Question about Craftsman Saws
After moving the table saw to a new residence i cant get the rip fence to line up with blade.i tried everything that was in the trouble shooting guide.
  • David Ford
    David Ford May 11, 2010
    Do you have an operators manual for this tool? Usually it gives detailed instructions on how to realign a fence. Give me the number and I will try and find something for you.
  • Jim Thurston May 11, 2010
    On my Craftsman table saw I loosen the bolts on top of the fence and set to paralell with the blade and then retighten the bolts. My saw is about 20 yrs old and I din't know if the fence is still the same. What is your model number??
    Problem Solver:
  • 10 Answers
I am guessing it must be damaged beyond the adjustments. Are you sure the blade is aligned with the table? If not that could be the problem. I have most rip fences for craftsman belt drive saws available, Ebay 'Hokienpokie" or contact me via email, if you need another fence. Jim
Posted on Feb 12, 2010
Table saw blade alignment
Are you referring to the table top or rip fence alignment? The blade itself is not aligned. We adjust the table to parallel with blade and the rip fence should toe away from blade 0.01mm over the length of the rip fence to prevent binding.
Jan 14, 2014 | Delta Saws
Rip fence is out of alignment..what do I need to do?
This is the fundamental problem with rip fences on table saws. I don't know what kind of rip fence you have, but most rip fences are adjustable for squareness. However, unless you have a very nice (and expensive) rip fence, they often don't self-align when you move them anyway. If you have the type that clamps at the front and the back of the table, the problem can be overcome by making sure the rip fence is straight before you clamp it in place. The easiest way I have found to do that is to use an adjustable square. Put the front of the rip fence where you want it, then set the adjustable square so that it matches the distance from the miter slot in the table to the fence. Then move the square to the back of the table and move the back of the fence to meet the end of the square. Now clamp it in place and check the front and the back one more time. It's tedious to do this every time you adjust the fence, but you can get a perfectly aligned fence this way. This method assumes that your blade is parallel to your miter slots, which is adjustable too, but you have to get underneath the saw to do that. good luck, Al K
Jan 14, 2011 | Saws
Rip fence to saw blade alignment
I dont believe there are pictures, but what you need to do is move the fence to the blade, there are 2 10MM bolts on the backside that you need to loosen and then you can move the fence to square with the blade. Snug them down and move the fence and recheck let me know if you have anymore problems
Jul 18, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Problem with 10" craftsman table saw
Your adjustment should be done on the rip fence which will align it to the blade for strait non binding cuts.
May 11, 2010 | Craftsman 10" Table Saw
I can't get the rip fence on my bosch 4000 table saw to square up to the table. the fence is parallel to the blade but when locked down it tilts a hair towards the blade at the top. and it doesn't seem...
hi ,
this is the link to the bosch manual for your table saw , it has the assembly instructions ( just reverse them ) and full details of the alignment proceadures required to true the blade/guides and fences up .
http://mdm.boschwebservices.com/MDMCache/English%20%5BUS%5D/t10/0000000/r00160v-1.pdf
hope this helps
Jan 17, 2010 | Bosch 4000 - 07 Electric Table Saws
Blade Alignment?
ok yep your blade is out of alignment with the fence. It is closer to the fence at the rear than the front. You need to make the modification or adjustment to your fence, if it allows that, and then worry about the miter slots later (which should be adjusted miter slot to blade, not miter slot to fence). You might be able to adjust the miter slot to blade by moving the actual table and then securing witht he table mount bolts. Check your manual for how to align the fence.
You do want to fix that though as it can be potentially dangerous and result in kickback of the workpiece which is a rather SCARY thing, and very dangerous.
Jun 01, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Blade Alignment?
By splitter I take it you mean fence. If this is correct there could be a couple things that I would look for. UNPLUG saw and check the blade at 0 for being inline, make sure flanges are on correctly and finally what I would look at is the adjustable table bringing the fence toward the blade. Loosen lever and move it to the first slot where the guide would go align the front of fence and lock lever then check the back of the fence to make sure it is straight. If not you would have to adjust the back rail to align it. What I made to do this is 2 of the rails from the guide slide into the slot and on the back of the saw are 2 10MM bolts that need to be loosened and the rear slide moved one way or the other after loosening the lever push the fence tight to whatever you use as a guide and snug the bolts move the fence away and then bring back rechecking alignment sometimes you might have to try a couple times but it should work. Tighten the bolts and again recheck If not let me know and I will find a manual for you to download
Feb 20, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Dewalt 10" table saw, when ripping jambs @ back of guide?
Without knowing the full problem, (theheader is cut off) I would ask are you using the fence to help you rip? and when does the board jamb? If it jambs toward the back of the saw the guide might not be square with the blade. I would unplug it and put something that you know is square on the front edge of the blade away from the teeth and adjust the fence so that it is just snub then lock down the table and move the square to the back of saw, it should move with no resistance. If it does then the fence is out. What you would need to do if this is the case is align the fence to the blade, on the back of the saw are 2 10MM bolts that you need to loosen put your square at the front again and lock down the handle with that done move the square to the back and tap the rail on the back side to move tighter or looser and then lock down the bolts. What I do is move the fence away and then back and start all over again to make sure nothing shifted. It sounds more involved than it is. Let me know if this cures your problem
Jan 12, 2009 | Dewalt DW746X 10" woodworker's table saw...
Saws Logo
194 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
