB 160 GB EIDE Hard...
Removed partitions. Now 'My Computer' doesn't see HDD.
You may want to use a program called Partition Magic to repartition your hard drive. You can try using the Disk Management Service built in to Windows 2000, XP, and Vista. This is available in "Computer Management" in Administrative Tools in the Control Panel.
Please note that after removing a partition, you need to create a new one then format it before the operating system can read it.
Hope this helps!
Oct 17, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Jul 27, 2008 | LaCie (300770) 250 GB Hard Drive
Partition error
Sep 28, 2007 | Western Digital Caviar 40 GB Hard Drive
Can't format or create partition......
you can try an FDISK form a windows boot disk, but you may need to read up a little on how to use it. or maxtor has a program available on their web sit called powermax that can try to find & repair possible problems. powermax may be the best & easiest way to go. good luck.
Feb 27, 2007 | Maxtor MaXLine Plus II 250 GB Hard Drive
Computers & Internet Logo
1,156 people viewed this question
David Payne
David Payne
