Question about Fantom Vacums FM625H Vacuum
How does one get the belt off of the FM625H? My
The belt is broken. I have the brush apart but can't figure out
how to get to the belt.
I sat down and studied the brush and mashed the two levers on the
front and it came apart. But I am not having any luck finding
the right size belt. I called the 800 number and got a guy wanting
my life history and I never got a number. Thanks
Posted on Oct 06, 2009
Vacuum cleaner turns on but has no sucking power.
The belt might have broken if something has clogged the brush head.
Lay it down on the floor and you should see two screws either side of the brushes.
If that doesn't help, you need to tell us what vacuum cleaner you have cos you haven't said.
Mar 09, 2016 | Vacuums
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
A small thin antenna cord on my radio got sucked up, and I immediately turned my vacuum off and easily puled out the small cord, Afterward the brush on the vacuu would notrotate.. The belt is not broken...
Hi Susan. There may still be a piece of the cord in the brush roller bearing. Check the ends of the brush and have a look. If its clear the belt is probably strethed. An easy way to test this is to turn on machine a put you hand against brush, if it stops the belts stretched. I would be will int bet the belt is stretched.l
Feb 09, 2011 | Riccar 8955 Upright Vacuum
Beater bar belt needs replacedon a dyson DC14 animal
Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
Its in the instruction book
Mar 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hoover Upright...OLD vacuum, broken belt
The rod must be your brush roll. it should just pull out, Have you removed the cover over the brush roll? When you do get the brush roll out, turnb the ends and make sure they turn freely, if nit, replace it also.
Sep 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Brushes won't turn
Sounds like you have broken belt. I had the same thing happen, Got replacement belts, but can't figure out how to get the smaller belt back on. There two larger belts - one on each end of the brushes under the clear plastic covers. On the left side there a single silver metal gear, but nothing to hook up the other end of the small belt to drive the brushes. If you take yours apart let me know how to hook up the smaller belt.
Thanks,
David Wood
Aug 13, 2008 | Bissell 9200 Upright Vacuum
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Dirt Devil vacuum sucks... figuratively
Well, I guess your visitors have come and gone, but the vacuum remains the same. It sounds like you have a broken or worn belt. The belt should be changed once a year (approx) and can break if something is picked up that jams the brush. It is also possible that you have something obstructing the vacuum inlet at the brush housing.
If the belt is worn, it can still look o.k., but won't have the tension to turn the roller when it engages the carpet. I suspect the belt is your trouble.
Mar 21, 2008 | Vacuums
Vacuums Logo
117 people viewed this question
Top Fantom Vacums Vacuums Experts
woodzowl307
ray gallant
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
