Question about Acer Aspire 5500 5570-2609 Laptop
What cause the screen turns blank with lines across it
  • 408 Answers
Its either the video inverteris bad or the display is bad
Posted on Oct 10, 2009
Older big screen hitachi w/pip tube tv and has blue lines across the screen turn off on it own sometimes.
It could be time to retire the TV.
The blue almost horizontal lines are probably a fault in the flyback blanking and the fact that it will turn itself off is likely due to a poor solder joint on a circuit board inside.
Jun 26, 2016 | Hitachi Televison & Video
Limes across screen when first turned on, by turning off and on sometimes fixes it, what could cause that problem?
If the lines are colored or even look 3d it is a convergence problem--if other lines it will depend on what they look like and what the model number is.
May 27, 2012 | Mitsubishi Televison & Video
Rainbow line will come across screen and then goes blank. This is an intermittent problem. Normally if I turn it off and back on, it works. Now it does not.
try resoldering the vertical output IC, the IC runs at a hot temperature and this can cause the Pins to have cracked solder.
May 23, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Blank screen with a line across the middle
thats the VERTICAL OUTPUT IC that went bad , needs to be replaced . hope this helps
Apr 30, 2008 | Jensen 5" Color TV 5 in. Portable...
Bright,thin line, in the middle of the screen, then...
1. I turn on the monitor, I hear a 'cracklin' sound
Reply: In a CRT Monitor there is a component called EHT which generates High voltage which is connected to the anode of the CRT, If there is any leakage due to moisture can cause this crackiling sound, You need to clean this high tension wire or replace the EHT ( CAUTION : BE AWARE OF HIGH VOLTAGES )
2. The screen only shows a bright, thin line.
Reply: The vertical Drive section of the monitor is faulty.
Dec 21, 2007 | Hitachi SuperScan Elite 802 21" CRT...
Red, Red, Red
Remove front speaker grill and access panel......
Turn red screen control down a little...
Cause may be bad CRT.......................................T.
Nov 07, 2007 | Sony KP-51WS510 51" Rear Projection...
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Acer Aspire 5500 5570-2609 Laptop Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
